Текущее время: 04 май 2024, 00:22
 Заголовок сообщения: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing
СообщениеДобавлено: 18 окт 2014, 00:23
Hi everyone, this old laptop came to me with password [stringent security] issue and after swapping bios chip, password was removed and I found out the South-bridge needed re-balling [smart-card error issue]. After re-balling, laptop charging led blinks six times and then restarts. I want to know if anyone has encountered this issue and how it was solved. I suspect South-bridge but i want confirmation... :-):
 Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing
СообщениеДобавлено: 18 окт 2014, 10:22
6 Caps Lock/Num Lock BIOS BIOS authentication failure
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 18 окт 2014, 12:50
Thanks for the reply but in this case it is the charging Indicator (orange led) that is blinking..
СообщениеДобавлено: 18 окт 2014, 13:06
I don't see what charging LED blinking, sorry.
charging LED blinking - problem with Power.
СообщениеДобавлено: 18 окт 2014, 19:55
I totally agree with you that it is a power issue because I just realized that there is no voltage on coil L29 [+VCCP] and L26 [+VCC_CORE], but everything was okay before the re-balling.All components around the South-bridge are okay. I will like to know if there are some signals I can check to verify whether the problem is from South-bridge or elsewhere.
 Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing  [РЕШЕНО]
СообщениеДобавлено: 25 окт 2014, 05:34
Hi everyone, after going through a lot of ordeal due to the client threatening me to either fix the motherboard or replace the laptop... :sh_ok:, i realised the problem was lack of PWR_GOOD_3 due to reduced output from Q34 [voltage drop from +V3s to +V2.1s], so replacing Q34 solved the issue... :ya_hoo_oo:
В этой теме нет новых непрочитанных сообщений. HP dv6610ew (da0at1mb8f1 rev. F) After reballing ot starting at all.
notemaster
16 июл 2014, 13:10
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP nx6310 (Inventec DAVOS 3.0) Не дружит с двумя ядрами CPU
infinity
28 янв 2016, 13:38
infinity Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. nx6310 (INVENTEC DAVOS 3.0.) высокий уровень ADP_EN#
roman05
10 июл 2016, 22:21
roman05 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus G751J (G751JY rev 2.5) Not starting, led blinks
Djosla
19 авг 2017, 11:02
Djosla Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Pixus Play Six помогите опознать элемент
в форуме Ремонт планшетных компьютеров | Tablet-PC repairs
mishka007-84
15 сен 2015, 10:27
dastali Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 65
