Текущее время: 21 май 2024, 01:21
 Заголовок сообщения: dead Acer aspire 5738Z
СообщениеДобавлено: 05 май 2015, 01:07
hi
Got dead Acer Aspire 5738Z for Repair.
Platform: JV50-MV M92MB (discrete)
Found shorted VGA_CORE_PWR output, changed U41 fet and short was gone now laptop powers up with no display and VGA_CORE_PWR =+0V Changed U45 RT8202A then U40, always same.
Main working voltage measured for RT8202A :
VDD and VDDP = +3.3V ok
EN_VGA = +3.3V ok
But :
TON is +0.9V must be +19V I think. C696 and R418 are checked ok.
RT8202_DH_VGA=+0V, it should be high ??
and RT8202_DL_VGA=+3.3Vit should be low??
P.S help with idea as what to check next to get VGA_CORE_PWR output ?
 Заголовок сообщения: Re: dead Acer aspire 5738Z
СообщениеДобавлено: 05 май 2015, 21:27
It should be 5V_S5 (5v.)
Have you checked R426?, I think it is open.
TON, goes to +19V trough R418, so voltage +0.9V is good.
СообщениеДобавлено: 06 май 2015, 00:16
andromedax писал(а):
It should be 5V_S5 (5v.)[/b]
Y're right, I made mistake when writing figures. They measured rather 5V_S5.
I was thinking that +19V going through R418 should be rather high and not so low.
Do you confirm that +0.9V could be ok ?
СообщениеДобавлено: 06 май 2015, 09:47
TON input is connected to DCBATOUT_8202_VGA (19v.) through a 1 Mohm. resistor, and it is an input comparator to set switching frequency.
I think +0.9V could be a good voltage for an input comparator.
СообщениеДобавлено: 06 май 2015, 16:59
[/quote]TON input is connected to DCBATOUT_8202_VGA (19v.) through a 1 Mohm. resistor, and it is an input comparator to set switching frequency.
I think +0.9V could be a good voltage for an input comparator.[/quote]
Ok I admit it.
Do you have any idea as what to check next to Get VGA_CORE_PWR output?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. acer aspire 5738z (Виндовс 7) Экран нет подсветки
B_pot_nogi
21 фев 2018, 23:45
B_pot_nogi Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Aspire 5738Z (JV50-MV) не стартует.
Rayms
20 ноя 2014, 16:57
Rayms Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire 5740g (JV50-CP 09285-1M 48.4GD01.01M) Acer Aspire 5740G dead / not starting at all.
anuragis1
01 июл 2014, 07:49
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. acer 5738z (jv50-mv) Зависает при чтении с usb флешки
skop234
1559
19 мар 2016, 21:59
skop234 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer 5738z (jv50-mv 08245-1) Need to convert to Uma
scobay
05 янв 2019, 23:16
Сейчас этот форум просматривают: Yandex [BOT] и гости: 13
