Текущее время: 03 май 2024, 22:41
 Заголовок сообщения: Acer Aspire 5552 (Compal LA-6552p) shut down by itself after few seconds
СообщениеДобавлено: 01 фев 2015, 18:36
Hi all.
I have a problem with this motherboard. It was bring in service with 'turns off by itself after few seconds'.
Replace North bridge, south bridge - no result.
Bios preprogramming - no result.
Test with different cpu/memory - no result.
When measure board, I found short on PL8. On PQ29 - 19v (5 6 7 8 legs)
LGATE, UGATE - 0V
VOUT - 0V
Replace PC218, PC96, PL8, PC97, PR119
I can't find where the hell is short...
PU8 also replaced - no result.
In these few seconds, before shutdown, I check cpu and memory voltages - OK. 3.3V and 5V - OK.
Identification of components is very hard on this board, because there are no labels on the board. If someone can help, please...
this is screenshot of damaged area:
schematic here: https://mega.co.nz/#!TxpBzRzS!oT3okcpcm ... 6eOQ3IxVIk
Thanks, regards,
 Заголовок сообщения: Re: Acer Aspire 5552 (Compal LA-6552p) shut down by itself after few seconds
СообщениеДобавлено: 02 фев 2015, 15:11
Raise the output №2, PL8 and find out which side is short. If short in PL8, check PQ30, and if the part of the North Bridge, the short or directly underneath it.
Short is - 0 Ohm.
Ремонт ноутбуков
Санкт-Петербург +79313406112
Ессентуки +79283151170
СообщениеДобавлено: 02 фев 2015, 16:10
Sorry, i can't understand "Raise the output №2".
PL8 and PQ30 already replaced.
Do you have boardview for this board?
Thanks for your support.
СообщениеДобавлено: 02 фев 2015, 16:26
It does not say that PQ30 replaced.
Then lift up the Northbridge and measure whether it took short.
It turns out that the short balls stuck together or makes himself or Northbridge.
Ремонт ноутбуков
СообщениеДобавлено: 03 фев 2015, 22:27
Little update. Lift the NB, clear pads and measure, I think short is somewhere before NB.
Because my donor boards are in my home, I try tomorrow with another PL8. PQ29 and PQ30 replace with no result.
Anybody with boardview, please? This board is terrible for work..
СообщениеДобавлено: 10 фев 2015, 02:14
Try connect some regulated power there and look which component heats up.
СообщениеДобавлено: 12 фев 2015, 09:28
Hi, I will try it. Thanks.
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 02:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. lg 42lw4500 alloy comes with picture and sound and after a few seconds erases everything
в форуме LG
eletmoraes
27 июн 2020, 05:11
Irbor Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. dell n1510 (la-4121p) turns on after shut down .
в форуме Dell
alifakhrniya
24 фев 2015, 00:42
ibarakat Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Elitebook 8560P (CURE-UMA_HR_HPB) it shut down after 30 mins
ayad
22 июн 2017, 21:03
Raimondas Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. fujitsu ah530 (da0fh2mb6e0) shut down after about 50 sec
в форуме Fujitsu-Siemens
alifakhrniya
14 окт 2016, 13:16
alifakhrniya Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 31
