Текущее время: 13 май 2024, 15:53
 Заголовок сообщения: GALAX RTX 3070 converted into 3060TI LHR with ram bank B1 C0 with errors
СообщениеДобавлено: 25 май 2023, 13:02
So as the title says, this GALAX RTX 3070 came with damaged GPU chip. The ram chips are Samsung K4Z80325BC-HC14. I found a donor chip which came from EVGA 3060TI. This one is the LHR version, the GA104-202-A1. I ran NVMT with no error on it's soldering. Tried different BIOS from different manufacturer and the problem persist. MATS shows B1 and C0 Write error. Im sure it has to do with the impossibility of the chip to reach those ram chips, mostly because of a bad BIOS config. So i'd like to know what could be the issue? I replaced ram chips with new ones and the problem persist. Thank you!
 Заголовок сообщения: Re: GALAX RTX 3070 converted into 3060TI LHR with ram bank B1 C0 with errors
СообщениеДобавлено: 25 май 2023, 15:17
BIOS - correct flash
СообщениеДобавлено: 26 май 2023, 15:28
Sorry. Which flash file do you suggest?
СообщениеДобавлено: 01 июн 2023, 17:58
3060ti chip does not work correctly on 3070 PCB because the data pads of memories B1 and C0 are in another position, I did the same experience here also with Samsung memories, maybe with memories from other manufacturers (Hynix and Micron) the board can work usually, but that's really just a guess.
СообщениеДобавлено: 04 июн 2023, 22:27
jeffersonsilva998
Conseguiu encontrar solução pra isso ?
СообщениеДобавлено: 24 июн 2023, 08:50
I ended up returning the graphics card because of what jeffersonsilva998 said. Eventually the chip aint compatible with the board. VRAM pins mismatch :za_da_va_la:
СообщениеДобавлено: 27 июн 2023, 19:36
Numa configuração de strap para 16gb samsung talvez esse chip funcione nesse PCB, outra alternativa seria tentar os straps de micron (3060ti GA104 pelo menos existem 2 tipos de configuração para MICRON, um nesse PCB estilo fouders, outro para PCBs que normalmente vem com o GPU da 3070, porem esse teste eu ainda não fiz.)
---------- Добавлено спустя 1 минуту 35 секунд: ----------
HeatElectronics писал(а):
Acabei devolvendo a placa de vídeo por causa do que jeffersonsilva998 disse. Eventualmente o chip não é compatível com a placa. Incompatibilidade de pinos VRAM
If you open a 3060 and a 3070 in boardview, you will see that the data pins of memories B1 and C0 are inverted, but all other channels are the same, that is why there is this bug when you try to place this chip on that PCB
В этой теме нет новых непрочитанных сообщений. RTX 3060ti LHR -> Замена GPU без LHR
yellowfox
23 мар 2022, 00:26
yellowfox Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte RTX 3070 LHR Gaming проблемы на холодную
INVIS
28 окт 2023, 18:47
В этой теме нет новых непрочитанных сообщений. asus rtx 3070 tuf convert to 3060ti
huehu3gg
11 май 2024, 01:46
huehu3gg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3070 and 3070 Ti strange problems
Rorschach315
24
4780
04 мар 2023, 18:56
Roslavl67 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS 3070 TI (LHR)All Voltages Present, NO Picture
aysatx
20 дек 2023, 11:34
crocodile70 Перейти к последнему сообщению
Сейчас этот форум просматривают: vladrak и гости: 25
