Текущее время: 21 май 2024, 14:04
 Заголовок сообщения: HP G62 (Quanta AX1) No backlight on LCD
СообщениеДобавлено: 09 мар 2014, 21:39
Hi guys,
I have a 'little' problem with 2 same motherboards.
Motherboards are pulled out from HP G62.
1. 01013y000-388-g
2. 01013y000-600-g
Platform is Quanta AX1
Both mobo's are Intel cpu, Intel HM55 chipset, Ati 216-0774009 graphics.
Problem is when I start the notebook, there is a picture on display, but there is no backlight. LCD cable and display has been changed for test - problem is not in cable or display.
This problem is with both mobo's.
I can't find information which IC turns backlight on when notebook starts - HM55 or Ati. Is there anybody who can explain me boot seq. for this noteobok (I'm a newbie).
You can find schematics here: https://www.dropbox.com/s/teikrnnyb4oef ... REV_1A.pdf
I think to change HM55 at first.
 Заголовок сообщения: Re: HP G62 (Quanta AX1) No backlight on LCD
СообщениеДобавлено: 10 мар 2014, 08:02
measurements on connector "CN1" pin4, pin38, pin39?
СообщениеДобавлено: 10 мар 2014, 13:24
Do not change HM55, better measure the voltage of these signals and pins:
+VIN_BLIGHT on CN1 pin39-40
BLON_CON on CN1 pin 38
VADJ1 on CN1 pin 37
EMU_LID on KBC (U4) pin 31
LID_EC# on KBC pin 127 or CN4 pin 3
and write voltages here :-):
СообщениеДобавлено: 10 мар 2014, 21:52
First - thanks for answers.
+VIN_BLIGHT on CN1 pin39-40 - 1.55-1.6v
BLON_CON on CN1 pin 38 - 1.55
VADJ1 on CN1 pin 37 - 0
EMU_LID on KBC (U4) pin 31 - 0
LID_EC# on KBC pin 127 or CN4 pin 3 - here I measure 0.3v and count to 0, which seems strange..
СообщениеДобавлено: 12 мар 2014, 21:26
check inductance "L15"
and once more, measurements on connector "CN1" pin4?
СообщениеДобавлено: 16 мар 2014, 18:00
I'm sorry for delay, but I have work out of town.
On pin4, CN1 = 0v
But I can't find this L15 on the board...
СообщениеДобавлено: 16 мар 2014, 18:19
Заблокирован
---------- Добавлено спустя 7 минут 52 секунды: ----------
latitude
QUANTA AX1 - BOARDVIEW
СообщениеДобавлено: 16 мар 2014, 18:52
Yes, I found it on the schematic, but I can't find it on the board... Still searching..
СообщениеДобавлено: 16 мар 2014, 19:03
Заблокирован
kotnatan писал(а):
latitude
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP G62 (Quanta AX1) HP G62 work when keyboard detached
montarbo
26 июн 2017, 18:51
montarbo Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. G62-450er (Quanta AX1) Пост код 5A
menbearpig
04 сен 2016, 13:16
slavik5514 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP G62-450ER (Quanta AX1 rev: C) Подскажите где стоит термодатчик процессора
Prochenok
21 мар 2016, 11:23
Prochenok Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. hp g62 (quanta ax1) не зарежает акб
vovka6230
06 янв 2017, 23:07
Гектор Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Куплю аудио разъем hp g62(quanta ax1), Украина
в форуме Куплю | Buy
darthmaulx3
15 май 2017, 21:29
FatalError Перейти к последнему сообщению
Сейчас этот форум просматривают: Бенедиктов Святослав, complus, DmitriyDDD, drsmoke, koko, paveell, x-tuner и гости: 39
