Текущее время: 02 июн 2024, 17:32
 Заголовок сообщения: Recomend me good software for copy files
СообщениеДобавлено: 26 сен 2013, 20:05
right now im using teracopy.. since 1pm until now copy just 50%
i make 30gb of file copy to external hdd.8 hours for 30gb. yeah im using usb 2.0.. its normal?
winXP -core2 duo -4gb ram
 Заголовок сообщения: Re: Recomend me good software for copy files
СообщениеДобавлено: 26 сен 2013, 21:00
Show model of a hard disk and show its SMART.
Профессиональное восстановление данных и ремонт HDD на PC3000-UDMA, PC3000-Express+SSD, DataExtractor (RE).
СообщениеДобавлено: 28 сен 2013, 17:26
WDC WD10 EARS-00MVWB0 SATA Disk Device (1000 GB, SATA-II)
and smart
ID Attribute Description Threshold Value Worst Data Status
01 Raw Read Error Rate 51 200 200 0 OK: Value is normal
03 Spinup Time 21 167 164 6616 OK: Value is normal
04 Start/Stop Count 0 100 100 339 OK: Always passes
05 Reallocated Sector Count 140 200 200 0 OK: Value is normal
07 Seek Error Rate 0 200 200 0 OK: Always passes
09 Power-On Time Count 0 100 100 446 OK: Always passes
0A Spinup Retry Count 0 100 100 0 OK: Always passes
0B Calibration Retry Count 0 100 100 0 OK: Always passes
0C Power Cycle Count 0 100 100 192 OK: Always passes
C0 Power-Off Retract Count 0 200 200 100 OK: Always passes
C1 Load/Unload Cycle Count 0 198 198 6998 OK: Always passes
C2 Temperature 0 119 107 31 OK: Always passes
C4 Reallocation Event Count 0 200 200 0 OK: Always passes
C5 Current Pending Sector Count 0 200 200 0 OK: Always passes
C6 Offline Uncorrectable Sector Count 0 200 200 0 OK: Always passes
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passes
C8 Write Error Rate 0 200 200 0 OK: Always passes
Thanks.. :-):
СообщениеДобавлено: 28 сен 2013, 21:25
For example PC-3000 DiskAnalyzer, Ver1.02 or WinHex, DMDE.
СообщениеДобавлено: 25 окт 2013, 18:33
PC-3000 is a very good one, thou expensive.
СообщениеДобавлено: 04 ноя 2013, 19:20
Try fast copy > http://ipmsg.org/tools/fastcopy.html.en
В этой теме нет новых непрочитанных сообщений. hp 200 g4 21.5 all on 1 (dan14bmb6e0) the bios recovery files cannot be found or the files are corrupted hp
grey3129
02 окт 2021, 17:35
XIM888 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Good software
в форуме Samsung
alfa777
28 ноя 2015, 05:58
alfa777 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. *.brd files
andromedax
13 июл 2015, 12:26
andromedax Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. I need to recover files pendriver
eletmoraes
09 авг 2015, 00:19
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. .brd files (Apple) boardview
в форуме Apple
andromedax
22 ноя 2015, 00:07
