Текущее время: 21 май 2024, 12:26
 Страница 1 из 1 [ Сообщений: 29 ]
 Заголовок сообщения: Xfx 470 8gb - bios problem (clock 0 memory 0)
СообщениеДобавлено: 11 дек 2021, 00:50
Good morning
I hope my English is pretty good.
I have an xfx 470 8gb with black fans, received from a friend, who tried to change his bios, but unfortunately did not save a backup to the original bios.
I took the original bios from another identical video card. I uploaded it using the ch341a program
But the video card does not have clock and memory in windows or in hiveos (linux)
Windows - https://i.imgur.com/OEu4bIm.png
Linux - https://i.imgur.com/zVLzd6D.png
I had another topic and I closed it by mistake I think.
 Заголовок сообщения: Re: Xfx 470 8gb - bios problem (clock 0 memory 0)
СообщениеДобавлено: 11 дек 2021, 02:34
alynut991
1) PCIe x16 @ x4 (GPU-Z)?
2) vBIOS patched (memory timing)? If "Y" - use Atikmdag patcher (Apply + Reboot).
СообщениеДобавлено: 12 дек 2021, 23:05
If anybody can help further
СообщениеДобавлено: 13 дек 2021, 14:41
1) - I tested the video card on two motherboards, In the first and second slot x16
2)- I used and Atikmdag patcher, restart pc (the same problem) restart 2 time (the same problem) .
3)- I re-installed and the windows 10 again maybe something was a blocked driver. I reinstalled the windows 7 maybe i don`t now, maybe work on windows 7 but no...
4)- I bought another identical video card rx 470 xfx , I extracted the chip (fm25q02), Before soldering, I checked the bios with ch341a. I soldering the chip, reinstall driver again restart pc...restart pc again, i try atikmdag patcher ...restart again...
5)- :(
@Edit
I have the original bios for xfx rx 470 8gb from xfx support. i try this bios and no results.
https://drive.google.com/file/d/1n5C5Gv ... QQs4J/view
СообщениеДобавлено: 14 дек 2021, 01:43
alynut991
Next step: looking for broken smd-components.
СообщениеДобавлено: 20 дек 2021, 18:23
I wanted to test the memories with the "tserver" program. but the video card cannot send a signal to the monitor. Can it be tested through the integrated video card?
СообщениеДобавлено: 20 дек 2021, 22:21
Try! - do not be afraid!
СообщениеДобавлено: 22 дек 2021, 14:25
Always use primary and secondary card. Of course when needed.
СообщениеДобавлено: 27 дек 2021, 03:36
i try tserver with intel graphic integrated. I don`t have display signal when i plug the hdmi cable on gpu (rx470).
Error Framerwork AK600.001
https://i.imgur.com/OE9cuMm.jpg
СообщениеДобавлено: 27 дек 2021, 05:17
I have at least two cards with it. Senior forum members here say it can be memory 1 or 2 and it may give this kind of errors. Iw ill test it tomorrow. This is probably such stupid response of the tserver on the error of the first vram.
СообщениеДобавлено: 10 янв 2022, 07:03
Some news? What else could I test or change?
СообщениеДобавлено: 10 янв 2022, 08:19
Аналогичная проблема с MSI RX480 8Gb - перепробована куча биосов,но все безрезультатно.
Пред история карты - небыло питания памяти и гпу. Восстановил питание на память, вышибло 1 сдвоенный мосфет (М3816N) в 6-й фазе питания гпу (с небольшим прогаром). Заменил все мосфеты и драйвера (CHL8510),а так же ШИМ IR3567B на ASP1300. В 6-й фазе снял драйвер+мосфет+дроссель. По сопротивлениям\напряжениям\ШИМлениям все, вроде бы, в порядке.
RX480 8Gb - a bunch of bios have been tried, but to no avail.
Pre-history of the card - there was no power supply of memory and GPU. I restored the power supply for memory, 1 dual mosfet (M3816N) was knocked out in the 6th phase of the gpu power supply (with a slight burnout). Replaced all mosfets and drivers (CHL8510), as well as the IR3567B PWM with ASP1300. In the 6th phase, I removed the driver + mosfet + throttle. According to the resistances \ voltages \ PWMs, everything seems to be in order
Вложение:
СообщениеДобавлено: 10 янв 2022, 08:45
I have written about this error some days ago. It is most likely VRAM.
viewtopic.php?f=48&t=121800
СообщениеДобавлено: 10 янв 2022, 10:41
Pandemonium6 i love you man !
I tried reflow memory bank but nothing change. Do you think it's worth reballing them? or will i waste my time ?
The problem with reballing is that I have a 0.40mm balls no 0.45mm.... work ok with 0.40mm ? :))
СообщениеДобавлено: 10 янв 2022, 12:17
Проблемы с памятью ,в первом канале ,были на другой карте RX570, НО при этом в GPU-Z было гораздо больше параметров, чем на скрине в предыдущем моем посте. В предыдущем моем посте, в GPU-Z видно, что параметров очень мало. Сравните 2 скрина:
Memory problems, in the first channel, were on another RX570 card, but the GPU-Z had significantly more parameters than on the screen in the observations of my post. In my post, in GPU-Z, you can see that there are very few parameters. Compare 2 screens:
Карта RX570 на которой помог реболл канала А
RX570 card on which channel A reball helped
Вложение:
Карта RX480 на которой НЕ помог реболл канала А,НЕ помогла так же прошивка БИОСов
The RX480 card on which the channel A reball did NOT help, the BIOS firmware did NOT help either
Вложение:
СообщениеДобавлено: 10 янв 2022, 13:10
sashazzz039 thanks,
but now i don`t have permissions to view the files attached.
I will compare the pictures when I have access
" You do not have the required permissions to view the files attached to this post.
You must have fifteen (15) or more messages.
You can buy access to files"
СообщениеДобавлено: 10 янв 2022, 14:18
Just pay for access, $99 by paypal, it is worth it :-) You will have access to all files.
I don't know if it is worth to reball but definitely this error is somehow related to the bank 1 or memory in general. I can't tell whether it is bank 1 or not. I reflowed some cards until today and many came back to life. First clean under the memory, add flux and reflow.
One RX580 with typical memory artifacts stopped displaying picture after the VRAM reflow and now I have 5555555 in the whole bank 1, both chips. But at least Tserver reports it. It was artifacting card.
СообщениеДобавлено: 10 янв 2022, 14:22
На этой RX480 мало параметров в GPU-Z и не помогает реболл памяти и перезаливка БИОСа
On this RX480, there are few parameters in GPU-Z and memory reballing and BIOS reloading does not help
На этой RX570 почти все параметры, кроме частоты ГПУ - помог реболл/замена памяти по каналу А
On this RX570, almost all parameters, except for the GPU frequency - helped reball / replace memory on channel A
СообщениеДобавлено: 10 янв 2022, 22:36
alynut991 писал(а):
Глянул только что скрин ваш - скорее всего в вашем случае всё же нужно смотреть канал А (реболл\замена)
А вот в моём случае считаю, что не гпу и не память причина неработоспособности карты.
Пересадил ГПУ с заведомо рабочей RX470 - картина точно такая же.
Пересадил заведомо рабочую память Hynix 4Gb - без изменений :ny_tik:
I just looked at your screen - most likely in your case you still need to watch channel A (reball \ replacement)
, but in my case I think that it is not the GPU and not the memory that causes the card to malfunction.
I transplanted a GPU with a deliberately working RX470 - the picture is exactly the same.
Transplanted obviously working memory Hynix 4Gb - no changes
СообщениеДобавлено: 12 янв 2022, 02:37
I will try to reflow the memory ... if there will be no effect, I will try a reballding.
It's ok if I use it 0.40mm balls ? i don`t have 0.45mm balls for memory. I ordered from aliexpress, but it will arrive in 2 months .
СообщениеДобавлено: 12 янв 2022, 04:23
ничего страшного.Если реболл не помогает,то бери другие 2 банка памяти и пробуй
It's not a big deal.If the reball does not help, then take the other 2 memory banks and try
СообщениеДобавлено: 12 янв 2022, 05:51
sashazzz039 I have 6 memory banks from another gpu xfx 470 which has dead gpu. I will try to replace them.
СообщениеДобавлено: 12 янв 2022, 09:36
Reballing bad memory chip is not a good idea.
СообщениеДобавлено: 12 янв 2022, 09:56
I'm going to reflow her for the first time. if I don't bring her to life, I'll replace them.
СообщениеДобавлено: 15 янв 2022, 02:10
У вас вБИОС не вычитывается - видно на скринах. У меня у самого такая беда на красной и на зелёной - так и не победил. Да и подсказать никто не смог...
СообщениеДобавлено: 15 янв 2022, 03:29
Вот тут полностью с Вами согласен.Склоняюсь уже давно к этому мнению, что по каким то причинам не вычитывается биос. На первой ноге БИОСа висит 2,75В - на рабочей карте 3,3В - пробовал искусственно подать 3,3в - получилось (путем замены R35, если не изменяет память, на нулевик) - при этом ГПУ перестал совсем определяться. Предположение, что он "в аварии" (а вот по какой причине, это не известно!) и поэтому не дает каким то образом делать, либо "полную вычитку" (осликом смотрел, даже при наличии на первой ноге флешки 2,75, вычитка со 2,5 ноги идет) БИОСа либо еще что то....
СообщениеДобавлено: 15 янв 2022, 17:28
Подобная проблема Asua RX570 gaming. Не отображалась частота ГПУ и памяти. Нашел сбитый резистор нулевик под позиционным положением PR157. После восстановления резистора все работает корректно.
СообщениеДобавлено: 08 фев 2022, 17:59
Добавлю по поводу этой ошибки.
Попалась MSI Armor RX 570 4gb, все сопротивления в норме, кроме питания памяти (0ом, память Hynix). Снял всю память - прозвонил (максимальное сопротивление у одной из банок 22Ом) у гпу сопротивление пришло в норму, заменил память - поставил с донора (не уверен в памяти, предварительно измерил сопротивление), запустил tserver и получил Error Framerwork AK600.001. Попробовал прогнать скриптом dmgg - показал на 3 и 4 банки, соответственно 3 и 4 банку заменил (именно заменил), далее dmgg показал "пасс", tserver прошел нормально и показал "пасс", карта стартанула.
Надеюсь кому-то поможет.
СообщениеДобавлено: 16 фев 2022, 13:59
I have exactly the same problem now, on my table.
RX580 Asus O8G DUAL. Someone before me unsoldered the bios chip, put there a random content, tried to repair memory voltage, and he did a big mess on the board. The memory rail was 1-2 ohms.
It was memory number 1 shorted, immediately visible on the thermal camera, next I got picture and voltages with a lot of artifacts. Memfa still reported bank D0 and D1 so replaced the second memory and the picture came back.
Memfa runs to the end but there are artifacts and errors during AK600.001.
First part of memfa AK403 passes, all banks are clean but it gives 55555555 errors on all banks during the second part of test AK600.001.
There are strange artifacts on the memfa. Background with small squares and foreground does not look as it should.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xfx 470 8gb - bios problem (clock 0 memory 0)
alynut991
09 дек 2021, 18:29
Sa1FeR Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX580 8GB with memory speed problem
karlan
22
2828
18 янв 2023, 14:03
karlan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic dri
в форуме Fujitsu-Siemens
draganzile
01 авг 2016, 18:08
draganzile Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX 580 XXX 8GB memory resistance
nikolavik
1204
21 фев 2022, 23:38
nikolavik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. msi rx470 armor 8gb memory problem
amkwca
27 дек 2021, 05:19
Pandemonium6 Перейти к последнему сообщению
Сейчас этот форум просматривают: alovs97, Carl78, HarleyDavidson78, noobon и гости: 17
