New Memory Testing 12_14_21.rar DiskGenius Professional 5.3.0.1066 + Crack
Вложение:
DiskGenius Professional 5.3.0.1066 + Crack.rar
Вложение:
Вложение:
Зарегистрирован: 30 окт 2021, 17:20 Наличности на руках: 2.11 Сообщения: 97 Откуда: England
I don't know how to use it. But Z97 or Z68 motherboard, with Tserver... using RX5700..., makes the normal test script code has memories. You have 2 conditions to not run the program and give an error! The bios is poorly made or hammered. +VDDCI unstable or defective PWM Some memory is even burned and this can be seen with a thermal or impedance sensor.
Сейчас этот форум просматривают: ruzalit и гости: 11
