Текущее время: 01 май 2024, 04:40
 Заголовок сообщения: K50AB (k40AB) red screen
СообщениеДобавлено: 13 фев 2014, 13:48
Hi. I have a problem with K50AB laptop (platform rev 2.1). After replace bga chip (north bridge 4026) laptop gives red screen (for example on start instead black screen under Asus logo screen is red). Bga is new (2013). Firstly laptop had a black screen (nothing on it). What can be dameged? Laptop have also graphic (8014). Could it be graphic bga chip?
P.S. sorry for my english.
 Заголовок сообщения: Re: K50AB (k40AB) red screen
СообщениеДобавлено: 13 фев 2014, 17:10
Try to reball it
СообщениеДобавлено: 13 фев 2014, 17:33
I'm already changing this gpu to new and i will give response soon what happened. Red screen is on both graphic setiings in BIOS (internal and external)...
Posted after 1 hour 14 minutes 16 seconds:
After replace gpu problem still is the same... red screen... Should I try to change for old bga chip 4026 or is something else which can make this problem? Anyone?
СообщениеДобавлено: 15 фев 2014, 00:05
How you determined what problem in GPU?
Jak było określano, że problem jest w GPU?
兰克乌是松尔赫, 你操舰军斯罗俄
СообщениеДобавлено: 15 фев 2014, 17:58
Based on cpu testing tool (which shows connections between CPU and North Bridge). It shows that this is a problem with North Bridge.
Podstawka procesora pokazywała problem w komunikacji pomiędzy CPU a mostem północnym stąd wymieniałem most północny.
СообщениеДобавлено: 16 фев 2014, 22:50
If is not a problem with GPU could be a problem with the PCB layers. I hope not.
Good Luck
СообщениеДобавлено: 17 фев 2014, 12:39
What else can be responsable for this "red screen"? Is someone have a schematic diagram (K40AB rev 2.1)? I would be very gratefull :)
СообщениеДобавлено: 17 фев 2014, 23:45
Can you plug in external monitor to the laptop?
Czy jest możliwość podłączyć monitor do laptopa?
Schematę można pobrać tutaj
http://zremcom.ru/scheme/scheme-asus/fi ... s-k40aa-ab
兰克乌是松尔赫, 你操舰军斯罗俄
СообщениеДобавлено: 18 фев 2014, 00:00
show photo of the North bridge on the motherboard. Can elements of the demolished near the North bridge. Scheme on K40ab for your mail.
Всех денег не заработать!!!
СообщениеДобавлено: 18 фев 2014, 11:53
On external monitor everything was fine. Thanks for scheme, It helps. Problem solved! I replaced TS3DV416DGGR (texas instruments) smd on U7801 field and everything is fine on internal and external screen :) Thanks everyone for help!
СообщениеДобавлено: 21 фев 2014, 03:31
I think it was a based problem with U7801, not the graphic controller, great jobs, i haved same problem with customer notebook, but i have blank screen, Your solution, reasolved also my problem. Thx .
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. K50AB (K40AB) Подскажите чем заменить K40AB/K50AB
Eriol1
1025
03 ноя 2021, 18:55
В этой теме нет новых непрочитанных сообщений. Куплю нерабочие материнки K40AB от Asus K50AF/K40AF, K50AB/K40AB
в форуме Куплю | Buy
radeon6
02 мар 2017, 13:28
maxr1979 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. k40ab (k40ab rev.1.3g) k40ab замена видио чипа на 216-0728020
sanya123
14 май 2015, 15:17
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus K50AB (K50AB) Очень сильно греется
[ На страницу: 1, 2 ]
gigaprice
49
22609
24 дек 2018, 15:26
Igor18Игорь Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus K50ab (Asus K50ab) Перегрев
Max13111987
3768
04 июл 2016, 11:38
promistik Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot] и гости: 39
