toshiba l450 no voltage on the B + also no 5valwP or 3.3v i change PQ7 (AO4407A) and all voltages - 5v is ok, 3.3v is ok and when i press power switch all voltage are ok 1.05v ok 1.5v ram is ok but just stay for a few seconds and turn off to 0v. i can not detect the problem i need help please.
RsM
Заголовок сообщения: Re: Toshiba satellite l450-171 (LA-5822P) Turns off after a few seconds
Добавлено: 31 июл 2013, 21:18
Зарегистрирован: 12 окт 2012, 21:53 Наличности на руках: 5,126.83 Сообщения: 8282 Откуда: Сыктывкар
Some other voltages not to bring up/ some PWM ic may be dead. Check other voltages, PGood signals. (oscilloscope)
robertevoula
Сейчас этот форум просматривают: deletc и гости: 8
