Текущее время: 07 июн 2024, 18:23
 Заголовок сообщения: V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES
СообщениеДобавлено: 23 сен 2014, 22:24
Hi,
I have got Acer V3-571 laptop with following symptoms.
01. When I turned it on power LED lights up for 5 senconds and turned off.
02. +3.3v and +5v available and +3VL and VLP (VREG3 andVREG5) are also available.
03. When I turned on the laptop U21 and U22 FETs does not turned on and not produced +3VS and +5VS
04. "SUSP" signal not coming to the Q19 and Q25 which are triggering the gates of U21 and U22.
05. Then I checked Q27 for "SUSP" signal. Unfortunately "SUSP#" must be there to generate "SUSP" signal.
06. "SUSP#" generates from KBC (ENE KB9012).
Therefore where to start to solve this problem.
 Заголовок сообщения: Re: V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES
СообщениеДобавлено: 24 сен 2014, 00:37
Voltage KBC (ENE KB9012) and chip bios correct? Firmware right? If so then KBC (ENE KB9012) died
СообщениеДобавлено: 24 сен 2014, 09:01
kandyan
Check
LID_SW# - must be high
ON/OFF - triggered by power switch
PBTN_OUT# - triggered by power switch
PCH_RSMRST# - must be high
KB9012 has internal firmware (EC firmware). Try to reflash it (you need the special programmer to do this).
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 24 сен 2014, 11:57
It might be and i changed it also.nothing good
MSF113 писал(а):
kandyan
Check
I changed KB9012 and reprogrammed it with "Maxim" s KB9012 programmer.
http://notebook1.ru/forma1/viewtopic.php?p=534436
Now all other signals are ok but PCH_RSMRST# doesn't show anything high. I suspect South bridge is the problem is this case according to the symptoms. Shall I reball it or is there anything to check before reballing it?
СообщениеДобавлено: 24 сен 2014, 12:10
Check what PCH_RSMRST# has no short cut.
Check +RTCVCC
Check XTAL25 on Y2 generation present
СообщениеДобавлено: 24 сен 2014, 14:55
Check +RTCVCC
I didn't find anything abnormal in PCH_RSMRST# and
+RTCVCC is present +3V
XTAL25 on Y2 is working when RTC battery is on the battery bay. (Checked it with oscilloscope)
Now I really think that problem is on south bridge bcz in this model there is no heat sink for it. So there is a dry contact under the PCH. I will reball it and let you know the results.
СообщениеДобавлено: 24 сен 2014, 14:58
Do you reflash main BIOS?
СообщениеДобавлено: 24 сен 2014, 20:04
Yes I did. Main,Win8 and EC.
 Заголовок сообщения: Re: V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES  [РЕШЕНО]
СообщениеДобавлено: 12 окт 2014, 21:12
Everything works well after i reballed the South bridge. Thanks everyone for the help.
and also when Dell 3521 boot up without display and making beeps sounds its better to reball the south bridge as well.
Bcz I have reballed 1 beep, 4 beeps and 8 beeps dell inspiron 3521 and problem was solved.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Aspire V3-517G (Q5WVH LA-7912P Rev:1.0) Грозовой нет 3vs и 5vs
jurok86
18 сен 2014, 14:33
jurok86 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. V3-571G (la-7912p REV 1.0) Залитик возле ТП нету +5vs и +3vs
grigoriy_str
26 авг 2015, 16:36
grigoriy_str Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer v3-571g (q5wv1 la-7912p rev:1) Отсутствуют 3vs и 5vs
staskarabas
3491
28 мар 2016, 16:24
Ksilen Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire E1-531 (la-7912p) занижено +5vs и +3vs
Dima08h
20 янв 2016, 22:13
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer E1-531 (la-7912p rev1.0) нет 3vs,5vs
dexstile
05 фев 2016, 13:01
dexstile Перейти к последнему сообщению
Сейчас этот форум просматривают: Diman6267, handymax и гости: 9
