Текущее время: 04 май 2024, 09:50
Сергей0607
Заголовок сообщения: Re: SSD OCZ vertex 450 Добавлено: 23 фев 2017, 23:13 |
Сообщения: 1 Откуда: Ростов
Есть ли возможность восстановить. OCZ vertex 450
TA device, with non-removable media Model Number: OCZ-VERTEX450 Serial Number: OCZ-1GRWSQA6K5Z2QU04 Firmware Revision: 1.0 Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0 Standards: Supported: 8 7 6 5 Likely used: 8 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 250069680 LBA48 user addressable sectors: 250069680 Logical Sector size: 512 bytes Physical Sector size: 512 bytes device size with M = 1024*1024: 122104 MBytes device size with M = 1000*1000: 128035 MBytes (128 GB) cache/buffer size = unknown Nominal Media Rotation Rate: Solid State Device Capabilities: LBA, IORDY(can be disabled) Queue depth: 32 Standby timer values: spec'd by Standard, no device specific minimum R/W multiple sector transfer: Max = 1 Current = 1 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Commands/features: Enabled Supported: * SMART feature set * Security Mode feature set * Power Management feature set * Write cache * Look-ahead * Host Protected Area feature set * WRITE_BUFFER command * READ_BUFFER command * DOWNLOAD_MICROCODE SET_MAX security extension * 48-bit Address feature set * Device Configuration Overlay feature set * Mandatory FLUSH_CACHE * FLUSH_CACHE_EXT * SMART self-test * General Purpose Logging feature set * 64-bit World wide name * Segmented DOWNLOAD_MICROCODE * Gen1 signaling speed (1.5Gb/s) * Gen2 signaling speed (3.0Gb/s) * Gen3 signaling speed (6.0Gb/s) * Native Command Queueing (NCQ) * Host-initiated interface power management * DMA Setup Auto-Activate optimization * Software settings preservation * Data Set Management TRIM supported (limit unknown) Security: Master password revision code = 8024 supported enabled locked not frozen not expired: security count not supported: enhanced erase Security level high Logical Unit WWN Device Identifier: 5e83a972e6b84892 NAA : 5 IEEE OUI : e83a97 Unique ID : 2e6b84892 Checksum: correct ubuntu@ubuntu:~$ sudo hdparm --security-unlock "" /dev/sda security_password: ""
/dev/sda: Issuing SECURITY_UNLOCK command, password="", user=user SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 51 40 01 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ubuntu@ubuntu:~$ sudo hdparm —security-disable "" /dev/sda —security-disable: No such file or directory ubuntu@ubuntu:~$ sudo hdparm --security-disable "" /dev/sda security_password: ""
/dev/sda: Issuing SECURITY_DISABLE command, password="", user=user SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 51 40 01 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 51 40 01 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ubuntu@ubuntu:~$
информация лучше бы осталась, но вообще не критична.
boildead
Заголовок сообщения: Re: SSD OCZ vertex 450 Добавлено: 24 фев 2017, 16:32 |
Сообщения: 2 Откуда: Moscow
Vic-42 писал(а): boildead А как он себя ведет? Подробнее... При подключении без джамперов первое время определялся как генерик диск на 0 ГБ в установщике Windows. Через какое-то время перестал определятся, после чего даже биос стал очень долго грузится. При загрузки лайв убунты выдавало такое сообщение: COMRESET failed (errno=-32) Разобрал, закоротил джампер как на картинке красным, начал отображаться в Управлении дисками в Windows как не инициализированый диск на 120 ГБ (размер ССД 120) Однако инициализировать или форматировать не удалось. В Убунту получилось с помощью 'dd' записать около 100 ГБ без проблем. По другому джамперы ставил, ничего не происходило. К 4 пиновому не притрагивался (как я понял это ком порт). Так же пробовал с помощью старых версий SSD Toolbox, а так же новых и Live CD от OCZ накатить прошивку, устройство не находит ни в каком состоянии (с джампером и без)
