Текущее время: 02 май 2024, 02:26
eletmoraes
Заголовок сообщения: compaq CQ42-212BR (DA0AX3MB6C2 rev.c) no power Добавлено: 14 дек 2013, 01:58 |
Зарегистрирован: 18 фев 2012, 22:42 Наличности на руках: 118.34
Сообщения: 389 Откуда: Brasil
not power, nor led the socket (connector) DC is lit. Removed HD, DVD, memories, battery, was the only motherboard . I want to rewrite the bios but how is budget , if possible, build a recorder BIOS (not have in hand in my workshop, this unit is very important, I also want to pass the budget as soon as possible for the customer)
does not light any LED
Заголовок сообщения: Re: compaq CQ42-212BR (DA0AX3MB6C2 rev.c) no power Добавлено: 14 дек 2013, 08:31 |
Check voltages on power supply connector first. It has 3 wire: +V, Ground, Adapter ID = 7-19V.
Заголовок сообщения: Re: compaq CQ42-212BR (DA0AX3MB6C2 rev.c) no power Добавлено: 16 дек 2013, 08:40 |
It's ok. if you are confused about gate 28V - see the line +VH28 (28V). Buy programmer EZP2010 with sockets - cheap and fast.
