Текущее время: 08 май 2024, 14:20
 Заголовок сообщения: Sandisk Extreme 240GB SSD component identification
СообщениеДобавлено: 27 июн 2015, 05:20
Hi everyone!
I have acquired a defective SSD with the following details:
brand/model: Sandisk Extreme 240GB
board no.: P/N 54-50-05056-r100
controller: SandForce SF-2281VB1-SDC
maybe someone can help me identify the U7 IC in the photo below.
I checked everything around it but it seems that it is shorted in one of its ouput.
I will try to replace U7 but i can't find anything about that IC (BQE 1AI A16Z) and i don't have a schematic for this PCB either.
thanks!
 Заголовок сообщения: Re: Sandisk Extreme 240GB SSD component identification
СообщениеДобавлено: 27 июн 2015, 10:29
I think it TPS62400DRC, here datasheet in attachment
СообщениеДобавлено: 05 июл 2015, 06:40
Hi kaliyan! thank you for your response!
i'm going to order the chip ASAP and see what happens.. I will update you also once i got the IC and done installing it. :-):
СообщениеДобавлено: 29 июл 2015, 12:39
Hi kaliyan! the chips I ordered have arrived and I already installed the replacement BQE IC for U7. Now I have a clean 1.0V and 2.91V on the inductors L4 and L5 but sadly the SSD is still not being detected by BIOS/EFI on laptops or desktop PC. The controller seems to have a power because it heats up.
I'm still blind due to non-availability of schematic and I'm hoping to find some lights by identifying some other IC's on the PCB and continue from there.
I'm suspecting that the controller SandForce SF-2281VB1-SDC does have one of the following issue:
a) is not getting all the voltages it needs or required logic signal to switch it ON
b) needs re-balling
c) it could be toasted or has a corrupted firmware
I will post some photos again later..
Posted after 1 hour 5 minutes 11 seconds:
Here are the photos I took,
left pins of C32, R27, R24, and C41 are GROUND.
as illustrated, pin 4 of this IC (U6) goes to C41 and pin 5 goes to R27 - near the controller on the photo above
I wonder what IC's are U6 "14BBJ" and U1 "W5BE 006"
СообщениеДобавлено: 01 дек 2015, 01:35
I have exactly same SSD. It's not working at all.
Have you made any progress? I'm working on it these days. I figured out a few things.
  • TPS62400 dual voltage regulator looks okay.
  • 2x TPS54418 voltage regulators looks okay.
  • Central MCU's Oscillator output pin looks working.
  • I've soldered a resistor and LED to D1 and R1, LED lights up after connect SSD to computer.
Finally, I've removed Sandforce SF-2281VB1-SDC Central MCU. Ordered new one. It's on the way right now. I wonder if that will work after replace the MCU. I'll keep you posted.
В этой теме нет новых непрочитанных сообщений. Реально ли прошить SSD Sandisk SSD Plus 120GB
в форуме Ремонт SSD | SSD repair and data recovery
Sebastianxy1
4818
19 фев 2023, 16:33
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. новый SSD M.2 Kingston HyperX Predator 240Gb (SHPM2280P2/240G)
Marcotender
04 май 2018, 16:17
Marcotender Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. WD sata ssd m.2 240gb
pumboid
3496
13 окт 2020, 16:26
pumboid Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. SSD Colorful SL500 240GB помогите с прошивкой контроллера SM2258XT
vova_w810i
5163
20 ноя 2020, 13:09
В этой теме нет новых непрочитанных сообщений. Слетает прошивка SSD 240Gb Kingston HyperX Savage
disonic
12
2882
23 фев 2021, 00:20
badcode Перейти к последнему сообщению
Сейчас этот форум просматривают: Vic-42 и гости: 5
