Текущее время: 30 апр 2024, 20:59
Страница 1 из 1 [ Сообщений: 29 ] |
alynut991
Заголовок сообщения: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 11 дек 2021, 00:50 |
Зарегистрирован: 09 дек 2021, 10:31 Наличности на руках: 14.03
Сообщения: 14 Откуда: Newcastle
Good morning I hope my English is pretty good. I have an xfx 470 8gb with black fans, received from a friend, who tried to change his bios, but unfortunately did not save a backup to the original bios. I took the original bios from another identical video card. I uploaded it using the ch341a program But the video card does not have clock and memory in windows or in hiveos (linux) Windows - https://i.imgur.com/OEu4bIm.pngLinux - https://i.imgur.com/zVLzd6D.pngI had another topic and I closed it by mistake I think.
alynut991
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 13 дек 2021, 14:41 |
pEEp писал(а): 1) PCIe x16 @ x4 (GPU-Z)? 2) vBIOS patched (memory timing)? If "Y" - use Atikmdag patcher (Apply + Reboot).
1) - I tested the video card on two motherboards, In the first and second slot x16 2)- I used and Atikmdag patcher, restart pc (the same problem) restart 2 time (the same problem) . 3)- I re-installed and the windows 10 again maybe something was a blocked driver. I reinstalled the windows 7 maybe i don`t now, maybe work on windows 7 but no... 4)- I bought another identical video card rx 470 xfx , I extracted the chip (fm25q02), Before soldering, I checked the bios with ch341a. I soldering the chip, reinstall driver again restart pc...restart pc again, i try atikmdag patcher ...restart again... 5)- :( @Edit I have the original bios for xfx rx 470 8gb from xfx support. i try this bios and no results. https://drive.google.com/file/d/1n5C5Gv ... QQs4J/view
pEEp
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 20 дек 2021, 22:21 |
Зарегистрирован: 25 сен 2018, 20:41 Наличности на руках: 709.36
Сообщения: 1114 Откуда: Севастополь
alynut991 писал(а): Can it be tested through the integrated video card? Try! - do not be afraid!
alynut991
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 27 дек 2021, 03:36 |
i try tserver with intel graphic integrated. I don`t have display signal when i plug the hdmi cable on gpu (rx470). Error Framerwork AK600.001 https://i.imgur.com/OE9cuMm.jpg
sashazzz039
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 10 янв 2022, 08:19 |
Зарегистрирован: 13 авг 2021, 01:16 Наличности на руках: 122.09
Сообщения: 56 Откуда: NNov
Аналогичная проблема с MSI RX480 8Gb - перепробована куча биосов,но все безрезультатно. Пред история карты - небыло питания памяти и гпу. Восстановил питание на память, вышибло 1 сдвоенный мосфет (М3816N) в 6-й фазе питания гпу (с небольшим прогаром). Заменил все мосфеты и драйвера (CHL8510),а так же ШИМ IR3567B на ASP1300. В 6-й фазе снял драйвер+мосфет+дроссель. По сопротивлениям\напряжениям\ШИМлениям все, вроде бы, в порядке. ----- RX480 8Gb - a bunch of bios have been tried, but to no avail. Pre-history of the card - there was no power supply of memory and GPU. I restored the power supply for memory, 1 dual mosfet (M3816N) was knocked out in the 6th phase of the gpu power supply (with a slight burnout). Replaced all mosfets and drivers (CHL8510), as well as the IR3567B PWM with ASP1300. In the 6th phase, I removed the driver + mosfet + throttle. According to the resistances \ voltages \ PWMs, everything seems to be in order Вложение: gpuz.JPG
sashazzz039
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 10 янв 2022, 12:17 |
Pandemonium6 писал(а): I have written about this error some days ago. It is most likely VRAM. viewtopic.php?f=48&t=121800 Проблемы с памятью ,в первом канале ,были на другой карте RX570, НО при этом в GPU-Z было гораздо больше параметров, чем на скрине в предыдущем моем посте. В предыдущем моем посте, в GPU-Z видно, что параметров очень мало. Сравните 2 скрина: ------------ Memory problems, in the first channel, were on another RX570 card, but the GPU-Z had significantly more parameters than on the screen in the observations of my post. In my post, in GPU-Z, you can see that there are very few parameters. Compare 2 screens: Карта RX570 на которой помог реболл канала А ------------------ RX570 card on which channel A reball helped Вложение: rx570.png Карта RX480 на которой НЕ помог реболл канала А,НЕ помогла так же прошивка БИОСов ------------------ The RX480 card on which the channel A reball did NOT help, the BIOS firmware did NOT help either Вложение: rx480.jpeg
Pandemonium6
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 10 янв 2022, 14:18 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,140.72
Сообщения: 762 Откуда: Holand
Just pay for access, $99 by paypal, it is worth it You will have access to all files. I don't know if it is worth to reball but definitely this error is somehow related to the bank 1 or memory in general. I can't tell whether it is bank 1 or not. I reflowed some cards until today and many came back to life. First clean under the memory, add flux and reflow. One RX580 with typical memory artifacts stopped displaying picture after the VRAM reflow and now I have 5555555 in the whole bank 1, both chips. But at least Tserver reports it. It was artifacting card.
sashazzz039
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 10 янв 2022, 14:22 |
alynut991 писал(а): but now i don`t have permissions to view the files attached. I will compare the pictures when I have access На этой RX480 мало параметров в GPU-Z и не помогает реболл памяти и перезаливка БИОСа ----------------- On this RX480, there are few parameters in GPU-Z and memory reballing and BIOS reloading does not help На этой RX570 почти все параметры, кроме частоты ГПУ - помог реболл/замена памяти по каналу А ------------------ On this RX570, almost all parameters, except for the GPU frequency - helped reball / replace memory on channel A
sashazzz039
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 10 янв 2022, 22:36 |
alynut991 писал(а): Глянул только что скрин ваш - скорее всего в вашем случае всё же нужно смотреть канал А (реболл\замена) А вот в моём случае считаю, что не гпу и не память причина неработоспособности карты. Пересадил ГПУ с заведомо рабочей RX470 - картина точно такая же. Пересадил заведомо рабочую память Hynix 4Gb - без изменений ------------------ I just looked at your screen - most likely in your case you still need to watch channel A (reball \ replacement) , but in my case I think that it is not the GPU and not the memory that causes the card to malfunction. I transplanted a GPU with a deliberately working RX470 - the picture is exactly the same. Transplanted obviously working memory Hynix 4Gb - no changes
pEEp
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 15 янв 2022, 02:10 |
sashazzz039 писал(а): А вот в моём случае считаю, что не гпу и не память причина неработоспособности карты. У вас вБИОС не вычитывается - видно на скринах. У меня у самого такая беда на красной и на зелёной - так и не победил. Да и подсказать никто не смог...
sashazzz039
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 15 янв 2022, 03:29 |
pEEp писал(а): У вас вБИОС не вычитывается - видно на скринах. У меня у самого такая беда на красной и на зелёной - так и не победил. Да и подсказать никто не смог... Вот тут полностью с Вами согласен.Склоняюсь уже давно к этому мнению, что по каким то причинам не вычитывается биос. На первой ноге БИОСа висит 2,75В - на рабочей карте 3,3В - пробовал искусственно подать 3,3в - получилось (путем замены R35, если не изменяет память, на нулевик) - при этом ГПУ перестал совсем определяться. Предположение, что он "в аварии" (а вот по какой причине, это не известно!) и поэтому не дает каким то образом делать, либо "полную вычитку" (осликом смотрел, даже при наличии на первой ноге флешки 2,75, вычитка со 2,5 ноги идет) БИОСа либо еще что то....
JooereX
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 08 фев 2022, 17:59 |
Зарегистрирован: 27 мар 2021, 09:18 Наличности на руках: 81.58
alynut991 писал(а): Error Framerwork AK600.001 Добавлю по поводу этой ошибки. Попалась MSI Armor RX 570 4gb, все сопротивления в норме, кроме питания памяти (0ом, память Hynix). Снял всю память - прозвонил (максимальное сопротивление у одной из банок 22Ом) у гпу сопротивление пришло в норму, заменил память - поставил с донора (не уверен в памяти, предварительно измерил сопротивление), запустил tserver и получил Error Framerwork AK600.001. Попробовал прогнать скриптом dmgg - показал на 3 и 4 банки, соответственно 3 и 4 банку заменил (именно заменил), далее dmgg показал "пасс", tserver прошел нормально и показал "пасс", карта стартанула. Надеюсь кому-то поможет.
Pandemonium6
Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0) Добавлено: 16 фев 2022, 13:59 |
I have exactly the same problem now, on my table. RX580 Asus O8G DUAL. Someone before me unsoldered the bios chip, put there a random content, tried to repair memory voltage, and he did a big mess on the board. The memory rail was 1-2 ohms. It was memory number 1 shorted, immediately visible on the thermal camera, next I got picture and voltages with a lot of artifacts. Memfa still reported bank D0 and D1 so replaced the second memory and the picture came back. Memfa runs to the end but there are artifacts and errors during AK600.001. First part of memfa AK403 passes, all banks are clean but it gives 55555555 errors on all banks during the second part of test AK600.001.
There are strange artifacts on the memfa. Background with small squares and foreground does not look as it should.
