Текущее время: 06 май 2024, 22:53
alifakhrniya
Заголовок сообщения: asus x401u (x401u-m3 rev.2.0) automatically goes to bios screen... Добавлено: 31 янв 2014, 18:22 |
Сообщения: 138 Откуда: iran,azerbaycan
Hi friends. x401u-m3 rev.2.0 automatically goes to bios screen and not boot from h.d.d.I mean after the system reset it goes to bios screen an do not boot from any device.So i updated bios links below: viewtopic.php?f=40&t=3878&p=140015&hilit=%2Ax401u%2A#p140015 this file: good_x501uas313_mainboard-x401u-m3_rev.2.0 Now system boots up from H.D.D and works well but there is an issue,the keyboard do not works properly,and the all key has wrong function,as the example the "B" works as down arrow key,i tried some bios but the same. َinclusively the keyboard works well with my backed up bios.... Any help please.
[size=85][color=#DA573B]Posted after 3 minutes 12 seconds:[/color][/size] I must add this that the bios files on asus support site are not true ones.i compared them with backed bios.
Dejmos
Заголовок сообщения: Re: asus x401u (x401u-m3 rev.2.0) automatically goes to bios screen... Добавлено: 03 фев 2014, 12:34 |
Сообщения: 591 Откуда: Латвия, Рига
alifakhrniya писал(а): Dear Dejmos,the bios has only this option"launch efi shell from filesystem device".when i choose this option.system reply with"not found" error.
i had exact problem as you have! And i have the solution! You need change settings, after you'll have success with bios flashing(you need that version of bios, when will be that function, or you need installatiion media with UEFI)! Windows 8 uses uefi partition to boot, and if bios support this, it is more secure and speed up boot time, but if your uefi partition has been lost or broken, your PC goest to setup screen, because new asus models does not display this message: "insert boot media in selected boot device and press a key" . If you change bios settings to legasy it will looking for any boot sector on all devices present as bootable in bios settings. Did you have that settings in bios?: You need Enable CSM
