Текущее время: 28 апр 2024, 13:41
 Заголовок сообщения: TOSHIBA SAT M40-307 (6050A2028701-MB-A03 ) power cycle with no display
СообщениеДобавлено: 12 ноя 2013, 22:50
Hi everyone in the forum!
I'm a new member to this forum and need help as where to dig ?
I'm repairing 2 Toshiba laps with power on cycling symptoms and no display.
Bios is phoenix.
Post card reading jumps directly from 00 to 86 and back cycle.
Current reading rises to 1.1V and down to 0V in a cycle of 6 times then lap shuts down.
Thanks
 Заголовок сообщения: Re: TOSHIBA SAT M40-307 (6050A2028701-MB-A03 ) power cycle with no display
СообщениеДобавлено: 17 ноя 2013, 16:51
Hi everyone!
P.S read in my previous post : Current ....1.1A and down to 0A
It seems that no one encountered the same problem !!!
I'm still waiting for your comment.
Thank you for any advice. as where to dig ???
СообщениеДобавлено: 18 ноя 2013, 07:17
have your boards is video chips? possible, problem in video. but befor you can firmware bios flash.
2d-replace bridge.
СообщениеДобавлено: 18 ноя 2013, 15:32
2d-replace bridge.
hi "tvios"!
Toshiba M40-307 intel based, has a GMCH chip. I reflowed it once with no result, I'll try a 2nd reflow and revert.
Unfortunately, I can't flash bios, as lap is rebooting, and I'm not equipped with a bios programmer.
СообщениеДобавлено: 19 ноя 2013, 07:38
you need to buy programmer.
have cheap programmer: http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
and buy bridge for replace.
and what you have of equipment for soldering and testing?
СообщениеДобавлено: 19 ноя 2013, 15:24
Besides multi-meter Excel DT9205A, I have Metrix mts 3352 100MHZ-Oscilloscope, Smart tweezers for auto-measurement of
L-C-R, Atlas ESR meter... a soldering station and a BGA infra-red station newly acquired.
СообщениеДобавлено: 20 ноя 2013, 12:06
I think that the problem in the bridge. you try replace bridge? (no reball.)
В этой теме нет новых непрочитанных сообщений. toshiba sat r630 (fulsy4) power on password
в форуме Toshiba
kjayachandran4
15 июл 2015, 16:37
evserv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Фоторамка TeXet TF-307 сильно отстают часы
в форуме TeXet
rublan
20
19628
05 окт 2020, 21:37
mia Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sven MS-307 номиналы резисторов
в форуме Ремонт бытовой техники | Repair of household appliances
magbuk
14 сен 2022, 20:58
lozavideo Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 4710S (Invicta Cycle 1) 13 раз моргает оранжевым светодиод на разъёме питания
brandline
24 мар 2015, 11:57
В этой теме нет новых непрочитанных сообщений. Probook 4510s (Inventec invicta cycle) Не заряжает батарею, не горит индикатор
Grizli_saratov
19 авг 2015, 09:57
xamyt_ Перейти к последнему сообщению
Сейчас этот форум просматривают: GoGo.Ru [Bot] и гости: 22
