Зарегистрирован: 03 фев 2014, 04:22 Наличности на руках: 7.00 Сообщения: 27 Откуда: world
Hello all
i have Asus ENGTX260 when connected to pc, pc not boot into but fan is spinning video card has continues beep,
I have changed with several power supply but still not work
elektronas
Заголовок сообщения: Re: Asus ENGTX260 not working
Добавлено: 31 мар 2014, 17:05
Зарегистрирован: 20 мар 2014, 22:28 Наличности на руках: 23.00 Сообщения: 7 Откуда: LT
Do you have connected external power connector to vga ?
massino
Добавлено: 01 апр 2014, 18:46
yes i have power coming from cpu power supplier connected to both connectors
reciners
Добавлено: 01 апр 2014, 18:47
Зарегистрирован: 20 мар 2014, 16:21 Наличности на руках: -14.00 Сообщения: 6 Откуда: españa
We currently have a pc with the mentioned card doing the same. Gona test all the info posted here
