Текущее время: 26 май 2024, 18:48
FRD
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 17 июн 2016, 12:39 |
Зарегистрирован: 12 май 2014, 21:17 Наличности на руках: 70.07
Сообщения: 50 Откуда: Iran
Sergej писал(а): Put a dump of 24s08 up Thanks for the reply, the laptop itself is not here at the moment, but it'll be in my hands in a couple of days, as soon as I get it I'll post up the dump. Thanks.
Rein
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 21 июн 2016, 18:06 |
Сообщения: 192 Откуда: Lvov
As Цитата: The eeprom is a Philips P24S08 which is equivalent to a 24RF08, so any reference in the following text to a 24RF08 applies to this eeprom it is a good idea to dance around with 24rf08 and IBMPass.
FRD
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 22 июн 2016, 14:20 |
Rein писал(а): As Цитата: The eeprom is a Philips P24S08 which is equivalent to a 24RF08, so any reference in the following text to a 24RF08 applies to this eeprom it is a good idea to dance around with 24rf08 and IBMPass. Ok, as it seems someone else before me has wiped 24s08, because when i read it gives me all 0xff, if it's been erased completely, can I do something?
FRD
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 14 июл 2016, 16:45 |
guys I have found a BIOS and 24s08 dump from forum in the following link. viewtopic.php?f=58&t=6140&p=345131&hilit=%2At61%2A#p345131I have programmed both BIOS and NXP 24s08 and now bad SVP data error is not shown and I can boot and work with system, however every time I restart the laptop it gives and Error as Follow Error 0188 : Invalid RFID Serialization Information Area. Press <F1> to Setup
although I press ESC and windows boots, but it's annoying, as it seems it's related to EEPROM CRC checksum and board Serial number, Am I correct? I have played with DMI values in Winphlash advanced setting with no luck :( Any help will be appreciated. Thanks an advance.
FRD
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 15 июл 2016, 09:11 |
Sergej писал(а): FRD change serial`s with Lenovo HMD Sergej Thanks for the answer, but right after i posted, i found the HMD and made a USB Flash Key, I managed to change system-unit and system board serial numbers, the previous ones were corrupt. Now serial numbers do appear on BIOS screen and error 0188 is gone for good now and system boots normally, but I can not change MAC Address (Internal LAN) on BIOS. It's all FF FF FF FF FF FF. I have tried it with C1 and C2 locations with no luck, is there a manual for HMD somewhere? Maybe I'm not feeding the MAC Address with the correct prefix?!!
Sergej
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 15 июл 2016, 20:27 |
Зарегистрирован: 25 дек 2011, 15:27 Наличности на руках: 3,511.28
FRD писал(а): can not change MAC Address (Internal LAN) on BIOS i wrote old MAC (from original dump) manually in a new BIOS with HEX-editor and then programmer.
FRD
Заголовок сообщения: Re: Lenovo (Thinkpad T61) 0177 Bad SVP Data Error Добавлено: 17 июл 2016, 08:42 |
Sergej писал(а): i wrote old MAC (from original dump) manually in a new BIOS with HEX-editor and then programmer. Spent some time in HEX-editor looking for MAC addresses in BIOS dump with no luck, I think MAC address is not stored in BIOS, instead it's in 24s08 dump, because when I open 24s08 dumps in SVP Tool it gives me, unit serial no, system board serial no, UUID and MAC address also. I'm attaching dumps and some pictures, and I really appreciate if you have the time to check. T61 FilesThanks you so much.
