Текущее время: 23 май 2024, 16:09
 Заголовок сообщения: XFX R7 370 checkered artifacts
СообщениеДобавлено: 10 апр 2020, 01:34
hello Masters, in my little experience I had never seen this type of artifacts, the plate does not crash, does not lose video, just stay with these types of artifacts (image), is it a case of damaged bga or memory? has anyone seen? and have any guidance you can give me?
 Заголовок сообщения: Re: XFX R7 370 checkered artifacts
СообщениеДобавлено: 10 апр 2020, 11:21
Hi! It's first time characteristic for memory, second time for gpu. You can test mats http://vlab.su/viewtopic.php?f=48&t=96805&hilit=%2Amats%2A
СообщениеДобавлено: 10 апр 2020, 12:18
mats are not tested with AMD
СообщениеДобавлено: 10 апр 2020, 12:56
if amd, then try compare heat video memory, clip video memory and gpu, off vtt for video every separately chips. But the fastest heat test for gpu.
СообщениеДобавлено: 11 апр 2020, 19:05
hello, I decided to make a reflow on the gpu and on the memories and the artifacts on the windows screen are gone, in heaven benchamark I also didn't notice any artifacts, but when opening Msi Kombustor it still detects several artifacts, I believe it really is a case of reballing.
Posted after 3 hours 51 minute 30 seconds:
unfortunately I don't have a thermal imager,
I left heaven running for a few hours and the card was apparently working normally, so I went to play The Division 2, and after about 15 minutes the artifacts came back.
if i put a heatsink just noble to the GPU, can i notice any difference in temperature in the memory modules?
СообщениеДобавлено: 17 апр 2020, 22:32
For this install another heatsink.
В этой теме нет новых непрочитанных сообщений. Next GT440 2GB artifacts after loading video driver
FRD
3357
22 окт 2016, 22:17
makarog Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTx 980ti articstorm - artifacts after drive installation
TheMArcos
13
2109
27 мар 2020, 06:40
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gigabyte gtx 770 windforce- artifacts
TheMArcos
06 июл 2020, 20:38
potas Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX Titan 6gb artifacts - mods mats
xxkachellxx
11
2758
01 май 2020, 11:54
BrasilBack Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ZOTAC RTX 2080TI Gets me Artifacts
MicroTech Computers
06 окт 2020, 07:43
LO-master Перейти к последнему сообщению
Сейчас этот форум просматривают: -=lucifer=-, Google [Bot], White2508 и гости: 16
