Текущее время: 04 май 2024, 23:56
 Заголовок сообщения: Dell Inspiron 3521 (LA-9104P) Computer Start on 0.49A but no picture
СообщениеДобавлено: 30 апр 2015, 20:17
I have problem this is 3 computers i have same model same problem
computer start goes to 0.49A but not picture
all voltage are o.k
i have changed all 2 bios thousand of times
nothing happen same problem
can any one please lead me
help!!!
all can be fixed
 Заголовок сообщения: Re: Dell Inspiron 3521 (LA-9104P) Computer Start on 0.49A but no picture
СообщениеДобавлено: 01 май 2015, 01:14
Post the voltage "+VCC_GFXCORE_AXG" (pin 4 PL700)
СообщениеДобавлено: 01 май 2015, 01:45
It seems that PL700 give me 0 volt
all can be fixed
СообщениеДобавлено: 01 май 2015, 10:04
Check voltage at pin 2 (VR_ON) of PU700.
СообщениеДобавлено: 03 май 2015, 10:26
i dont get the idea
PU700 is only 2 pin and is 0 voltage
all can be fixed
СообщениеДобавлено: 04 май 2015, 13:22
leg 2 = 3.3v
leg 4 = 1.1v
---------- Добавлено спустя 52 минуты 10 секунд: ----------
ISL95833HRTZ was replaced
same problem
all can be fixed
СообщениеДобавлено: 05 май 2015, 00:12
Dimension писал(а):
i dont get the idea
PU700= ISL95833HRTZ-T_TQFN32_4X4 (32 pin)
page 52 from schematic: b2f74_Compal_LA-9104P_VAW00_Inspiron_3521.pdf
СообщениеДобавлено: 05 май 2015, 05:57
yes i understand
i gave u an answer
leg 2 = 3.3v
leg 4 = 1.1v
same problem
all can be fixed
СообщениеДобавлено: 05 май 2015, 22:48
Dimension писал(а):
yes i understand
i gave u an answer
leg 2 = 3.3v
leg 4 = 1.1v
same problem
Voltages seem to be good.
Could you get an oscilloscope, in order to measure pulses at pins 25 and 26 of ISL?
I am trying to get the data-sheet for the ISL95833HRTZ, but until now..... :ne_vi_del:
СообщениеДобавлено: 14 май 2015, 13:17
Dear Vlab member
i did check the problem and it has not been solved electronic
so i read in the internet in some post that
the solution!!!
Dell 3521 is not turning on without the battery
shit!!!!
so simple so annoying
hope this post help you if it did
say thanks
this case can be close all computer got out fix
all can be fixed
В этой теме нет новых непрочитанных сообщений. Gigabyte GTX 960 - computer can't start, stop on "2b" post code
Micchaleq
21 июн 2019, 00:12
Micchaleq Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo B590 (Intel) Lenovo B590 power on but no display (picture)
cygron
28 июн 2021, 09:32
kkv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 3521 (La-9104P) Выключается сам по себе
в форуме Dell
Henkok_UA
12
7400
24 сен 2014, 15:49
kerim92 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell inspiron 3521 (la-9104p) не стартует
в форуме Dell
staskarabas
13942
16 апр 2015, 07:26
dedmartos Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell inspiron 3521 (la-9104p) (intel) не стартует
в форуме Dell
triano
12
6645
02 сен 2014, 19:15
ion.tutunaru Перейти к последнему сообщению
Сейчас этот форум просматривают: buddy, Yandex [BOT] и гости: 13
