Текущее время: 17 май 2024, 10:47
 Заголовок сообщения: Acer DA0ZAWMB8G Rev G IT8987E-CXA EC firmware needed..
СообщениеДобавлено: 15 сен 2023, 20:44
Please help me finding good working dump of IT8987E-CXA on Acer DA0ZAWMB8G Rev G
thank you..
 Заголовок сообщения: Re: Acer DA0ZAWMB8G Rev G IT8987E-CXA EC firmware needed..
СообщениеДобавлено: 15 сен 2023, 21:19
EC Dump is in the BIOS. search at 300000h. if necessary, cut out from the BIOS. hex editor can be cut out.
Here is an example of the beginning of the EC firmware in the BIOS.
Вложение:
p.s.
If we don’t know how, send the BIOS from the board to me in a private message (ЛС). I'll cut it out.
СообщениеДобавлено: 16 сен 2023, 01:00
p.s.
Thanks for the hint..
Here is my original bios + EC pulled from it (Starting Address=300000, End=31FFFF, Length=20000 / 128KB)
is everything right ?
P.S I have a bunch of BXA versions instead of CXA, do you think it should work ?
СообщениеДобавлено: 16 сен 2023, 13:50
1. It’s better not to make the BIOS public here. there is a windows key. I wrote what to send in a private message. Better remove the file.
---------- Добавлено спустя 39 минут 30 секунд: ----------
everything is correct
may not work. may not work correctly. It’s better to put what was standing. after all, the revision version of BXA is lower than CXA.
Here's the service firmware to try. cut out EC. bios from here. Thank slavashoot
viewtopic.php?p=733923#p733923
Вложение:
ZAW.rar
СообщениеДобавлено: 18 сен 2023, 00:38
mohammedsf [ТС] if you are interested, there is an ECFinder program for searching and saving multicontroller firmware inside any binary files
and here
viewtopic.php?f=294&t=136639
and here
https://comsystem-tlt.ru/forum/viewtopic.php?t=759
СообщениеДобавлено: 18 сен 2023, 01:59
thanks for the links..
I can't edit my post, I've sent a report but still not answered..
the BXA version made the "ITE Busy" on the SVOD3, replaced with a new CXA version and filled with my dump but still no reaction to the power button..
EC_PWROK = 0v
traced to SYS_SHDN# = 0.4v
traced to Thermal Sensor PU3002 which was shorted, removed and +5VPCU appeared but no +3VPCU
3V_LDO became 0.6v, found a knocked-out capacitor PC6022, installed and 3V_LDO became 3.3v again and +3VPCU appeared
EC_PWROK = 3v and the board started :co_ol:
PU3002 = TMP708AIDBVR
any analogues ??
СообщениеДобавлено: 18 сен 2023, 02:21
ask the moderators to remove it
any analogues ??
TMP708AIDBVR TEMPERATURE SWITCH RESISTOR
maybe they will fit - MAX6509 , MCP9509HT
https://www.ti.com/lit/ds/symlink/tmp70 ... 4922809457
https://ww1.microchip.com/downloads/en/ ... 22114a.pdf
https://www.analog.com/media/en/technic ... AX6510.pdf
В этой теме нет новых непрочитанных сообщений. Tenda W309R firmware dump needed
в форуме Ремонт сетевого оборудования | Network equipment repair
latitude
5417
12 ноя 2019, 19:32
carbonx1992 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. E5-575G (DAZAAMB16E0 rev E) dump it 8987E CXA
StayeR
01 дек 2017, 12:24
StayeR Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus ga503rm (DANJPMB2AA0 REV:A) it8252e248e cxa
nick190280
12
1589
08 сен 2023, 15:13
acelectric Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ACER extensa 2511 (Quanta ZRT rev.D) НЕТ питания IT8987E +3V
Berkut
2725
09 фев 2019, 02:15
vldmrdnpr Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP DV6-6159ER (HPMH-41-AB6200-E00G) Замена IT8518E CXA на IT8528E EXS
Avenger_kz
4854
20 окт 2017, 09:21
eugkov Перейти к последнему сообщению
Сейчас этот форум просматривают: wfun и гости: 7
