Текущее время: 04 май 2024, 00:59
 Заголовок сообщения: Lumix TZ-1
СообщениеДобавлено: 23 янв 2011, 23:45
Hi!
I had a problem with sand clogged TZ-1 lens. After clearing and applying thin film of lubricant
thev move smooth, but camera shut downs after 17 seconds.
I suppose some adjustment initialization procedure has to be taken...
Any ideas?
Thanks!
 Заголовок сообщения: Re: Lumix TZ-1
СообщениеДобавлено: 09 фев 2011, 13:23
Hi!
Most likely you it is bad почители a lens from sand. I advise once again to disassemble a lens and to clear of sand!
Good luck!
СообщениеДобавлено: 14 фев 2011, 11:09
Hi,
Thanks for idea, but in fact I clear lens more than 3 times - same result :ne_vi_del:
BR
СообщениеДобавлено: 14 фев 2011, 18:12
it is possible that mechanics have been disturbed, it is necessary to rearrange to the initial position.
СообщениеДобавлено: 17 фев 2011, 13:10
Yes, that is what I am looking for - HOW to rearrange initial position.
I am sure lens are assembled OK, but there must be some service routine - maybe with software or
pressing combination of buttons..
Advices are welcome!
СообщениеДобавлено: 18 фев 2011, 14:56
Without experience it is difficult...
Go to the authorized service the center!
Good luck!
