Текущее время: 02 июн 2024, 23:23
 Заголовок сообщения: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7
СообщениеДобавлено: 06 янв 2024, 16:24
2 одинаковых по составу микросхем SSD.
Но в одном данные rtl_flash_id:
v0.15a
Drive: 0(ATA)
OS: 6.1 build 7601 Service Pack 1
ATA: SmartEnable failed! Error: 0x51
ATA: Identify failed! Error: 0x51
Model: REALTEK_RL6531
Fw : 3.AAE
Size : 1 MB [0.0 GB]
FwStr: [REALTEK_RL6531]
ATA: Get FWI failed! Error: 0x51
Bank00: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank01: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank02: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank03: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank04: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank08: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank09: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank12: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank13: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Flash CE Mask : [++++-+++ -+++++++]
а в другом данные rtl_flash_id:
v0.15a
Drive: 0(ATA)
Fw : 3.AAE
Bank00: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank01: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank04: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank05: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank08: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank09: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank12: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank13: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Flash CE Mask : [++--++-- ++--++--]
вопрос:
как определить где правильная информация и как восстановить (привести до правильной) неверный SSD.
или возможен вариант что под одинаковым названием китайцы спрятали разные микросхемы?
---------- Добавлено спустя 1 час 3 минуты 7 секунд: ----------
на всякий случай добавлю фото.
 Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7
СообщениеДобавлено: 06 янв 2024, 18:00
Сам мптул выдаст фид при включении диска в ром мод .
Подобрать прошивку и главное это посмотреть количество бэдов каждом чипе .
Иначе это мусор .
СообщениеДобавлено: 07 янв 2024, 11:34
мптул при автодетекте выдает такую же информацию (В17А и В27А).
но форматирование памяти не проводит - доходит только до Do LLF - и через некоторое время выскакивает ошибка - время закончилось.
вот и возник вопрос о различии и достоверности информации о микросхемах
СообщениеДобавлено: 07 янв 2024, 17:05
Покажи скрин мптула .
нанды одинаковые на фото , если оно родное .
СообщениеДобавлено: 10 янв 2024, 21:36
фото оригинальное.
а что может сказать MPTool дополнительно ?
СообщениеДобавлено: 18 янв 2024, 15:37
может есть какой совет? в каком направлении двигаться?
СообщениеДобавлено: 18 янв 2024, 16:37
Valery_ писал(а):
фото оригинальное.
Диски в ром переведены ?
СообщениеДобавлено: 18 янв 2024, 21:07
извиняюсь за дилетантский вопрос:
а как узнать что устройство перешло в режим Rom Mode?
что с перемычкой,что без- комп определяет устройство как Realtek RL6531 ATA Device.
подключаю через e-SATA.
СообщениеДобавлено: 19 янв 2024, 10:34
Подключи через sata-usb мост .
В мптуле сделай стирание с галками clear mode и dl mode . Это удалит старую инфу .
Переподключить диск и далее автодетект определит нанды .
СообщениеДобавлено: 20 янв 2024, 14:50
подключенные через SATA-USB(2 разных) не опознаются Mptool
пробовал через e-SATA- Clear проходит,но при повторном подключении опознаются так же криво.
СообщениеДобавлено: 21 янв 2024, 11:20
https://aliexpress.ru/item/100500440356 ... 3280hosDwT
СообщениеДобавлено: 27 янв 2024, 16:50
в этом адаптере какой-то специфический контроллер?
нашел адаптер в котором компьютер увидел SSD, но мптул устройство не нашел и flash_id микросхемы не увидел.
v0.15a
Drive: 1(USB)
Fw : 3.AAE
Flash CE Mask : [-------- --------]
Banks : 0
Channel : 0
CE : 0
Die/CE : 0
Plane : 0
Block/Die : 0
Page/Block : 0
Sect/Page : 0
FullPageSize: 0
MaxCapacity : 0
MaxPECycle : 0
SharedPages : 0
GCFreeLimit : 0
Fabric Bad block list (bank0 only):
Later Bad block list (bank0 only):
Bank0 BB (Fabric+Later): 0 (0+0)
В этой теме нет новых непрочитанных сообщений. Помогите прошить Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB2LBATM7 Micron 64L (B17A)
в форуме Ремонт SSD | SSD repair and data recovery
Legan
28
3960
16 фев 2024, 21:27
Motq Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Kingson ssd sata 256 (fake) стал read only
Монтер65
15 апр 2024, 22:24
Монтер65 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Восстановление данных с ADATA SU650 RTS5733DL
Xellbadgrumer
21 май 2024, 08:43
Xellbadgrumer Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. W25Q64FVSIG из Partsdirect fake или кривые руки?)
vampirekiller
3822
03 июн 2017, 12:14
Size Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. FAKE FLUX
erhanzeynel
22 июл 2017, 12:20
Сейчас этот форум просматривают: BMA и гости: 0
