Текущее время: 18 май 2024, 16:36
 Заголовок сообщения: ECS AMD690M-M2 rev1.0A only works if you put the battery in the socket 3V CMOS
СообщениеДобавлено: 03 сен 2013, 21:54
If the cmos battery is not in socket the motherboard will not turn on and also the diagnostic card is all erased.
If it is abnormal, where you may be the fault?
 Заголовок сообщения: Re: ECS AMD690M-M2 rev1.0A only works if you put the battery in the socket 3V CMOS
СообщениеДобавлено: 03 сен 2013, 23:19
Replace the PSU for known-working-ok, and check the standby (green wire with +5) voltage first. Does the system boot? What does POST-card show while the CMOS battery is in? What sound signals do you hear? Give us more information and you'll get the answer. Best regards.
СообщениеДобавлено: 04 сен 2013, 05:48
I tried to replace the power supply for a stronger repair and that did not change anything.
Continues running the motherboard only when I put the cmos battery in place
The green power supply is 5V
СообщениеДобавлено: 20 сен 2013, 03:32
I think that this model of motherboard is one that has to work to have the battery in the socket 3v cmos. I put the battery in place and the addition of the motherboard work she usually entered in the bios setup. If I am not wrong I can conclude that the motherboard had no defect was only put the battery into the socket and ready ....
The positive battery terminal is the signal that goes to the VBAT pin E1 signal I / O component whose code is (U18A)
If that's right, I can conclude that this topic is complete
В этой теме нет новых непрочитанных сообщений. Sarphie Radeon RX 560 Pulse 4GB (works only 3GB)
Micchaleq
27 июл 2018, 13:19
kolyandex Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gainward RTX3070 only works with AMD Mainboard/CPU
Dance0fArrows
737
10 сен 2023, 00:30
Opacky Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Socket G2 Discrete only. Возможно ли?
в форуме temp
RomanLV
08 май 2019, 11:42
RomanLV Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Vostro 3500 (Wistron DW50 Winery15) Starts by itself when put on charger, restarts after aprox. 10 second
в форуме Dell
gligurski
20 сен 2018, 18:25
gligurski Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
