Текущее время: 27 апр 2024, 23:23
 Заголовок сообщения: Sony VPCS111FM VPCS (MBX-216 A1767191A) BIOS
СообщениеДобавлено: 05 дек 2013, 10:24
I am looking for bios VPCS111FM VPCs Sony MBX-216 Motherboard A1767191A the size of 8Mb .. because my bios flas image tool change 4MB..please help me
 Заголовок сообщения: Re: Sony VPCS111FM VPCS (MBX-216 A1767191A) BIOS
СообщениеДобавлено: 05 дек 2013, 11:41
where is an original 8MB dump from your NB?
There is no bios for sony anywhere. And this is not a wide-selling brand
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 10 дек 2013, 08:09
This example bios of sony vaio
СообщениеДобавлено: 10 дек 2013, 10:35
and there isn't bios region.
Only ME-region.
bad dump
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 12 дек 2013, 09:41
Only ME-region.
bad dump
The best solution how?
thanks
СообщениеДобавлено: 26 авг 2016, 20:14
hi,
sorry for opening an old thread. my problem is almost same.
changed hm57 and need to write clean me. but i cannot write 8mb file with my fitc
please help.
there is two chip on this system
one 8mb(u54) other is 2mb(u23)
need clean me for hm57
note: by the way motherboard model is da0gd3mbcd0. rev:d mbx-216
this motherboard is an UMA. no external chip placed on u4001. it is empty.
looking forward helps
СообщениеДобавлено: 27 авг 2016, 12:29
Solution made by atombilgisayar.com and they accepted to give it for free.
8mb file is not a bios file. it has intel pch and me region. it is u54
2mb file is bios file it is u23.
fitc 6.040.1212 recommended for build file.
opened 8mb file with fitc and selected "hp's hm55 me region"
after build file it gives 4mb file.
with hex editor opened old 8mb file and builded 4mb file.
copied builded 4mb contents and overwrited first side of old 8mb file than write it with bios writer hardware. it is successfull. :dan_ser:
fan works normal.
the bios and new pch with clear me is attached to message.
click thanks if usefull.
В этой теме нет новых непрочитанных сообщений. Sony VPCS111FM (MBX-216 rev D) Need dump
в форуме Sony
ipc111
12 ноя 2014, 12:02
ipc111 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. sony (mbx-224) 216-0728014 вместо 216-0774007
в форуме Sony
voronn86
08 июн 2015, 17:43
babayan75 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony sve171a11v (mbx-267 (z70cr)) замена 216-0833002 на 216-0833000
в форуме Sony
eugkov
16 апр 2015, 09:28
eugkov Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sony SVE1513B4E (DA0HK5MB6F0 MBX-269 REV-F) замена 216-0833002 на 216-0833000
в форуме Sony
acidzone
5814
10 июл 2016, 13:48
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony PCG-7181V (MBX-217) Замена 216-0728018 на 216-0749001
в форуме Sony
UnitX
10 ноя 2017, 00:48
UnitX Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
