Текущее время: 09 май 2024, 07:32
 Заголовок сообщения: Dell Inspiron 1564 (DAUM3BMB6E0 REV.E) Power button voltage drop
СообщениеДобавлено: 28 дек 2023, 05:26
Hello everyone..
this board came with the symptoms of it turns on automatically then goes off, checked and found there was a little flood in the area of C302 witch was shorted, cleaned and restored and there is still an auto-start when charger is connected, all voltages rises and there is full initialization then it goes off, all in 5 seconds..
RTC checked and battery replaced, power button checked and there is 5v that goes to zero when pressed..
checked SYS_PWR_SW# signal and there was only 0.75v, resistance to ground at IT8502E pin 125 is 100 ohms
didn't find IT8502E in the donors so replaced with IT8512E, resistance at pin 125 became 90k ohms and voltage = 1v (there is a spike to 2.4v for half a second when connecting the charger then it drops to 1v) it goes to 0.2v when pressing the button...
removing the button has no change..
replaced the 100K pull-up resistor R301 twice, still 3.2v on side and 1v on the other
replaced everything at the power button (C386, R304, D30 & D31)
replaced 32khz W2 quartz
bios and ec flashed
still auto-starts with full initialize for 5 seconds then off, not wondering why with that 1v at SYS_PWR_SW#
at Q17, Q21, Q22, ACAV_IN & ALW_ON & 3.3V_ALW_ON all signals are there = 3.2v
at IT8512E all voltages are there (+RTC_CELL, +3.3V_RUN, +3.3V_ALW) = 3.2v
the resistance of +3.3V_SUS line is only 97 ohms, but the consumption is only 100mv@3.3v with the LBP and it rises to 3.2v normally...
at IT8512E pin 125 SYS_PWR_SW#, resistance to ground with removed R301 & D31 became mega ohms...
R301 to pin 125 continuity = 1.7 ohms :du_ma_et:
What kind of a ghost sits in there ?? :ps_ih:
 Заголовок сообщения: Re: Dell Inspiron 1564 (DAUM3BMB6E0 REV.E) Power button voltage drop
СообщениеДобавлено: 28 дек 2023, 22:32
While I'm writing those lines I stopped at this point:
I've asked myself why ? there should be zero ohms :du_ma_et:
is it possible that the line is rotten ? the answer is yes...
the line goes in the interlayer under C302 witch was found boiling and it definitely damaged the trace, soldered a wire bridge between R301 & pin 125 and the resistance became 0.2 ohms, 3.3v appeared and the board started to switch on & off from the button normally, auto-start gone also :co_ol:
thank you, closing...
В этой теме нет новых непрочитанных сообщений. Inspiron 1564 (DAUM3BMB6E0 REV:E REV:A00) Постепенно перестал подавать признаки жизни
в форуме Dell
Civ1
08 май 2018, 01:00
foton73 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. inspiron 1564 (daum3bmb6e0 rev. e) нет запуска
в форуме Dell
vital_d77
01 мар 2018, 16:36
В этой теме нет новых непрочитанных сообщений. inspiron 1564 (daum3bmb6e0 rev e) не стартует
в форуме Dell
BacR
05 апр 2018, 16:19
BacR Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Inspiron N5110 (DELL) once i press power button it keeping restart without showing data
в форуме Dell
omex
09 июн 2014, 07:48
В этой теме нет новых непрочитанных сообщений. Asus k53d (k53sd rev:2.2) no green light on power button
bokin021
26 сен 2020, 12:37
bokin021 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
