Текущее время: 19 май 2024, 20:28
 Заголовок сообщения: HP 450 G6 (Quanta X8J DA0X8JMB8E0 Rev E DSC) Water Damage, identify of 2 chips
СообщениеДобавлено: 13 окт 2023, 05:08
Hello masters..
this board came water damaged, DA0X8JMB8E0 Rev E with discrete graphics,
cleaned and restored except those two chips:
#1 marked "ZU8KA" and #2 marked "AE"
Location on DA0X8JMB8E0 DSC
#2 was easy to identify, a simple 2-input AND gate, it is a 74AHC1G08GW - datasheet
No schematics / boardview of Quanta X8J was found to identify chip #1 but identical chips was found in a different location on photos of DA0X8JMB16E0 "UMA", sadly no schematics / boardview too:
accidentally i've found that this part of the board (DA0X8JMB16E0) is identical to the design of Quanta X8M (DA0X8MMB6D0) and the boardview is available:
so we have the pinout of those chips now :co_ol:
by studying the design and matching to the schematics of Quanta X81 i can confirm now that chip #1 (ZU***) = MC74VHC1G08DFT2G - datasheet
BUT!!! according to the schematics chip #2 is also MC74VHC1G08DFT2G ?! which is a simple 2-input AND gate too..
note that both are supplied by +3v
went back to Quanta X8M's boardview and found that the difference is that MC74VHC1G08DFT2G (ZU***) is supplied by +5v while 74AHC1G08GW (AE) is supplied by +3v, but according to the datasheets both chips can handle 5v supply and i didn't find any differences so i'm lost at this point :zvez_ochki:
what's the difference between those two, or did i identify them incorrectly ?? :wo_ol:
 Заголовок сообщения: Re: HP 450 G6 (Quanta X8J DA0X8JMB8E0 Rev E DSC) Water Damage, identify of 2 chips
СообщениеДобавлено: 13 окт 2023, 13:16
another scan x8j-6l - zu*** = vt. mc74vhc1g08.
>> Location on DA0X8JMB8E0 DSC >>>>>
Последний раз редактировалось jocker 13 окт 2023, 13:22, всего редактировалось 2 раз(а).
СообщениеДобавлено: 13 окт 2023, 13:18
I can’t see from the photo which body it is. sot23-5 or less.
СообщениеДобавлено: 13 окт 2023, 20:01
this photo is from DA0X8JMB16E0 UMA, in the discrete board 8E0 the location is different..
it helped a lot :-ok-:
in your photo ZU*** = VT & AE = V2
by studying the datasheets everything become clear:
ZU*** = VT = CE = 74AHCT1G08 = MC74VHC1GT08 <- TTL Compatible Input
AE = V2 = 74AHC1G08GW = MC74VHC1G08 <- non-TTL
so they are not interchangeable :co_ol:
SOT-353
Posted after 4 hours 50 minutes 32 seconds:
MC74VHC1G08DFT2G found and installed
74AHCT1G08 found in SOT23-5 package (74AHCT1G08DBVR) and installed
board started perfectly :co_ol:
input supply voltages measured on this platform (DA0X8JMB8E0 Rev E DSC):
MC74VHC1G08DFT2G pin#5 = 5v
MC74VHC1GT08DFT2G pin#5 = pre-init 1.2v , after-init 1.35v
thx :-ok-:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Probook 450 (Quanta X8j-8L (DA0X8JMB8E0)) ШИМ питания видео.
Jahm
2340
15 мар 2021, 16:27
Jahm Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 450 G6 / HP 450 G3 (quanta X8J / quanta X63) COMPONENT IDENTICATION
dycc
12 мар 2020, 12:45
Powerman Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI GE62 7RD Apache (MS-16J91) Error in graphics memory with chips and without chips
в форуме MSI
ying
1090
02 окт 2022, 16:25
ying Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Apple Macbook Pro A1278 (K90i, 820-2936) another motherboard with water damage issue
в форуме Apple
andromedax
22 окт 2015, 20:12
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. U46SV (Asus) Water damage
NoLuck
11 фев 2017, 22:05
Гектор Перейти к последнему сообщению
Сейчас этот форум просматривают: digitalworkshop, ЦиNick и гости: 22
