Текущее время: 06 май 2024, 16:08
 Заголовок сообщения: Asus (g752vw) Missing capacitor?
СообщениеДобавлено: 02 окт 2017, 12:08
I found that one capacitor is missing from the board...i wont to identify it but with no luck.
I attached the boardview it is part PC8916, but there are no details, only 2580?
Original photo i found on the internet, its not best resolution but best i could find..
Can someone tell me what are details regarding this capacitor?
Может ли кто-нибудь рассказать мне, какие детали относятся к этому конденсатору?
 Заголовок сообщения: Re: Asus (g752vw) Missing capacitor?
СообщениеДобавлено: 02 окт 2017, 12:53
Capacity stands at circuit (net) + 3VA. Check to see if the second contact on the ground.
It fits this capacity: 1U_0402_6.3V6K
СообщениеДобавлено: 02 окт 2017, 13:39
Hmm there is something wrong with last photo, that capacitor is on two nets: P_CHG_ACMOS_S_20 and P_CHG_ACMOS_G_20, Not the +3va
I probably hit something wrong
СообщениеДобавлено: 03 окт 2017, 13:58
Yes, I see.
Ok
If you place the pointer (arrow) in the upper-left corner \pin of an item on the pop-up appears characteristic of this element. If that doesn't work, give a link to this boardview
СообщениеДобавлено: 03 окт 2017, 15:06
no details, nothing, only that mark i already wrote 2580?!
Boardview i already attached, but here it is again on the bottom.
СообщениеДобавлено: 03 окт 2017, 20:13
ok. i jast see.
in the file parts.ASC
I read:
PC8916 6.958 8.023 270.0 3D (T) '2580 1A30-0085D00', 'NBS_C0603_H37_000S'
it means
PC8916 is NBS_C0603_H37_000S
0603 -case
H37_000S -capasity
---------- Добавлено спустя 6 минут 29 секунд: ----------
What program can read this boardview?
СообщениеДобавлено: 04 окт 2017, 11:37
aaa now i understand, open parts.asc with notepad...thank you very much :)
СообщениеДобавлено: 04 окт 2017, 12:38
may be.may be...
1A30 is 10V, 30 pF ???
as in
https://product.tdk.com/info/en/catalog ... ral_en.pdf
В этой теме нет новых непрочитанных сообщений. Lenovo Ideapad B5400/M5400 (DA0BM5MB8D0 Rev:D) no power / Capacitor shorted
comasutra
07 фев 2017, 05:20
В этой теме нет новых непрочитанных сообщений. Samsung tablet does not charge, is it a capacitor problem?
в форуме Samsung
Annaaaaa
14 авг 2018, 18:44
youngwar Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv aoc D26W931 Exploding Capacitor 100uF / 450V and tny277 Source Board (PSU)
в форуме Ремонт мониторов | LCD repair
eletmoraes
11 окт 2019, 08:15
mia Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. I can't find 2.2mf polyester capacitor by 900V
eletmoraes
06 авг 2020, 07:27
В этой теме нет новых непрочитанных сообщений. mesr-100 ESR capacitor tester
в форуме Беседка
crow84
27 окт 2021, 15:30
crow84 Перейти к последнему сообщению
Сейчас этот форум просматривают: agafon27, doncah9i, kinoxa, Marshall007, Olgert, pecisal696, Vyacheslav007 и гости: 46
cron
