Текущее время: 02 май 2024, 10:23
 Заголовок сообщения: asus (g751jy rev 2.0) bios dump w25x40
СообщениеДобавлено: 31 авг 2017, 16:35
i need bios dump for g751jy rev 2.0 but not for main bios i need it for w25x40 chip, thank you.
 Заголовок сообщения: Re: asus (g751jy rev 2.0) bios dump w25x40
СообщениеДобавлено: 01 сен 2017, 15:42
Try this
---------- Добавлено спустя 2 минуты 29 секунд: ----------
Or look here
viewtopic.php?f=40&t=63743
СообщениеДобавлено: 02 сен 2017, 12:38
that is for main bios i need it fro vga bios
СообщениеДобавлено: 02 сен 2017, 14:08
myth77
show your backup
СообщениеДобавлено: 02 сен 2017, 15:37
this is my old bios, it is from asus g751jy rev.2.5 motherboard...
Posted after 31 minute 18 seconds:
for those who wont to help this is the situation....
the laptop is rev 2.5 but i found only rev 2.0 on the net.....so, the laptop is turning on, no picture,has no voltage on 3v3 main and 3v3 aon net...i look at the boardview and found that voltage should come from 12vsus net, but for some reason it is not. First i found that the ec chip 25x40clsnig is not receiving any power, the voltage reading was zero or 0,1 v on aon net.
I was finally able to find area where the power problem is but i dont understand why and which part is responsible...please help :)
So first picture, this is ec chip and nowhere there is voltage relating ground, on aon net 0.09v.
I was searching through the boardview, checking how 3v3 main and aon nets are connected to the rest of the board and on the next picture i found that somewhere here is the problem. That resistor r7124 is on one side ok +12v on vsus net net on DGPU power main has 0 V.
I was not sure about that so i borrow almoust exactly the same laptop (his revision is 2.0 and doesnt have gsync) from my friend and i was right. His readings from his motherboard are ok and shown on the next picture.
I am not sure now what is going on. I checked resistence of that resistor (while on board) and it is reading 100k ohm. can anybody look at the boardview and picture please and suggest what to do next. The question is how to bring voltage to vga bios to 3v3 main and aon net. Why doesnt that chip receve voltage? also i have heat on cpu and gpu.
Thank you all!
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus rog g751jy (asus rog g751jy) нет заряда батареи
Avraham
2928
27 июл 2020, 10:10
Avraham Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus G751JY (G751JY Rev. 2.0) корорткий импульс на AC_BAT_SYS примерно каждую секунду
user54321
2149
26 янв 2019, 22:53
user54321 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. G751JY (G751JY rev 2.0) не видит сетевой контроллер
Mehrunes
08 июл 2018, 04:00
Mehrunes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. g751jy (g751jy) нет изображения
SEmp
13 май 2020, 19:49
Panovich Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. G751JY (G751JY) Отключается блок питания
Panovich
2174
14 май 2020, 17:54
Сейчас этот форум просматривают: kkv, malicious и гости: 35
