спасибо разобрался и вроде получилось запустить тест, но не могу понять в каком канале памяти проблема если не трудно можете подсказать куда смотреть
MODS arguments :
MODS start: Wed Dec 13 14:28:59 2023
Command Line : gputest.js -no_gold -test 275
CPU Arch : x86_64 Name : Intel(R) Pentium(R) CPU G4600 @ 3.60GHz Cores : 4
Version MODS : 455.178
System OperatingSystem: Linux (x86_64) Kernel : 5.9.1-gentoo-x86_64 KernelDriver : 4.00 SBIOS Version : P7.70 SBIOS Date : 03/01/2018 HostName : tinylinux Available RAM : 7669/8001 MB (Free/Size) Sys-uuid : HDD-Serno :
GPU 0 [01:00.0] dev.sub 0.0 ---------------------------------------- DevInst : 0 PCI Location : 0x00, 0x01, 0x00, 0x00 GPU DID : 0x2206 PDI : 0x80ff20c1972d46ee Raw ECID : 0x008016400000005d764921c4 Raw ECID (GHS) : 0x4705d76492000000019008100 ECID : SAMSUNG-SNNP98-25_x1_y4 Device Id : GA102 Revision : a1 Sub Revision : 1 NV Base : 0xde000000 FB Base : 0xc0000000 IRQ : 11 ERROR: bp @ <fileid:0x0005e4>:745
ERROR: ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] ------------------------- BEGIN ASSERT INFO DUMP ------------------------- [ ] [0000:00:1c.0] cap id 0x10 found at offs 0x40 [ ] [0000:00:1c.0] extended cap id 0x1 not found [ ] [0000:00:1c.5] cap id 0x10 found at offs 0x40 [ ] [0000:00:1c.5] extended cap id 0x1 not found [ ] Root check: 0000:00:01.0 IsRoot=true [ ] Connecting ports for Chipset 0000:00:01.0: [ ] DP0 0000:00:01.0 connects to test device GPU 0 [01:00.0] [ ] ------Finish bridge detection----- [ ] Detected potential primary VGA device: GPU 0 [01:00.0] [ ] mods [1]: set dma mask 47 for dev 0000:01:00.0 [ ] Suspended Linux console [ ] InitializeAllDevices : RM not initialized, skipping GPU nvlink device initialization [ ] GPU 0 [01:00.0] dev.sub 0.0 [ ] Console: switching consoles 1-1 to colour dummy device 80x25 [ ] ---------------------------------------- [ ] DevInst : 0 [ ] PCI Location : 0x00, 0x01, 0x00, 0x00 [ ] GPU DID : 0x2206 [ ] PDI : 0x80ff20c1972d46ee [ ] Raw ECID : 0x008016400000005d764921c4 [ ] Raw ECID (GHS) : 0x4705d76492000000019008100 [ ] ECID : SAMSUNG-SNNP98-25_x1_y4 [ ] Device Id : GA102 [ ] Revision : a1 [ ] Sub Revision : 1 [ ] NV Base : 0xde000000 [ ] FB Base : 0xc0000000 [ ] IRQ : 11 [ ] MSI-X not supported on GPU 0 [01:00.0], skipping [ ] Detected supported interrupt types: legacy MSI [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] Legacy interrupts verified OK [ ] mods [1]: enabled dev 0000:01:00.0 [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] MSI verified OK [ ] Skipping MSI-X verification [ ] Hooking MSI [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Bypassing unsupported vendor: 0x8086Device already uninitialized [ ] GA102 Azalia: DeviceId: 0x1aef. [ ] Found 1 controllers (DevId 127) [ ] SetAspm on GPU: 0x11030043 [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Found codec on sdin 0 [ ] mods [1]: set dma mask 47 for dev 0000:01:00.1 [ ] The codec contains 1 function group(s). [ ] PEX: set downstream ASPM=0xd1030043 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] DRAM info read from PreOS PBI not supported [ ] Failed to get DRAM information from VBIOS preOS PBI. Will attempt to read from the DRAM. [ ] NVRM: Child aperture crosses parent's boundary, length 925696 offset 0, Parent's length 0 [ ] NVRM: Child aperture crosses parent's boundary, length 1024 offset 0, Parent's length 0 [ ] Setup dma base only supported on PPC, skipping [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] Found (0, 0, 31, 4) with cc = 0xc0500, vid = 0x8086, did = 0xa123 [ ] INTEL - SMBus: DeviceId: 0xa123. [ ] Found 1 devices [ ] mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed [ ] func? polled 494 times in 25007 us on func? and returned 77. [ ] EC Device not found on Smbus [ ] ACPI: Unable to evaluate dev method _PR0, id 0xffffffff on 0000:00:01.0 [ ] mods [1] error: ACPI method _PR0 failed [ ] ata2: SATA link down (SStatus 0 SControl 300) [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: Unexpected versioning (00) encountered in XPIO specific table header # 3. Parsing stopped. [ ] GF100GpuSubdevice: FloorsweepingAffected=0 [ ] GF100GpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF100GpuSubdevice: Floorsweeping parameter mask values: display=0x0 msdec=0x0 msvld=0x0 fbio_shift_override=0x0 ce=0x0 gpc=0x0 fb=0x0 fbio=0x0 fbio_shift=0x0 gpctpc[0]=0x0 gpctpc[1]=0x0 gpctpc[2]=0x0 gpctpc[3]=0x0 gpctpc[4]=0x0 gpctpc[5]=0x0 gpctpc[6]=0x0 gpctpc[7]=0x0 gpczcull[0]=0x0 gpczcull[1]=0x0 gpczcull[2]=0x0 gpczcull[3]=0x0 gpczcull[4]=0x0 gpczcull[5]=0x0 gpczcull[6]=0x0 gpczcull[7]=0x0 [ ] GF108PlusGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF108PlusGpuSubdevice: Floorsweeping parameter mask values: pcie_lane=0x0 fbpa=0x0 spare=0x0 [ ] GM10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM10xGpuSubdevice: Floorsweeping parameter mask values: nvenc=0x0 nvdec=0x0 head=0x0 [ ] GM20xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM20xGpuSubdevice: Floorsweeping parameters mask values: fbp_ltc[0]=0x0 fbp_ltc[1]=0x0 fbp_ltc[2]=0x0 fbp_ltc[3]=0x0 fbp_ltc[4]=0x0 fbp_ltc[5]=0x0 fbp_ltc[6]=0x0 fbp_ltc[7]=0x0 fbp_ltc[8]=0x0 fbp_ltc[9]=0x0 fbp_ltc[10]=0x0 fbp_ltc[11]=0x0 fbp_ltc[12]=0x0 fbp_ltc[13]=0x0 fbp_ltc[14]=0x0 fbp_ltc[15]=0x0 [ ] GP10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GP10xGpuSubdevice: Floorsweeping parameters mask values: gpc_pes[0]=0x0 gpc_pes[1]=0x0 gpc_pes[2]=0x0 gpc_pes[3]=0x0 gpc_pes[4]=0x0 gpc_pes[5]=0x0 gpc_pes[6]=0x0 gpc_pes[7]=0x0 gpc_pes[8]=0x0 gpc_pes[9]=0x0 gpc_pes[10]=0x0 gpc_pes[11]=0x0 gpc_pes[12]=0x0 gpc_pes[13]=0x0 gpc_pes[14]=0x0 gpc_pes[15]=0x0 [ ] TU10x floorsweeping parameters present on commandline: [ ] TU10x floorsweeping parameter mask values: nvlink=0x0 [ ] AmpereFs : Floorsweeping parameters present on commandline: [ ] AmpereFs : Floorsweeping parameters mask values: [ ] _XGQlGpuSubdevice: Floorsweeping parameters present on commandline: _XGQlGpuSubdevice: Floorsweeping parameters mask values: gpc_rop[0]=0x0 gpc_rop[1]=0x0 gpc_rop[2]=0x0 gpc_rop[3]=0x0 gpc_rop[4]=0x0 gpc_rop[5]=0x0 gpc_rop[6]=0x0 gpc_rop[7]=0x0 gpc_rop[8]=0x0 gpc_rop[9]=0x0 gpc_rop[10]=0x0 gpc_rop[11]=0x0 gpc_rop[12]=0x0 gpc_rop[13]=0x0 gpc_rop[14]=0x0 gpc_rop[15]=0x0 [ ] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0 [ ] Unknown init property : FbGddr5x8Mode [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: IOCTRL not present in PTOP, NVLink is unavailable. [ ] NVRM: FECS override applied to FB LTC ECC [ ] NVRM: FECS override applied to FB DRAM ECC [ ] NVRM: BBX object get failed, status=0x57 [ ] Warning: Can't find Pci device with class code 0x30000, index 1 [ ] Warning: Can't find Pci device with class code 0x30200, index 0 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Warning: Can't find Pci device with class code 0x60000, index 1 [ ] Warning: Can't find Pci device with class code 0x60100, index 1 [ ] Warning: Can't find Pci device with class code 0x60200, index 0 [ ] Warning: Can't find Pci device with class code 0x60300, index 0 [ ] Warning: Can't find Pci device with class code 0x60400, index 3 [ ] Warning: Can't find Pci device with class code 0x60401, index 0 [ ] Warning: Can't find Pci device with class code 0x60500, index 0 [ ] Warning: Can't find Pci device with class code 0x60600, index 0 [ ] Warning: Can't find Pci device with class code 0x60700, index 0 [ ] Warning: Can't find Pci device with class code 0x60800, index 0 [ ] Warning: Can't find Pci device with class code 0x60940, index 0 [ ] Warning: Can't find Pci device with class code 0x60980, index 0 [ ] Warning: Can't find Pci device with class code 0x60a00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b01, index 0 [ ] Warning: Can't find Pci device with class code 0x68000, index 0 [ ] NVRM: *** Chipset Setup Function Error! [ ] NVRM: Almost all programmable domains must be included in the VBIOS clock domains. [ ] NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000 [ ] NVRM: Improperly fused GPU ADC code error deltas - skipping the update from fused values. [ ] NVRM: InfoROM PPO object header load failed, status=0x57 [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Not enabling straddling ctag support as platform is not Win10 [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | DDC port | Display Type | Pad Mask | Connected? | Display Mask (name) [ ] NVRM: ----------------------------------------------------------------------------------- [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: | 0x08 | DisplayPort | 0x00000020 | -- | 00002000 ( DFP-0 ). [ ] NVRM: | 0x08 | TMDS | 0x00000020 | -- | 00004000 ( DFP-1 ). [ ] NVRM: | 0x07 | DisplayPort | 0x00000010 | -- | 00000800 ( DFP-2 ). [ ] NVRM: | 0x07 | TMDS | 0x00000010 | -- | 00001000 ( DFP-3 ). [ ] NVRM: | 0x06 | DisplayPort | 0x00000008 | -- | 00000200 ( DFP-4 ). [ ] NVRM: | 0x06 | TMDS | 0x00000008 | -- | 00000400 ( DFP-5 ). [ ] NVRM: | 0x05 | TMDS | 0x00000004 | Yes | 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | Suggested (boot/resume) device(s): 00000100 ( DFP-6 ). [ ] NVRM: | Selecting as primary device: 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: GR binaries will be picked for netlist'0' [ ] NVRM: GR binaries will be picked for netlist'1' [ ] NVRM: GR binaries will be picked for netlist'2' [ ] NVRM: GR binaries will be picked for netlist'3' [ ] NVRM: Child aperture crosses parent's boundary, length 2097152 offset 4194304, Parent's length 0 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid PSI volt ramp down time in VBIOS. Disabling DI coupled PSI. [ ] NVRM: Invalid DI volt settle time in VBIOS. Disabling DI VOLTAGE_UPDATE. [ ] NVRM: OCT object load failed, status=0x57 [ ] NVRM: Breakpoint on RC Disable Override is disabled [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PCI-E device status errors pending (00000009): [ ] NVRM: Clearing these errors.. [ ] NVRM: PCI-E device AER errors pending (00200000): [ ] NVRM: Clearing these errors.. [ ] NVRM: Unable to read VBIOS temperature limits. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19. [ ] NVRM: OBJPMU Async: !Bootloader starting! [ ] NVRM: OBJPMU Async: Bootloader base: 0x606000027D0D7000 [ ] NVRM: OBJPMU Async: Booting... [ ] NVRM: OBJPMU Async: Initializing PMU application [ ] NVRM: OBJPMU Async: initPmuApp [ ] NVRM: Failed to map Logical port (1) to Physical I2C port! File a bug to investigate! [ ] NVRM: Failed to map L2P port for I2C device 0. [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019ae30a [ ] bp @ <fileid:0x0005e4>:745 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP -------------------------- ERROR: bp @ <fileid:0x0005e4>:888
[ 0] ------------------------- BEGIN ASSERT INFO DUMP ------------------------- [ ] mods [1]: set dma mask 47 for dev 0000:01:00.0 [ ] Suspended Linux console [ ] InitializeAllDevices : RM not initialized, skipping GPU nvlink device initialization [ ] GPU 0 [01:00.0] dev.sub 0.0 [ ] Console: switching consoles 1-1 to colour dummy device 80x25 [ ] ---------------------------------------- [ ] DevInst : 0 [ ] PCI Location : 0x00, 0x01, 0x00, 0x00 [ ] GPU DID : 0x2206 [ ] PDI : 0x80ff20c1972d46ee [ ] Raw ECID : 0x008016400000005d764921c4 [ ] Raw ECID (GHS) : 0x4705d76492000000019008100 [ ] ECID : SAMSUNG-SNNP98-25_x1_y4 [ ] Device Id : GA102 [ ] Revision : a1 [ ] Sub Revision : 1 [ ] NV Base : 0xde000000 [ ] FB Base : 0xc0000000 [ ] IRQ : 11 [ ] MSI-X not supported on GPU 0 [01:00.0], skipping [ ] Detected supported interrupt types: legacy MSI [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] Legacy interrupts verified OK [ ] mods [1]: enabled dev 0000:01:00.0 [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] MSI verified OK [ ] Skipping MSI-X verification [ ] Hooking MSI [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Bypassing unsupported vendor: 0x8086Device already uninitialized [ ] GA102 Azalia: DeviceId: 0x1aef. [ ] Found 1 controllers (DevId 127) [ ] SetAspm on GPU: 0x11030043 [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Found codec on sdin 0 [ ] mods [1]: set dma mask 47 for dev 0000:01:00.1 [ ] The codec contains 1 function group(s). [ ] PEX: set downstream ASPM=0xd1030043 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] DRAM info read from PreOS PBI not supported [ ] Failed to get DRAM information from VBIOS preOS PBI. Will attempt to read from the DRAM. [ ] NVRM: Child aperture crosses parent's boundary, length 925696 offset 0, Parent's length 0 [ ] NVRM: Child aperture crosses parent's boundary, length 1024 offset 0, Parent's length 0 [ ] Setup dma base only supported on PPC, skipping [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] Found (0, 0, 31, 4) with cc = 0xc0500, vid = 0x8086, did = 0xa123 [ ] INTEL - SMBus: DeviceId: 0xa123. [ ] Found 1 devices [ ] mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed [ ] func? polled 494 times in 25007 us on func? and returned 77. [ ] EC Device not found on Smbus [ ] ACPI: Unable to evaluate dev method _PR0, id 0xffffffff on 0000:00:01.0 [ ] mods [1] error: ACPI method _PR0 failed [ ] ata2: SATA link down (SStatus 0 SControl 300) [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: Unexpected versioning (00) encountered in XPIO specific table header # 3. Parsing stopped. [ ] GF100GpuSubdevice: FloorsweepingAffected=0 [ ] GF100GpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF100GpuSubdevice: Floorsweeping parameter mask values: display=0x0 msdec=0x0 msvld=0x0 fbio_shift_override=0x0 ce=0x0 gpc=0x0 fb=0x0 fbio=0x0 fbio_shift=0x0 gpctpc[0]=0x0 gpctpc[1]=0x0 gpctpc[2]=0x0 gpctpc[3]=0x0 gpctpc[4]=0x0 gpctpc[5]=0x0 gpctpc[6]=0x0 gpctpc[7]=0x0 gpczcull[0]=0x0 gpczcull[1]=0x0 gpczcull[2]=0x0 gpczcull[3]=0x0 gpczcull[4]=0x0 gpczcull[5]=0x0 gpczcull[6]=0x0 gpczcull[7]=0x0 [ ] GF108PlusGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF108PlusGpuSubdevice: Floorsweeping parameter mask values: pcie_lane=0x0 fbpa=0x0 spare=0x0 [ ] GM10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM10xGpuSubdevice: Floorsweeping parameter mask values: nvenc=0x0 nvdec=0x0 head=0x0 [ ] GM20xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM20xGpuSubdevice: Floorsweeping parameters mask values: fbp_ltc[0]=0x0 fbp_ltc[1]=0x0 fbp_ltc[2]=0x0 fbp_ltc[3]=0x0 fbp_ltc[4]=0x0 fbp_ltc[5]=0x0 fbp_ltc[6]=0x0 fbp_ltc[7]=0x0 fbp_ltc[8]=0x0 fbp_ltc[9]=0x0 fbp_ltc[10]=0x0 fbp_ltc[11]=0x0 fbp_ltc[12]=0x0 fbp_ltc[13]=0x0 fbp_ltc[14]=0x0 fbp_ltc[15]=0x0 [ ] GP10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GP10xGpuSubdevice: Floorsweeping parameters mask values: gpc_pes[0]=0x0 gpc_pes[1]=0x0 gpc_pes[2]=0x0 gpc_pes[3]=0x0 gpc_pes[4]=0x0 gpc_pes[5]=0x0 gpc_pes[6]=0x0 gpc_pes[7]=0x0 gpc_pes[8]=0x0 gpc_pes[9]=0x0 gpc_pes[10]=0x0 gpc_pes[11]=0x0 gpc_pes[12]=0x0 gpc_pes[13]=0x0 gpc_pes[14]=0x0 gpc_pes[15]=0x0 [ ] TU10x floorsweeping parameters present on commandline: [ ] TU10x floorsweeping parameter mask values: nvlink=0x0 [ ] AmpereFs : Floorsweeping parameters present on commandline: [ ] AmpereFs : Floorsweeping parameters mask values: [ ] _XGQlGpuSubdevice: Floorsweeping parameters present on commandline: _XGQlGpuSubdevice: Floorsweeping parameters mask values: gpc_rop[0]=0x0 gpc_rop[1]=0x0 gpc_rop[2]=0x0 gpc_rop[3]=0x0 gpc_rop[4]=0x0 gpc_rop[5]=0x0 gpc_rop[6]=0x0 gpc_rop[7]=0x0 gpc_rop[8]=0x0 gpc_rop[9]=0x0 gpc_rop[10]=0x0 gpc_rop[11]=0x0 gpc_rop[12]=0x0 gpc_rop[13]=0x0 gpc_rop[14]=0x0 gpc_rop[15]=0x0 [ ] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0 [ ] Unknown init property : FbGddr5x8Mode [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: IOCTRL not present in PTOP, NVLink is unavailable. [ ] NVRM: FECS override applied to FB LTC ECC [ ] NVRM: FECS override applied to FB DRAM ECC [ ] NVRM: BBX object get failed, status=0x57 [ ] Warning: Can't find Pci device with class code 0x30000, index 1 [ ] Warning: Can't find Pci device with class code 0x30200, index 0 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Warning: Can't find Pci device with class code 0x60000, index 1 [ ] Warning: Can't find Pci device with class code 0x60100, index 1 [ ] Warning: Can't find Pci device with class code 0x60200, index 0 [ ] Warning: Can't find Pci device with class code 0x60300, index 0 [ ] Warning: Can't find Pci device with class code 0x60400, index 3 [ ] Warning: Can't find Pci device with class code 0x60401, index 0 [ ] Warning: Can't find Pci device with class code 0x60500, index 0 [ ] Warning: Can't find Pci device with class code 0x60600, index 0 [ ] Warning: Can't find Pci device with class code 0x60700, index 0 [ ] Warning: Can't find Pci device with class code 0x60800, index 0 [ ] Warning: Can't find Pci device with class code 0x60940, index 0 [ ] Warning: Can't find Pci device with class code 0x60980, index 0 [ ] Warning: Can't find Pci device with class code 0x60a00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b01, index 0 [ ] Warning: Can't find Pci device with class code 0x68000, index 0 [ ] NVRM: *** Chipset Setup Function Error! [ ] NVRM: Almost all programmable domains must be included in the VBIOS clock domains. [ ] NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000 [ ] NVRM: Improperly fused GPU ADC code error deltas - skipping the update from fused values. [ ] NVRM: InfoROM PPO object header load failed, status=0x57 [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Not enabling straddling ctag support as platform is not Win10 [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | DDC port | Display Type | Pad Mask | Connected? | Display Mask (name) [ ] NVRM: ----------------------------------------------------------------------------------- [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: | 0x08 | DisplayPort | 0x00000020 | -- | 00002000 ( DFP-0 ). [ ] NVRM: | 0x08 | TMDS | 0x00000020 | -- | 00004000 ( DFP-1 ). [ ] NVRM: | 0x07 | DisplayPort | 0x00000010 | -- | 00000800 ( DFP-2 ). [ ] NVRM: | 0x07 | TMDS | 0x00000010 | -- | 00001000 ( DFP-3 ). [ ] NVRM: | 0x06 | DisplayPort | 0x00000008 | -- | 00000200 ( DFP-4 ). [ ] NVRM: | 0x06 | TMDS | 0x00000008 | -- | 00000400 ( DFP-5 ). [ ] NVRM: | 0x05 | TMDS | 0x00000004 | Yes | 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | Suggested (boot/resume) device(s): 00000100 ( DFP-6 ). [ ] NVRM: | Selecting as primary device: 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: GR binaries will be picked for netlist'0' [ ] NVRM: GR binaries will be picked for netlist'1' [ ] NVRM: GR binaries will be picked for netlist'2' [ ] NVRM: GR binaries will be picked for netlist'3' [ ] NVRM: Child aperture crosses parent's boundary, length 2097152 offset 4194304, Parent's length 0 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid PSI volt ramp down time in VBIOS. Disabling DI coupled PSI. [ ] NVRM: Invalid DI volt settle time in VBIOS. Disabling DI VOLTAGE_UPDATE. [ ] NVRM: OCT object load failed, status=0x57 [ ] NVRM: Breakpoint on RC Disable Override is disabled [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PCI-E device status errors pending (00000009): [ ] NVRM: Clearing these errors.. [ ] NVRM: PCI-E device AER errors pending (00200000): [ ] NVRM: Clearing these errors.. [ ] NVRM: Unable to read VBIOS temperature limits. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19. [ ] NVRM: OBJPMU Async: !Bootloader starting! [ ] NVRM: OBJPMU Async: Bootloader base: 0x606000027D0D7000 [ ] NVRM: OBJPMU Async: Booting... [ ] NVRM: OBJPMU Async: Initializing PMU application [ ] NVRM: OBJPMU Async: initPmuApp [ ] NVRM: Failed to map Logical port (1) to Physical I2C port! File a bug to investigate! [ ] NVRM: Failed to map L2P port for I2C device 0. [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019ae30a [ ] bp @ <fileid:0x0005e4>:745 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] First error recorded: 818 Mods detected an assertion failure [ ] JavaScript stack trace: [ ] #0: Initialize() in <native>:0 [ ] #1: InitializeGpuTests() in gputest.jse:341 [ ] #2: gputest_main() in gputest.jse:2227 [ ] #3: main() in gputest.jse:2164 [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019aea68 [ ] bp @ <fileid:0x0005e4>:888 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP -------------------------- ERROR: bp @ <fileid:0x00064f>:530
[ 0] ------------------------- BEGIN ASSERT INFO DUMP ------------------------- [ ] GPU 0 [01:00.0] dev.sub 0.0 [ ] Console: switching consoles 1-1 to colour dummy device 80x25 [ ] ---------------------------------------- [ ] DevInst : 0 [ ] PCI Location : 0x00, 0x01, 0x00, 0x00 [ ] GPU DID : 0x2206 [ ] PDI : 0x80ff20c1972d46ee [ ] Raw ECID : 0x008016400000005d764921c4 [ ] Raw ECID (GHS) : 0x4705d76492000000019008100 [ ] ECID : SAMSUNG-SNNP98-25_x1_y4 [ ] Device Id : GA102 [ ] Revision : a1 [ ] Sub Revision : 1 [ ] NV Base : 0xde000000 [ ] FB Base : 0xc0000000 [ ] IRQ : 11 [ ] MSI-X not supported on GPU 0 [01:00.0], skipping [ ] Detected supported interrupt types: legacy MSI [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] Legacy interrupts verified OK [ ] mods [1]: enabled dev 0000:01:00.0 [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] MSI verified OK [ ] Skipping MSI-X verification [ ] Hooking MSI [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Bypassing unsupported vendor: 0x8086Device already uninitialized [ ] GA102 Azalia: DeviceId: 0x1aef. [ ] Found 1 controllers (DevId 127) [ ] SetAspm on GPU: 0x11030043 [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Found codec on sdin 0 [ ] mods [1]: set dma mask 47 for dev 0000:01:00.1 [ ] The codec contains 1 function group(s). [ ] PEX: set downstream ASPM=0xd1030043 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] DRAM info read from PreOS PBI not supported [ ] Failed to get DRAM information from VBIOS preOS PBI. Will attempt to read from the DRAM. [ ] NVRM: Child aperture crosses parent's boundary, length 925696 offset 0, Parent's length 0 [ ] NVRM: Child aperture crosses parent's boundary, length 1024 offset 0, Parent's length 0 [ ] Setup dma base only supported on PPC, skipping [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] Found (0, 0, 31, 4) with cc = 0xc0500, vid = 0x8086, did = 0xa123 [ ] INTEL - SMBus: DeviceId: 0xa123. [ ] Found 1 devices [ ] mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed [ ] func? polled 494 times in 25007 us on func? and returned 77. [ ] EC Device not found on Smbus [ ] ACPI: Unable to evaluate dev method _PR0, id 0xffffffff on 0000:00:01.0 [ ] mods [1] error: ACPI method _PR0 failed [ ] ata2: SATA link down (SStatus 0 SControl 300) [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: Unexpected versioning (00) encountered in XPIO specific table header # 3. Parsing stopped. [ ] GF100GpuSubdevice: FloorsweepingAffected=0 [ ] GF100GpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF100GpuSubdevice: Floorsweeping parameter mask values: display=0x0 msdec=0x0 msvld=0x0 fbio_shift_override=0x0 ce=0x0 gpc=0x0 fb=0x0 fbio=0x0 fbio_shift=0x0 gpctpc[0]=0x0 gpctpc[1]=0x0 gpctpc[2]=0x0 gpctpc[3]=0x0 gpctpc[4]=0x0 gpctpc[5]=0x0 gpctpc[6]=0x0 gpctpc[7]=0x0 gpczcull[0]=0x0 gpczcull[1]=0x0 gpczcull[2]=0x0 gpczcull[3]=0x0 gpczcull[4]=0x0 gpczcull[5]=0x0 gpczcull[6]=0x0 gpczcull[7]=0x0 [ ] GF108PlusGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF108PlusGpuSubdevice: Floorsweeping parameter mask values: pcie_lane=0x0 fbpa=0x0 spare=0x0 [ ] GM10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM10xGpuSubdevice: Floorsweeping parameter mask values: nvenc=0x0 nvdec=0x0 head=0x0 [ ] GM20xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM20xGpuSubdevice: Floorsweeping parameters mask values: fbp_ltc[0]=0x0 fbp_ltc[1]=0x0 fbp_ltc[2]=0x0 fbp_ltc[3]=0x0 fbp_ltc[4]=0x0 fbp_ltc[5]=0x0 fbp_ltc[6]=0x0 fbp_ltc[7]=0x0 fbp_ltc[8]=0x0 fbp_ltc[9]=0x0 fbp_ltc[10]=0x0 fbp_ltc[11]=0x0 fbp_ltc[12]=0x0 fbp_ltc[13]=0x0 fbp_ltc[14]=0x0 fbp_ltc[15]=0x0 [ ] GP10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GP10xGpuSubdevice: Floorsweeping parameters mask values: gpc_pes[0]=0x0 gpc_pes[1]=0x0 gpc_pes[2]=0x0 gpc_pes[3]=0x0 gpc_pes[4]=0x0 gpc_pes[5]=0x0 gpc_pes[6]=0x0 gpc_pes[7]=0x0 gpc_pes[8]=0x0 gpc_pes[9]=0x0 gpc_pes[10]=0x0 gpc_pes[11]=0x0 gpc_pes[12]=0x0 gpc_pes[13]=0x0 gpc_pes[14]=0x0 gpc_pes[15]=0x0 [ ] TU10x floorsweeping parameters present on commandline: [ ] TU10x floorsweeping parameter mask values: nvlink=0x0 [ ] AmpereFs : Floorsweeping parameters present on commandline: [ ] AmpereFs : Floorsweeping parameters mask values: [ ] _XGQlGpuSubdevice: Floorsweeping parameters present on commandline: _XGQlGpuSubdevice: Floorsweeping parameters mask values: gpc_rop[0]=0x0 gpc_rop[1]=0x0 gpc_rop[2]=0x0 gpc_rop[3]=0x0 gpc_rop[4]=0x0 gpc_rop[5]=0x0 gpc_rop[6]=0x0 gpc_rop[7]=0x0 gpc_rop[8]=0x0 gpc_rop[9]=0x0 gpc_rop[10]=0x0 gpc_rop[11]=0x0 gpc_rop[12]=0x0 gpc_rop[13]=0x0 gpc_rop[14]=0x0 gpc_rop[15]=0x0 [ ] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0 [ ] Unknown init property : FbGddr5x8Mode [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: IOCTRL not present in PTOP, NVLink is unavailable. [ ] NVRM: FECS override applied to FB LTC ECC [ ] NVRM: FECS override applied to FB DRAM ECC [ ] NVRM: BBX object get failed, status=0x57 [ ] Warning: Can't find Pci device with class code 0x30000, index 1 [ ] Warning: Can't find Pci device with class code 0x30200, index 0 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Warning: Can't find Pci device with class code 0x60000, index 1 [ ] Warning: Can't find Pci device with class code 0x60100, index 1 [ ] Warning: Can't find Pci device with class code 0x60200, index 0 [ ] Warning: Can't find Pci device with class code 0x60300, index 0 [ ] Warning: Can't find Pci device with class code 0x60400, index 3 [ ] Warning: Can't find Pci device with class code 0x60401, index 0 [ ] Warning: Can't find Pci device with class code 0x60500, index 0 [ ] Warning: Can't find Pci device with class code 0x60600, index 0 [ ] Warning: Can't find Pci device with class code 0x60700, index 0 [ ] Warning: Can't find Pci device with class code 0x60800, index 0 [ ] Warning: Can't find Pci device with class code 0x60940, index 0 [ ] Warning: Can't find Pci device with class code 0x60980, index 0 [ ] Warning: Can't find Pci device with class code 0x60a00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b01, index 0 [ ] Warning: Can't find Pci device with class code 0x68000, index 0 [ ] NVRM: *** Chipset Setup Function Error! [ ] NVRM: Almost all programmable domains must be included in the VBIOS clock domains. [ ] NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000 [ ] NVRM: Improperly fused GPU ADC code error deltas - skipping the update from fused values. [ ] NVRM: InfoROM PPO object header load failed, status=0x57 [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Not enabling straddling ctag support as platform is not Win10 [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | DDC port | Display Type | Pad Mask | Connected? | Display Mask (name) [ ] NVRM: ----------------------------------------------------------------------------------- [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: | 0x08 | DisplayPort | 0x00000020 | -- | 00002000 ( DFP-0 ). [ ] NVRM: | 0x08 | TMDS | 0x00000020 | -- | 00004000 ( DFP-1 ). [ ] NVRM: | 0x07 | DisplayPort | 0x00000010 | -- | 00000800 ( DFP-2 ). [ ] NVRM: | 0x07 | TMDS | 0x00000010 | -- | 00001000 ( DFP-3 ). [ ] NVRM: | 0x06 | DisplayPort | 0x00000008 | -- | 00000200 ( DFP-4 ). [ ] NVRM: | 0x06 | TMDS | 0x00000008 | -- | 00000400 ( DFP-5 ). [ ] NVRM: | 0x05 | TMDS | 0x00000004 | Yes | 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | Suggested (boot/resume) device(s): 00000100 ( DFP-6 ). [ ] NVRM: | Selecting as primary device: 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: GR binaries will be picked for netlist'0' [ ] NVRM: GR binaries will be picked for netlist'1' [ ] NVRM: GR binaries will be picked for netlist'2' [ ] NVRM: GR binaries will be picked for netlist'3' [ ] NVRM: Child aperture crosses parent's boundary, length 2097152 offset 4194304, Parent's length 0 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid PSI volt ramp down time in VBIOS. Disabling DI coupled PSI. [ ] NVRM: Invalid DI volt settle time in VBIOS. Disabling DI VOLTAGE_UPDATE. [ ] NVRM: OCT object load failed, status=0x57 [ ] NVRM: Breakpoint on RC Disable Override is disabled [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PCI-E device status errors pending (00000009): [ ] NVRM: Clearing these errors.. [ ] NVRM: PCI-E device AER errors pending (00200000): [ ] NVRM: Clearing these errors.. [ ] NVRM: Unable to read VBIOS temperature limits. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19. [ ] NVRM: OBJPMU Async: !Bootloader starting! [ ] NVRM: OBJPMU Async: Bootloader base: 0x606000027D0D7000 [ ] NVRM: OBJPMU Async: Booting... [ ] NVRM: OBJPMU Async: Initializing PMU application [ ] NVRM: OBJPMU Async: initPmuApp [ ] NVRM: Failed to map Logical port (1) to Physical I2C port! File a bug to investigate! [ ] NVRM: Failed to map L2P port for I2C device 0. [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019ae30a [ ] bp @ <fileid:0x0005e4>:745 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] First error recorded: 818 Mods detected an assertion failure [ ] JavaScript stack trace: [ ] #0: Initialize() in <native>:0 [ ] #1: InitializeGpuTests() in gputest.jse:341 [ ] #2: gputest_main() in gputest.jse:2227 [ ] #3: main() in gputest.jse:2164 [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019aea68 [ ] bp @ <fileid:0x0005e4>:888 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] NVRM: boardObjGrpPmuSet() returned error: status=0x00000040. [ ] NVRM: bp @ <fileid:0x00064f>:530 [ ] bp @ <fileid:0x00064f>:530 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP -------------------------- ERROR: bp @ <fileid:0x0005e4>:357
[ 0] ------------------------- BEGIN ASSERT INFO DUMP ------------------------- [ ] PCI Location : 0x00, 0x01, 0x00, 0x00 [ ] GPU DID : 0x2206 [ ] PDI : 0x80ff20c1972d46ee [ ] Raw ECID : 0x008016400000005d764921c4 [ ] Raw ECID (GHS) : 0x4705d76492000000019008100 [ ] ECID : SAMSUNG-SNNP98-25_x1_y4 [ ] Device Id : GA102 [ ] Revision : a1 [ ] Sub Revision : 1 [ ] NV Base : 0xde000000 [ ] FB Base : 0xc0000000 [ ] IRQ : 11 [ ] MSI-X not supported on GPU 0 [01:00.0], skipping [ ] Detected supported interrupt types: legacy MSI [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] Legacy interrupts verified OK [ ] mods [1]: enabled dev 0000:01:00.0 [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] MSI verified OK [ ] Skipping MSI-X verification [ ] Hooking MSI [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Bypassing unsupported vendor: 0x8086Device already uninitialized [ ] GA102 Azalia: DeviceId: 0x1aef. [ ] Found 1 controllers (DevId 127) [ ] SetAspm on GPU: 0x11030043 [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Found codec on sdin 0 [ ] mods [1]: set dma mask 47 for dev 0000:01:00.1 [ ] The codec contains 1 function group(s). [ ] PEX: set downstream ASPM=0xd1030043 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] DRAM info read from PreOS PBI not supported [ ] Failed to get DRAM information from VBIOS preOS PBI. Will attempt to read from the DRAM. [ ] NVRM: Child aperture crosses parent's boundary, length 925696 offset 0, Parent's length 0 [ ] NVRM: Child aperture crosses parent's boundary, length 1024 offset 0, Parent's length 0 [ ] Setup dma base only supported on PPC, skipping [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] Found (0, 0, 31, 4) with cc = 0xc0500, vid = 0x8086, did = 0xa123 [ ] INTEL - SMBus: DeviceId: 0xa123. [ ] Found 1 devices [ ] mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed [ ] func? polled 494 times in 25007 us on func? and returned 77. [ ] EC Device not found on Smbus [ ] ACPI: Unable to evaluate dev method _PR0, id 0xffffffff on 0000:00:01.0 [ ] mods [1] error: ACPI method _PR0 failed [ ] ata2: SATA link down (SStatus 0 SControl 300) [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: Unexpected versioning (00) encountered in XPIO specific table header # 3. Parsing stopped. [ ] GF100GpuSubdevice: FloorsweepingAffected=0 [ ] GF100GpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF100GpuSubdevice: Floorsweeping parameter mask values: display=0x0 msdec=0x0 msvld=0x0 fbio_shift_override=0x0 ce=0x0 gpc=0x0 fb=0x0 fbio=0x0 fbio_shift=0x0 gpctpc[0]=0x0 gpctpc[1]=0x0 gpctpc[2]=0x0 gpctpc[3]=0x0 gpctpc[4]=0x0 gpctpc[5]=0x0 gpctpc[6]=0x0 gpctpc[7]=0x0 gpczcull[0]=0x0 gpczcull[1]=0x0 gpczcull[2]=0x0 gpczcull[3]=0x0 gpczcull[4]=0x0 gpczcull[5]=0x0 gpczcull[6]=0x0 gpczcull[7]=0x0 [ ] GF108PlusGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF108PlusGpuSubdevice: Floorsweeping parameter mask values: pcie_lane=0x0 fbpa=0x0 spare=0x0 [ ] GM10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM10xGpuSubdevice: Floorsweeping parameter mask values: nvenc=0x0 nvdec=0x0 head=0x0 [ ] GM20xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM20xGpuSubdevice: Floorsweeping parameters mask values: fbp_ltc[0]=0x0 fbp_ltc[1]=0x0 fbp_ltc[2]=0x0 fbp_ltc[3]=0x0 fbp_ltc[4]=0x0 fbp_ltc[5]=0x0 fbp_ltc[6]=0x0 fbp_ltc[7]=0x0 fbp_ltc[8]=0x0 fbp_ltc[9]=0x0 fbp_ltc[10]=0x0 fbp_ltc[11]=0x0 fbp_ltc[12]=0x0 fbp_ltc[13]=0x0 fbp_ltc[14]=0x0 fbp_ltc[15]=0x0 [ ] GP10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GP10xGpuSubdevice: Floorsweeping parameters mask values: gpc_pes[0]=0x0 gpc_pes[1]=0x0 gpc_pes[2]=0x0 gpc_pes[3]=0x0 gpc_pes[4]=0x0 gpc_pes[5]=0x0 gpc_pes[6]=0x0 gpc_pes[7]=0x0 gpc_pes[8]=0x0 gpc_pes[9]=0x0 gpc_pes[10]=0x0 gpc_pes[11]=0x0 gpc_pes[12]=0x0 gpc_pes[13]=0x0 gpc_pes[14]=0x0 gpc_pes[15]=0x0 [ ] TU10x floorsweeping parameters present on commandline: [ ] TU10x floorsweeping parameter mask values: nvlink=0x0 [ ] AmpereFs : Floorsweeping parameters present on commandline: [ ] AmpereFs : Floorsweeping parameters mask values: [ ] _XGQlGpuSubdevice: Floorsweeping parameters present on commandline: _XGQlGpuSubdevice: Floorsweeping parameters mask values: gpc_rop[0]=0x0 gpc_rop[1]=0x0 gpc_rop[2]=0x0 gpc_rop[3]=0x0 gpc_rop[4]=0x0 gpc_rop[5]=0x0 gpc_rop[6]=0x0 gpc_rop[7]=0x0 gpc_rop[8]=0x0 gpc_rop[9]=0x0 gpc_rop[10]=0x0 gpc_rop[11]=0x0 gpc_rop[12]=0x0 gpc_rop[13]=0x0 gpc_rop[14]=0x0 gpc_rop[15]=0x0 [ ] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0 [ ] Unknown init property : FbGddr5x8Mode [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: IOCTRL not present in PTOP, NVLink is unavailable. [ ] NVRM: FECS override applied to FB LTC ECC [ ] NVRM: FECS override applied to FB DRAM ECC [ ] NVRM: BBX object get failed, status=0x57 [ ] Warning: Can't find Pci device with class code 0x30000, index 1 [ ] Warning: Can't find Pci device with class code 0x30200, index 0 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Warning: Can't find Pci device with class code 0x60000, index 1 [ ] Warning: Can't find Pci device with class code 0x60100, index 1 [ ] Warning: Can't find Pci device with class code 0x60200, index 0 [ ] Warning: Can't find Pci device with class code 0x60300, index 0 [ ] Warning: Can't find Pci device with class code 0x60400, index 3 [ ] Warning: Can't find Pci device with class code 0x60401, index 0 [ ] Warning: Can't find Pci device with class code 0x60500, index 0 [ ] Warning: Can't find Pci device with class code 0x60600, index 0 [ ] Warning: Can't find Pci device with class code 0x60700, index 0 [ ] Warning: Can't find Pci device with class code 0x60800, index 0 [ ] Warning: Can't find Pci device with class code 0x60940, index 0 [ ] Warning: Can't find Pci device with class code 0x60980, index 0 [ ] Warning: Can't find Pci device with class code 0x60a00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b01, index 0 [ ] Warning: Can't find Pci device with class code 0x68000, index 0 [ ] NVRM: *** Chipset Setup Function Error! [ ] NVRM: Almost all programmable domains must be included in the VBIOS clock domains. [ ] NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000 [ ] NVRM: Improperly fused GPU ADC code error deltas - skipping the update from fused values. [ ] NVRM: InfoROM PPO object header load failed, status=0x57 [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Not enabling straddling ctag support as platform is not Win10 [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | DDC port | Display Type | Pad Mask | Connected? | Display Mask (name) [ ] NVRM: ----------------------------------------------------------------------------------- [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: | 0x08 | DisplayPort | 0x00000020 | -- | 00002000 ( DFP-0 ). [ ] NVRM: | 0x08 | TMDS | 0x00000020 | -- | 00004000 ( DFP-1 ). [ ] NVRM: | 0x07 | DisplayPort | 0x00000010 | -- | 00000800 ( DFP-2 ). [ ] NVRM: | 0x07 | TMDS | 0x00000010 | -- | 00001000 ( DFP-3 ). [ ] NVRM: | 0x06 | DisplayPort | 0x00000008 | -- | 00000200 ( DFP-4 ). [ ] NVRM: | 0x06 | TMDS | 0x00000008 | -- | 00000400 ( DFP-5 ). [ ] NVRM: | 0x05 | TMDS | 0x00000004 | Yes | 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | Suggested (boot/resume) device(s): 00000100 ( DFP-6 ). [ ] NVRM: | Selecting as primary device: 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: GR binaries will be picked for netlist'0' [ ] NVRM: GR binaries will be picked for netlist'1' [ ] NVRM: GR binaries will be picked for netlist'2' [ ] NVRM: GR binaries will be picked for netlist'3' [ ] NVRM: Child aperture crosses parent's boundary, length 2097152 offset 4194304, Parent's length 0 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid PSI volt ramp down time in VBIOS. Disabling DI coupled PSI. [ ] NVRM: Invalid DI volt settle time in VBIOS. Disabling DI VOLTAGE_UPDATE. [ ] NVRM: OCT object load failed, status=0x57 [ ] NVRM: Breakpoint on RC Disable Override is disabled [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PCI-E device status errors pending (00000009): [ ] NVRM: Clearing these errors.. [ ] NVRM: PCI-E device AER errors pending (00200000): [ ] NVRM: Clearing these errors.. [ ] NVRM: Unable to read VBIOS temperature limits. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19. [ ] NVRM: OBJPMU Async: !Bootloader starting! [ ] NVRM: OBJPMU Async: Bootloader base: 0x606000027D0D7000 [ ] NVRM: OBJPMU Async: Booting... [ ] NVRM: OBJPMU Async: Initializing PMU application [ ] NVRM: OBJPMU Async: initPmuApp [ ] NVRM: Failed to map Logical port (1) to Physical I2C port! File a bug to investigate! [ ] NVRM: Failed to map L2P port for I2C device 0. [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019ae30a [ ] bp @ <fileid:0x0005e4>:745 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] First error recorded: 818 Mods detected an assertion failure [ ] JavaScript stack trace: [ ] #0: Initialize() in <native>:0 [ ] #1: InitializeGpuTests() in gputest.jse:341 [ ] #2: gputest_main() in gputest.jse:2227 [ ] #3: main() in gputest.jse:2164 [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019aea68 [ ] bp @ <fileid:0x0005e4>:888 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] NVRM: boardObjGrpPmuSet() returned error: status=0x00000040. [ ] NVRM: bp @ <fileid:0x00064f>:530 [ ] bp @ <fileid:0x00064f>:530 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019afa69 [ ] bp @ <fileid:0x0005e4>:357 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP -------------------------- ERROR: bp @ <fileid:0x000399>:467
[ 0] ------------------------- BEGIN ASSERT INFO DUMP ------------------------- [ ] Raw ECID (GHS) : 0x4705d76492000000019008100 [ ] ECID : SAMSUNG-SNNP98-25_x1_y4 [ ] Device Id : GA102 [ ] Revision : a1 [ ] Sub Revision : 1 [ ] NV Base : 0xde000000 [ ] FB Base : 0xc0000000 [ ] IRQ : 11 [ ] MSI-X not supported on GPU 0 [01:00.0], skipping [ ] Detected supported interrupt types: legacy MSI [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] Legacy interrupts verified OK [ ] mods [1]: enabled dev 0000:01:00.0 [ ] IRQ statistics: [ ] num IRQs: 10 [ ] avg IRQ delay: 0us [ ] min IRQ delay: 0us [ ] max IRQ delay: 0us [ ] MSI verified OK [ ] Skipping MSI-X verification [ ] Hooking MSI [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Bypassing unsupported vendor: 0x8086Device already uninitialized [ ] GA102 Azalia: DeviceId: 0x1aef. [ ] Found 1 controllers (DevId 127) [ ] SetAspm on GPU: 0x11030043 [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0. [ ] Found codec on sdin 0 [ ] mods [1]: set dma mask 47 for dev 0000:01:00.1 [ ] The codec contains 1 function group(s). [ ] PEX: set downstream ASPM=0xd1030043 [ ] [0000:01:00.0] cap id 0x10 found at offs 0x78 [ ] DRAM info read from PreOS PBI not supported [ ] Failed to get DRAM information from VBIOS preOS PBI. Will attempt to read from the DRAM. [ ] NVRM: Child aperture crosses parent's boundary, length 925696 offset 0, Parent's length 0 [ ] NVRM: Child aperture crosses parent's boundary, length 1024 offset 0, Parent's length 0 [ ] Setup dma base only supported on PPC, skipping [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] ACPI: Unable to evaluate dev method _DSM, id 0xffffffff on 0000:01:00.0 [ ] Found (0, 0, 31, 4) with cc = 0xc0500, vid = 0x8086, did = 0xa123 [ ] INTEL - SMBus: DeviceId: 0xa123. [ ] Found 1 devices [ ] mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed mods [1] error: ACPI method _DSM failed [ ] func? polled 494 times in 25007 us on func? and returned 77. [ ] EC Device not found on Smbus [ ] ACPI: Unable to evaluate dev method _PR0, id 0xffffffff on 0000:00:01.0 [ ] mods [1] error: ACPI method _PR0 failed [ ] ata2: SATA link down (SStatus 0 SControl 300) [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: Unexpected versioning (00) encountered in XPIO specific table header # 3. Parsing stopped. [ ] GF100GpuSubdevice: FloorsweepingAffected=0 [ ] GF100GpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF100GpuSubdevice: Floorsweeping parameter mask values: display=0x0 msdec=0x0 msvld=0x0 fbio_shift_override=0x0 ce=0x0 gpc=0x0 fb=0x0 fbio=0x0 fbio_shift=0x0 gpctpc[0]=0x0 gpctpc[1]=0x0 gpctpc[2]=0x0 gpctpc[3]=0x0 gpctpc[4]=0x0 gpctpc[5]=0x0 gpctpc[6]=0x0 gpctpc[7]=0x0 gpczcull[0]=0x0 gpczcull[1]=0x0 gpczcull[2]=0x0 gpczcull[3]=0x0 gpczcull[4]=0x0 gpczcull[5]=0x0 gpczcull[6]=0x0 gpczcull[7]=0x0 [ ] GF108PlusGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GF108PlusGpuSubdevice: Floorsweeping parameter mask values: pcie_lane=0x0 fbpa=0x0 spare=0x0 [ ] GM10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM10xGpuSubdevice: Floorsweeping parameter mask values: nvenc=0x0 nvdec=0x0 head=0x0 [ ] GM20xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GM20xGpuSubdevice: Floorsweeping parameters mask values: fbp_ltc[0]=0x0 fbp_ltc[1]=0x0 fbp_ltc[2]=0x0 fbp_ltc[3]=0x0 fbp_ltc[4]=0x0 fbp_ltc[5]=0x0 fbp_ltc[6]=0x0 fbp_ltc[7]=0x0 fbp_ltc[8]=0x0 fbp_ltc[9]=0x0 fbp_ltc[10]=0x0 fbp_ltc[11]=0x0 fbp_ltc[12]=0x0 fbp_ltc[13]=0x0 fbp_ltc[14]=0x0 fbp_ltc[15]=0x0 [ ] GP10xGpuSubdevice: Floorsweeping parameters present on commandline: [ ] GP10xGpuSubdevice: Floorsweeping parameters mask values: gpc_pes[0]=0x0 gpc_pes[1]=0x0 gpc_pes[2]=0x0 gpc_pes[3]=0x0 gpc_pes[4]=0x0 gpc_pes[5]=0x0 gpc_pes[6]=0x0 gpc_pes[7]=0x0 gpc_pes[8]=0x0 gpc_pes[9]=0x0 gpc_pes[10]=0x0 gpc_pes[11]=0x0 gpc_pes[12]=0x0 gpc_pes[13]=0x0 gpc_pes[14]=0x0 gpc_pes[15]=0x0 [ ] TU10x floorsweeping parameters present on commandline: [ ] TU10x floorsweeping parameter mask values: nvlink=0x0 [ ] AmpereFs : Floorsweeping parameters present on commandline: [ ] AmpereFs : Floorsweeping parameters mask values: [ ] _XGQlGpuSubdevice: Floorsweeping parameters present on commandline: _XGQlGpuSubdevice: Floorsweeping parameters mask values: gpc_rop[0]=0x0 gpc_rop[1]=0x0 gpc_rop[2]=0x0 gpc_rop[3]=0x0 gpc_rop[4]=0x0 gpc_rop[5]=0x0 gpc_rop[6]=0x0 gpc_rop[7]=0x0 gpc_rop[8]=0x0 gpc_rop[9]=0x0 gpc_rop[10]=0x0 gpc_rop[11]=0x0 gpc_rop[12]=0x0 gpc_rop[13]=0x0 gpc_rop[14]=0x0 gpc_rop[15]=0x0 [ ] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0 [ ] Unknown init property : FbGddr5x8Mode [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: IOCTRL not present in PTOP, NVLink is unavailable. [ ] NVRM: FECS override applied to FB LTC ECC [ ] NVRM: FECS override applied to FB DRAM ECC [ ] NVRM: BBX object get failed, status=0x57 [ ] Warning: Can't find Pci device with class code 0x30000, index 1 [ ] Warning: Can't find Pci device with class code 0x30200, index 0 [ ] Warning: Can't find Pci device with class code 0x40300, index 2 [ ] Warning: Can't find Pci device with class code 0x60000, index 1 [ ] Warning: Can't find Pci device with class code 0x60100, index 1 [ ] Warning: Can't find Pci device with class code 0x60200, index 0 [ ] Warning: Can't find Pci device with class code 0x60300, index 0 [ ] Warning: Can't find Pci device with class code 0x60400, index 3 [ ] Warning: Can't find Pci device with class code 0x60401, index 0 [ ] Warning: Can't find Pci device with class code 0x60500, index 0 [ ] Warning: Can't find Pci device with class code 0x60600, index 0 [ ] Warning: Can't find Pci device with class code 0x60700, index 0 [ ] Warning: Can't find Pci device with class code 0x60800, index 0 [ ] Warning: Can't find Pci device with class code 0x60940, index 0 [ ] Warning: Can't find Pci device with class code 0x60980, index 0 [ ] Warning: Can't find Pci device with class code 0x60a00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b00, index 0 [ ] Warning: Can't find Pci device with class code 0x60b01, index 0 [ ] Warning: Can't find Pci device with class code 0x68000, index 0 [ ] NVRM: *** Chipset Setup Function Error! [ ] NVRM: Almost all programmable domains must be included in the VBIOS clock domains. [ ] NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000 [ ] NVRM: Improperly fused GPU ADC code error deltas - skipping the update from fused values. [ ] NVRM: InfoROM PPO object header load failed, status=0x57 [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Failed to obtain perf table header! [ ] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ ] NVRM: Not enabling straddling ctag support as platform is not Win10 [ ] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | DDC port | Display Type | Pad Mask | Connected? | Display Mask (name) [ ] NVRM: ----------------------------------------------------------------------------------- [ ] mods [1] error: ACPI method _DOD failed [ ] NVRM: | 0x08 | DisplayPort | 0x00000020 | -- | 00002000 ( DFP-0 ). [ ] NVRM: | 0x08 | TMDS | 0x00000020 | -- | 00004000 ( DFP-1 ). [ ] NVRM: | 0x07 | DisplayPort | 0x00000010 | -- | 00000800 ( DFP-2 ). [ ] NVRM: | 0x07 | TMDS | 0x00000010 | -- | 00001000 ( DFP-3 ). [ ] NVRM: | 0x06 | DisplayPort | 0x00000008 | -- | 00000200 ( DFP-4 ). [ ] NVRM: | 0x06 | TMDS | 0x00000008 | -- | 00000400 ( DFP-5 ). [ ] NVRM: | 0x05 | TMDS | 0x00000004 | Yes | 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: | Suggested (boot/resume) device(s): 00000100 ( DFP-6 ). [ ] NVRM: | Selecting as primary device: 00000100 ( DFP-6 ). [ ] NVRM: ----------------------------------------------------------------------------------- [ ] NVRM: GR binaries will be picked for netlist'0' [ ] NVRM: GR binaries will be picked for netlist'1' [ ] NVRM: GR binaries will be picked for netlist'2' [ ] NVRM: GR binaries will be picked for netlist'3' [ ] NVRM: Child aperture crosses parent's boundary, length 2097152 offset 4194304, Parent's length 0 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid Client Id 15 [ ] NVRM: Invalid PSI volt ramp down time in VBIOS. Disabling DI coupled PSI. [ ] NVRM: Invalid DI volt settle time in VBIOS. Disabling DI VOLTAGE_UPDATE. [ ] NVRM: OCT object load failed, status=0x57 [ ] NVRM: Breakpoint on RC Disable Override is disabled [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PCI-E device status errors pending (00000009): [ ] NVRM: Clearing these errors.. [ ] NVRM: PCI-E device AER errors pending (00200000): [ ] NVRM: Clearing these errors.. [ ] NVRM: Unable to read VBIOS temperature limits. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ ] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19. [ ] NVRM: OBJPMU Async: !Bootloader starting! [ ] NVRM: OBJPMU Async: Bootloader base: 0x606000027D0D7000 [ ] NVRM: OBJPMU Async: Booting... [ ] NVRM: OBJPMU Async: Initializing PMU application [ ] NVRM: OBJPMU Async: initPmuApp [ ] NVRM: Failed to map Logical port (1) to Physical I2C port! File a bug to investigate! [ ] NVRM: Failed to map L2P port for I2C device 0. [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019ae30a [ ] bp @ <fileid:0x0005e4>:745 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] First error recorded: 818 Mods detected an assertion failure [ ] JavaScript stack trace: [ ] #0: Initialize() in <native>:0 [ ] #1: InitializeGpuTests() in gputest.jse:341 [ ] #2: gputest_main() in gputest.jse:2227 [ ] #3: main() in gputest.jse:2164 [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019aea68 [ ] bp @ <fileid:0x0005e4>:888 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] NVRM: boardObjGrpPmuSet() returned error: status=0x00000040. [ ] NVRM: bp @ <fileid:0x00064f>:530 [ ] bp @ <fileid:0x00064f>:530 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019afa69 [ ] bp @ <fileid:0x0005e4>:357 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ ] NVRM: Assertion failed: 0x0000000001ea3c75 [ ] bp @ <fileid:0x000399>:467 [ ] [ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP -------------------------- MODS is exiting with failure after assert #5. Breakpoint limit exceeded. Error 000000000818 : Global.IsTestModeCompute Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds]
Error 000000000818 : Global.JsonLogNvSwitches Mods detected an assertion failure [0.000 seconds] Error 000000000818 : Out.Flush Mods detected an assertion failure [0.000 seconds] Error 000000000818 : Global.PrintNvSwitchInfo Mods detected an assertion failure [0.001 seconds] Error 000000000818 : Global.RunFuncOnlyOnce Mods detected an assertion failure [0.002 seconds] Error 000000000818 : Global.VerifyErrorCode Mods detected an assertion failure [0.000 seconds]
Error Code = 000000000818 (Mods detected an assertion failure)
Error 000000000818 : Global.PrintErrors Mods detected an assertion failure [0.000 seconds] Error 000000000818 : Global.PrintVbiosStatus Mods detected an assertion failure [0.000 seconds] Error 000000000818 : Global.PrintGpuTestErrors Mods detected an assertion failure [0.000 seconds] ERROR: bp @ <fileid:0x00006c>:464 ERROR: Detected a recursive breakpoint while handling -exit_on_breakpoint. Aborting!!
[ 0] ------------------------- BEGIN ASSERT INFO DUMP ------------------------- [ 0] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0 [ 0] Unknown init property : FbGddr5x8Mode [ 0] mods [1] error: ACPI method _DOD failed [ 0] NVRM: IOCTRL not present in PTOP, NVLink is unavailable. [ 0] NVRM: FECS override applied to FB LTC ECC [ 0] NVRM: FECS override applied to FB DRAM ECC [ 0] NVRM: BBX object get failed, status=0x57 [ 0] Warning: Can't find Pci device with class code 0x30000, index 1 [ 0] Warning: Can't find Pci device with class code 0x30200, index 0 [ 0] Warning: Can't find Pci device with class code 0x40300, index 2 [ 0] Warning: Can't find Pci device with class code 0x60000, index 1 [ 0] Warning: Can't find Pci device with class code 0x60100, index 1 [ 0] Warning: Can't find Pci device with class code 0x60200, index 0 [ 0] Warning: Can't find Pci device with class code 0x60300, index 0 [ 0] Warning: Can't find Pci device with class code 0x60400, index 3 [ 0] Warning: Can't find Pci device with class code 0x60401, index 0 [ 0] Warning: Can't find Pci device with class code 0x60500, index 0 [ 0] Warning: Can't find Pci device with class code 0x60600, index 0 [ 0] Warning: Can't find Pci device with class code 0x60700, index 0 [ 0] Warning: Can't find Pci device with class code 0x60800, index 0 [ 0] Warning: Can't find Pci device with class code 0x60940, index 0 [ 0] Warning: Can't find Pci device with class code 0x60980, index 0 [ 0] Warning: Can't find Pci device with class code 0x60a00, index 0 [ 0] Warning: Can't find Pci device with class code 0x60b00, index 0 [ 0] Warning: Can't find Pci device with class code 0x60b01, index 0 [ 0] Warning: Can't find Pci device with class code 0x68000, index 0 [ 0] NVRM: *** Chipset Setup Function Error! [ 0] NVRM: Almost all programmable domains must be included in the VBIOS clock domains. [ 0] NVRM: VBIOS clock domains: 0x041800fe Programmable domains: 0x07d800fe Bad domains: 0x03c00000 [ 0] NVRM: Improperly fused GPU ADC code error deltas - skipping the update from fused values. [ 0] NVRM: InfoROM PPO object header load failed, status=0x57 [ 0] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ 0] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ 0] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ 0] NVRM: Failed to obtain perf table header! [ 0] NVRM: Failed to obtain perf table header! [ 0] NVRM: Failed to obtain perf table header! [ 0] NVRM: Using Clocks 2.x to read read-only utilsclk clock domain 18. [ 0] NVRM: Not enabling straddling ctag support as platform is not Win10 [ 0] ACPI: Unable to evaluate dev method _DOD, id 0xffffffff on 0000:01:00.0 [ 0] NVRM: ----------------------------------------------------------------------------------- [ 0] NVRM: | DDC port | Display Type | Pad Mask | Connected? | Display Mask (name) [ 0] NVRM: ----------------------------------------------------------------------------------- [ 0] mods [1] error: ACPI method _DOD failed [ 0] NVRM: | 0x08 | DisplayPort | 0x00000020 | -- | 00002000 ( DFP-0 ). [ 0] NVRM: | 0x08 | TMDS | 0x00000020 | -- | 00004000 ( DFP-1 ). [ 0] NVRM: | 0x07 | DisplayPort | 0x00000010 | -- | 00000800 ( DFP-2 ). [ 0] NVRM: | 0x07 | TMDS | 0x00000010 | -- | 00001000 ( DFP-3 ). [ 0] NVRM: | 0x06 | DisplayPort | 0x00000008 | -- | 00000200 ( DFP-4 ). [ 0] NVRM: | 0x06 | TMDS | 0x00000008 | -- | 00000400 ( DFP-5 ). [ 0] NVRM: | 0x05 | TMDS | 0x00000004 | Yes | 00000100 ( DFP-6 ). [ 0] NVRM: ----------------------------------------------------------------------------------- [ 0] NVRM: | Suggested (boot/resume) device(s): 00000100 ( DFP-6 ). [ 0] NVRM: | Selecting as primary device: 00000100 ( DFP-6 ). [ 0] NVRM: ----------------------------------------------------------------------------------- [ 0] NVRM: GR binaries will be picked for netlist'0' [ 0] NVRM: GR binaries will be picked for netlist'1' [ 0] NVRM: GR binaries will be picked for netlist'2' [ 0] NVRM: GR binaries will be picked for netlist'3' [ 0] NVRM: Child aperture crosses parent's boundary, length 2097152 offset 4194304, Parent's length 0 [ 0] NVRM: Invalid Client Id 15 [ 0] NVRM: Invalid Client Id 15 [ 0] NVRM: Invalid Client Id 15 [ 0] NVRM: Invalid Client Id 15 [ 0] NVRM: Invalid Client Id 15 [ 0] NVRM: Invalid PSI volt ramp down time in VBIOS. Disabling DI coupled PSI. [ 0] NVRM: Invalid DI volt settle time in VBIOS. Disabling DI VOLTAGE_UPDATE. [ 0] NVRM: OCT object load failed, status=0x57 [ 0] NVRM: Breakpoint on RC Disable Override is disabled [ 0] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ 0] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ 0] NVRM: PCI-E device status errors pending (00000009): [ 0] NVRM: Clearing these errors.. [ 0] NVRM: PCI-E device AER errors pending (00200000): [ 0] NVRM: Clearing these errors.. [ 0] NVRM: Unable to read VBIOS temperature limits. [ 0] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ 0] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller. [ 0] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19. [ 0] NVRM: OBJPMU Async: !Bootloader starting! [ 0] NVRM: OBJPMU Async: Bootloader base: 0x606000027D0D7000 [ 0] NVRM: OBJPMU Async: Booting... [ 0] NVRM: OBJPMU Async: Initializing PMU application [ 0] NVRM: OBJPMU Async: initPmuApp [ 0] NVRM: Failed to map Logical port (1) to Physical I2C port! File a bug to investigate! [ 0] NVRM: Failed to map L2P port for I2C device 0. [ 0] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019ae30a [ 0] bp @ <fileid:0x0005e4>:745 [ 0] [ 0] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ 0] First error recorded: 818 Mods detected an assertion failure [ 0] JavaScript stack trace: [ 0] #0: Initialize() in <native>:0 [ 0] #1: InitializeGpuTests() in gputest.jse:341 [ 0] #2: gputest_main() in gputest.jse:2227 [ 0] #3: main() in gputest.jse:2164 [ 0] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019aea68 [ 0] bp @ <fileid:0x0005e4>:888 [ 0] [ 0] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ 0] NVRM: boardObjGrpPmuSet() returned error: status=0x00000040. [ 0] NVRM: bp @ <fileid:0x00064f>:530 [ 0] bp @ <fileid:0x00064f>:530 [ 0] [ 0] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ 0] NVRM: Assertion failed: Generic Error: Invalid state [NV_ERR_INVALID_STATE] (0x00000040) returned from 0x00000000019afa69 [ 0] bp @ <fileid:0x0005e4>:357 [ 0] [ 0] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ 0] NVRM: Assertion failed: 0x0000000001ea3c75 [ 0] bp @ <fileid:0x000399>:467 [ 0] [ 0] ** ModsDrvBreakPoint on GPU 0 [01:00.0] ** [ 0] MODS is exiting with failure after assert #5. Breakpoint limit exceeded. [ 0] Error 000000000818 : Global.IsTestModeCompute Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : GPU 0 [01:00.0] Mods detected an assertion failure [0.000 seconds] [ 0] [ 0] Error 000000000818 : Global.JsonLogNvSwitches Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : Out.Flush Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : Global.PrintNvSwitchInfo Mods detected an assertion failure [0.001 seconds] [ 0] Error 000000000818 : Global.RunFuncOnlyOnce Mods detected an assertion failure [0.002 seconds] [ 0] Error 000000000818 : Global.VerifyErrorCode Mods detected an assertion failure [0.000 seconds] [ 0] Error Code = 000000000818 (Mods detected an assertion failure) [ 0] [ 0] ####### #### ######## ### ####### ###### ######## ### ## ## ## ## ### ## ## ## ## ### ####### ######## ## ### ####### ######## ## ### ## ## ## ## ### ## ## ## ######## ######## ## ## ## ######## ######## [ 0] [ 0] Error 000000000818 : Global.PrintErrors Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : Global.PrintVbiosStatus Mods detected an assertion failure [0.000 seconds] [ 0] Error 000000000818 : Global.PrintGpuTestErrors Mods detected an assertion failure [0.000 seconds] [ 0] Beginning GPU shut down [ 0] Shutdown : GPU devices not initialized, skipping GPU nvlink shutdown [ 0] IRQ statistics: [ 0] num IRQs: 0 [ 0] NVRM: Assertion failed: 0x00000000018ef2fd [ 0] bp @ <fileid:0x00006c>:464 [ 0] Detected a recursive breakpoint while handling -exit_on_breakpoint. Aborting!!
[ 0] -------------------------- END ASSERT INFO DUMP -------------------------- ----------call stack----------
Thread 7 (LWP 4539): #0 0x00007fc9ef2307a2 in ?? () #1 0x0000000000000090 in ?? () #2 0x0000000000000000 in ?? ()
Thread 6 (LWP 4534): #0 0x00007fc9ef2304b5 in ?? () #1 0x0000000000000000 in ?? ()
Thread 5 (LWP 4533): #0 0x00007fc9ef0aeb7f in ?? () #1 0x00000000ffffffff in ?? () #2 0x00007fc9d77f97c0 in ?? () #3 0x0000000000000002 in ?? () #4 0xffffffff0ae26120 in ?? () #5 0x0000000000586ca0 in ?? () #6 0x0000000000586d29 in ?? () #7 0x000000000ae26120 in ?? () #8 0x000000000ae26120 in ?? () #9 0x0000000100000003 in ?? () #10 0x0000000100000004 in ?? () #11 0x00007fc9cc000c10 in ?? () #12 0x0000000000000000 in ?? ()
Thread 4 (LWP 4532): #0 0x00007fc9ef2304b5 in ?? () #1 0x000000000000000a in ?? () #2 0x0000000000000000 in ?? ()
Thread 3 (LWP 4531): #0 0x00007fc9ef2304b5 in ?? () #1 0x000000000000048c in ?? () from /lib64/ld-linux-x86-64.so.2 #2 0x0000000000000000 in ?? ()
Thread 2 (LWP 4530): #0 0x00007fc9ef2304b5 in ?? () #1 0x000000000000007f in ?? () #2 0x0000000000000001 in ?? () #3 0x0000000000000004 in ?? () #4 0x00007fc9e57f56f0 in ?? () #5 0x00000000000000ff in ?? () #6 0x0000000000000000 in ?? ()
Thread 1 (LWP 4412): #0 0x00007fc9ef088177 in ?? () #1 0x00007fc9ef223dd8 in ?? () #2 0x00007ffe657966c8 in ?? () #3 0x00000000000011bd in ?? () from /lib64/ld-linux-x86-64.so.2 #4 0x00007fc9ef13f480 in ?? () #5 0x00000000000011bd in ?? () from /lib64/ld-linux-x86-64.so.2 #6 0x00007ffe657966d0 in ?? () #7 0x0000000000000000 in ?? ()
----------call stack---------- ---------- Добавлено спустя 1 минуту 24 секунды: ---------- madking можете подсказать куда смотреть
