Текущее время: 07 май 2024, 15:55
 Заголовок сообщения: ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU
СообщениеДобавлено: 04 янв 2014, 19:23
There is a strange problem, Laptop not boot by Core i7 but boot and working ok by Core i3!!!. Bios sewed. Any idea??
Don't give up without the fight.
 Заголовок сообщения: Re: ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU
СообщениеДобавлено: 04 янв 2014, 19:28
A software limit of BIOS
Also for I7 need 3 phase of CPU core power
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 04 янв 2014, 19:52
So what can I do? You have any compatible BIOS? or suggest to dig CPU feed?
СообщениеДобавлено: 04 янв 2014, 21:53
I think you shouldn't install I7. Also it is very hot (think about cooling system).
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 05 янв 2014, 11:00
But it worked with i7, suddenly stop working, you just Eliminate the issue!! not solving!!
СообщениеДобавлено: 05 янв 2014, 17:32
did you write this?
and after you wrote this
can you write more clearly?
СообщениеДобавлено: 05 янв 2014, 19:33
unit1 писал(а):
did you write this?
yes.I once sewed BIOS and boot by core i7. so after I assemble laptop there is no boot. and after that I tried more and more but not boot in core i7. So I changed CPU with core i3 --> booting!!! So now It boot with core i3 but not booting by core i7.
 Заголовок сообщения: Re: ASUS K43JA (K43JA) NOT BOOT BY CORE I7 CPU  [РЕШЕНО]
СообщениеДобавлено: 07 янв 2014, 13:10
Problem solved. VGA resoled! laptop booted by core i3 because CPU have Integrated HD graphics but, And not booted by i7 because it has not Integrated HD graphics!!! So by solving VGA Chipset Disconnection by BGA machine every thing goes OK.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer TMP455-MG (AC82935) Default Boot Device Missing or Boot Failed
frigate
02 мар 2015, 10:49
frigate Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. V3-471G (DA0ZQSMB8F0) Cannot boot with Core i7 45W Processor stuck at 4d Debug code
chrizzclo
11 дек 2017, 07:05
chrizzclo Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus (k43sj) not boot
nasser_pczone
08 май 2015, 06:24
volshebnik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 4530 (win7) Not boot
massino
05 ноя 2014, 17:18
notemaster Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. aspire one (pav70 la-6221p rev:1.0) could not boot from h.d.d
alifakhrniya
28 мар 2016, 15:46
alifakhrniya Перейти к последнему сообщению
Сейчас этот форум просматривают: Dr.Serg, Dron1980, Saxet, vsepo4inim, yourtechby и гости: 46
