Текущее время: 03 май 2024, 09:34
Duiesel
Заголовок сообщения: Re: A1286 logic board issue Добавлено: 27 июн 2013, 12:37 |
Зарегистрирован: 21 ноя 2012, 01:30 Наличности на руках: 51.02
Сообщения: 66 Откуда: Moscow
Hi Check all the board for the oxides damage. Then if you find some damaged signal or power lines-reair it. If no, clean it well and I thing everything will be OK.
zsibvasaros69
Заголовок сообщения: Re: A1286 logic board issue Добавлено: 28 июн 2013, 12:26 |
Зарегистрирован: 20 мар 2013, 11:51 Наличности на руках: 14.00
Duiesel писал(а): Hi Check all the board for the oxides damage. Then if you find some damaged signal or power lines-reair it. If no, clean it well and I thing everything will be OK. Hi Duiesel, I've cleaned the oxides damage, but it hasn't been good yet. I think it may be a bios problem, or not? I don't understand the code, because Apple didin't present firmware restoration CD for this type. But what does the code mean?
zsibvasaros69
Заголовок сообщения: Re: A1286 logic board issue Добавлено: 10 июл 2013, 11:12 |
Alex White писал(а): First of all, double check the board for oxidation. I use these two: http://www.radioshack.com/product/index ... Id=2104746http://www.yaotek.com/store/ProClean-Fl ... P1908.aspxWeird enough, these two in combo proved to clean off oxidation pretty well. Then, try to read the EFI chip (I believe it's SST25VF032B) with a programmer (SP8-B) and verify it against a working dump (bunch of them here, ex: viewtopic.php?f=51&t=6547&p=65107&hilit=%2A820+2330+A%2A#p65107). PS: Don't forget to change the board code in the EFI hex dump to yours before erasing and programming :)) (It's all the way at the end of the dump, the 17 digit ID) Good luck! Thank you! I checked these cleaners, but I can't buy in my country, I can order abroad these, but it will be very expensive. :( I use PCC and isopropil alcohol for cleaning, I think these are good alternatives for yours. So I have cleaned the board more times, but nothing happened. After I bought SPI programmer and I tried rewrite the EFI bios, but logic board doesn't work with the new dump. This is a mysterious fault for me. Maybe are the GPU, CPU or integrated RAM wrong?
dany_l2003
Заголовок сообщения: Re: A1286 logic board issue Добавлено: 03 окт 2013, 10:41 |
Зарегистрирован: 06 авг 2013, 17:30 Наличности на руках: 101.10
Сообщения: 52 Откуда: Romania
Попробуйте прошивку для восстановления CD здесь: http://support.apple.com/kb/HT2213Имеет ли значение, если оно имеет Рами? звуковой картины что-то изменить? Напряжение 3,4 V на флэш SST25VF ... ?
