Текущее время: 05 май 2024, 05:07
 Заголовок сообщения: Asrock B75M - Need help with component identification
СообщениеДобавлено: 17 мар 2016, 10:16
Good morning, everyone. I have Asrock B75M, which dies some days ago.
So, there is blown chip, which I can't identify. Can someone help me with that? I don't know if there any schematics for desktop boards.
Blown IC is between DIMM and CPU socket, marking code UP751. On the IC I only see '02 FC'. You can see board position on the attached photo.
Thanks in advance,
Have a nice day all.
 Заголовок сообщения: Re: Asrock B75M - Need help with component identification
СообщениеДобавлено: 17 мар 2016, 14:55
May be RT9611A ?
СообщениеДобавлено: 18 мар 2016, 12:27
Maybe. I will check pin's on the board ..
СообщениеДобавлено: 27 мар 2016, 17:26
Little update ..
Maybe IC is really RT9611A.
1-0v
2-3v
3-5v
4-12v
5-0v
6-ground
7-0v
8-0v
but 5 and 8 are Lgate & Ugate, so it's normal without IC
I have to replace bios chip, because old one gives errors when try to flash it. When install pci-e graphic card, motherboard powers on, POST and works (go to BIOS). With onboard graphics, there is no picture and no POST. Can someone tell me what is the meaning of this IC. From PDF I see this:
The RT9611A/B is a high frequency, synchronous rectified,
single phase dual MOSFET driver designed to adapt from
normal MOSFET driving applications to high performance
CPU VR driving capabilities.
Is there relation between this IC and cpu internal graphics?
СообщениеДобавлено: 24 окт 2016, 10:18
Hello, i have Asrock B75M-GL motherboard and here is not enough 3 components, can you help me identify it?
There should be placed resistors i guess, but i dont know nominals.
Second photo is UP751 controller on my board.
Thx
Тема поднималась пользователем i001546 24 окт 2016, 10:18.
В этой теме нет новых непрочитанных сообщений. component identification help
TheMArcos
12
2077
14 авг 2022, 06:04
TikaZzava Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenvo l520 (please help me i need bin lenvo l520) please help me i need bin lenvo l520
issabaouch
10 ноя 2017, 02:06
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus k55vj (K55VM) need identification nad help
notemaster
03 мар 2016, 11:29
notemaster Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell SE2416H -need help identifying a component
в форуме Ремонт мониторов | LCD repair
Djosla
12 июл 2017, 20:08
Djosla Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sandisk Extreme 240GB SSD component identification
zoom21
01 дек 2015, 01:35
hamityanik Перейти к последнему сообщению
