Текущее время: 22 май 2024, 09:35
 Заголовок сообщения: ZOTAC RTX3060 Not access to the BIOS.
СообщениеДобавлено: 14 ноя 2023, 03:48
I received this ZOTAC RTX 3060 Twin Edge OC 12gb
All the voltage are present. Card is not detected.
I check if BIOS (one single chip) is accessed and no, it's not accessed.
I also checked first transmission pair (backward riser insertion??) .... diode mode, both 1,8v ... seems good.
Tomorrow I will check the crystal .... if crystal is good, I think I run out of ideas.
Any tips?
Thanks in advance.
 Заголовок сообщения: Re: ZOTAC RTX3060 Not access to the BIOS.
СообщениеДобавлено: 14 ноя 2023, 16:05
PERST# is open .... tested in diode mode. Doesn't look good to me.
Posted after 2 hours 27 minutes 4 seconds:
Maybe I am on something ....
I found u512 and u513 .... luckily, it seems zotac follow the same schematics as gigabyte (so probably it's nvidia reference)
But as you can see below, u512 is not present. And looking at the board, it seems as it has never been there.
But, there are two pads looking weird. And this could be the missing 0.05 ohm resistor (r711).
So, I suppose that installing the resistor, should bypass the missing u512 and pex_rst should be restored.
But I wonder if I'm missing something. If I put there a 0 ohm resistor, could I do any damage? What is the purpose of u512?
They look as they are level translator.
Thanks in advance.
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sony Vaio PCG-41219V (VPCSB3M1R) Сам включается и запускает quick web access
в форуме Sony
papanin
09 авг 2019, 14:24
papanin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. lenovo s440 (la 9761p) 0187 eaia data access error
фыы
28 янв 2016, 21:46
Dmitriy07 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Yoga S1 (LA-A341P) ошибка 0187 EAIA data access error
Leo_vrn
18 окт 2018, 21:29
ahmeterengul Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ST9500420AS partial access
cyna
15 авг 2018, 17:39
Mordoc Перейти к последнему сообщению
Сейчас этот форум просматривают: GRK, iustin, Sa1FeR и гости: 16
