gserg писал(а):
the system identifies the matrix after reading the EDID, the power is supplied to it first, if the system recognizes the connection, the next will be powered by T-CON , power to the backlight is always present.
fortunately i have another 1564 for repair
i connect this laptop lcd cable to other one board and it works
so lcd cable and lcd panel is ok
but why this board not detect lcd?!
