Заголовок сообщения: Macbook A1286 (820-2915) VGA problem
Добавлено: 25 ноя 2013, 14:50
Зарегистрирован: 18 сен 2012, 23:52 Наличности на руках: 52.00 Сообщения: 8 Откуда: Poland
Hello from Poland,
we have a lot of problems with Apple 820-2915 motherboards. Usually there is a problem with graphics (artifacts) on this motherboard. It is ATI 216-0809000. Originally it is DC11 chipset.
After heat it - Macbook start ok and work. So we replace chipset to the new one DC12 and DC13 (chipsets are 100% new and original). After it Macbook starts, give sound signal, but screen remain black. Don't run properly. So we back to original chipset - Macbook start ok.
Question: Do you have any information about compatibility new chips? Is it chipset firmware problem, EFI problem, revision problem or chipset ID problem?
Any information will be helpful.
lamo
Заголовок сообщения: Re: Macbook A1286 (820-2915) VGA problem
Сейчас этот форум просматривают: Arrrrtemka и гости: 12
