Текущее время: 05 май 2024, 23:02
wegeras
Заголовок сообщения: Re: Macbook Air a1466 (820-3437-B.) Bios need Добавлено: 27 мар 2014, 13:43 |
Зарегистрирован: 24 мар 2014, 16:50 Наличности на руках: 50.01
Сообщения: 6 Откуда: Warsaw
U need tools: unpkg and maccommander in adminmode (cmd+0) to acces /
1. download smc update from apple website (pkg file), unpack it, find SmcFlasher.efi and YOURSMCNAME.smc and copy it to / 2. download efi update from apple website (pkg file), unpack it, find YOURSMCFILELOCKED.scap copy it to /
W A R N I N G !!! EXTREMELY CAREFULLY CHECK IF *smc FILE IS 4 YOUR COMPUTER!!! MESSING WITH IT WILL TOTALLY FUCKED UP YOUR BOARD!!! TO FIX IT THEN U NEED TO REPLACE SMC CHIP FROM SAME WORKING BOARD!!!
3. flash smc via efi shell. Use refit, type: SmcFlasher.efi -LoadApp YOURSMCNAME.smc next reboot to os(safe mode if not working in normal mode) 4. there is 3 possibilities, you can find witch 1 of them will work 4 u. a) efi update via updates can be found in applemenu/updates, if not found there go to step "b" b) efi update via package downloaded earlier -just double click on it . After reboot shoiiuld reflash your efi. If this step is either not working for you step "c" will be good. c) efi update via terminal, open terminal type #bless -mount / -firmware /YOURSMCFILELOCKED.scap
If you do not have root access type $sudo bless -mount / -firmware /YOURSMCFILELOCKED.scap
thats all
