Текущее время: 11 май 2024, 20:19
 Заголовок сообщения: C850 (6050A2541801-MB-A02) 1st time no power on but 2nd time working
СообщениеДобавлено: 27 апр 2015, 20:26
I have Toshiba C850 6050A2541801-MB-A02 with PCH (HM76) damaged laptop and I replaced the PCH with another. After I replaced it, when I pressed power button it turn on and off. after few seconds it again turn on automatically and continue to boot. or if I pressed power button immediately it went off in the first time, it continue to boot.
After booting to windows I checked all the ports and part are working without a problem. Where would be the wrong for this strange problem.
I have same thing on another laptop which is Toshiba C50-A. I replaced the damaged PCH (HM76) with another removed from HP G6.
Posted after 7 minutes 26 seconds:
Another symptom of this problem is it takes 2 minutes to enter BIOS if I pressed F2 key.
Posted after 8 minutes:
If I pressed and hold F12 and pressed power button laptop will power on 1st time and shows Boot Devices Menu and continue to boot whatever device I choose. Without press and hold F2 (BIOS) or F12 (Boot Devices) It won't power on for the 1 st time. need to press power button again.
Is it related to BIOS?
I have changed many version (dumps from working laptops) but nothing changed.
 Заголовок сообщения: Re: C850 (6050A2541801-MB-A02) 1st time no power on but 2nd time working
СообщениеДобавлено: 28 апр 2015, 09:23
i have a same problem with c50-a and ithink we need bios dump with clear ME region, but i can't find it
---------- Добавлено спустя 4 часа 38 минут 57 секунд: ----------
viewtopic.php?f=54&t=31866&p=239975#p239975
you need bios dump with clear ME region
place here your bios dump i can try fix it
 Заголовок сообщения: Re: C850 (6050A2541801-MB-A02) 1st time no power on but 2nd time working  [РЕШЕНО]
СообщениеДобавлено: 04 май 2015, 12:31
I returned the laptop to the customer and if i get another C50-A I will upload the BIOS dump for you. Thanks
В этой теме нет новых непрочитанных сообщений. Apple time capsule A1470 (A1470) нужна прошивка для Apple time capsule A1470
в форуме Apple
Adleon
11 янв 2019, 13:38
Adleon Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 14-BP100NA DAG71MB16D0 REV D (HP) Touchpad and keyboard stop working after some time
mantza
04 июн 2020, 22:07
mantza Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Satellite C855-S5107 (DK10F-6050A2541801-MB-A02) Пост 20
в форуме Toshiba
Jagupop
18
5606
11 сен 2015, 14:22
Jagupop Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba satellite c855-s5350 (DK10F-6050a2541801-mb-a02) нужен думп биос
в форуме Toshiba
Kinetic_servis
16 май 2016, 14:01
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. satellite l855-S5405 (Dk10f-6050A2541801-MB-A02) Нужен дамп bios
в форуме Toshiba
satghost
3011
02 июл 2016, 12:34
satghost Перейти к последнему сообщению
