Текущее время: 02 май 2024, 23:49
 Заголовок сообщения: Sony Vaio SVE151j11M (DA0HK5MB6F0 MBX-269) CONSTANT BIOS RESET- NEED HELP Спасиьа!
СообщениеДобавлено: 26 окт 2017, 01:30
Ok , i am from EX- YU .
Doing some board repairs.
Laptop had a BIOS issue - laptop model SVE151J11M turns on, no picture, found bios on this site, flashed, got picture, boot to bios via VAIO button. after reset, got black screen, no picture. new start, again get picture, after reset, no picture... one thing i have noticed is that i cannot read EC chip version. says UNKNOWN
Reflashed old bios again, this time have picture, can go to bios via VAIO button, can setup bios to boot, however, after reset i get to VAIO screen and it constantly gives me no operating system found. i shut down it and start with vaio button, however every time bios gets reset to factory defaults.
i have replaced cmos battery, here is the schematics:
http://www.s-manuals.com/pdf/motherboar ... matics.pdf
my board is revision f, schematics is other revision, but it is the same board with same chips.
i have checked 3v passing diode d18
also i have measured 3v on pu110 , pu111 and pu112 , i do have 3v on pins which are connected to 3v rtc.
i have connected SVOD programmer via keyboard connector to the motherboard USB from the left side ( USB 3.0 ) and to my laptop. I could not detect Novotoun EC chip.
i guess EC has a bad firmware and it cannot be detected , thats why PCH is giving signal to reset bios?
does anyone here knows how to stop BIOS reset?
Thank you for your help!
Спасиьа!
 Заголовок сообщения: Re: Sony Vaio SVE151j11M (DA0HK5MB6F0 MBX-269) CONSTANT BIOS RESET- NEED HELP Спасиьа!
СообщениеДобавлено: 27 окт 2017, 18:25
your kbc is not programmable that's why it does not detect it
here is the list of those that are programmable
ene kb9012 programmable
ene kb9016 programmable
ene kb9018 programmable
ene kb9022 programmable
ene kb9028qc programmable
ene kb9010 programmable
ene kb3930qf/b1 programmable
ite it8585e programmable
ite it8586e programmable
ite it8985e programmable
www.Dr-Bios.com
ite it8587e programmable
ite it8522 programmable
ite it8987e programmable
ite it8589 programmable
ite IT8380E programmable 192kb
ite IT8380VG programmable 192kb
ite IT8995E-128 programmable
ite it8886H programmable
ite it8886he programmable
ite it8386 programmable
nuvoton npce288na0dx programmable
nuvoton npce388na0dx programmable
SMSC MEC 1609 programmable
СообщениеДобавлено: 27 окт 2017, 23:12
so this EC is not programmable? why am i getting error EC version Unknown inside of BIOS? why does my RTC always resets, it resets during power plugged in, during 3v cmos battery in, every time i start it it returns to default settings.
do i need to program EC? i have replaced many kb9012 , ite 8587e ite 8587e and they never made any problems.
i just replaced them and it worked fine.
sometimes i bought new ec ite 8587 and replace the burned one and it works, i plug in programmer and from their official page for that board model i download ec firmware, upload it on ec controller and the board wont start anymore :D
so this may be bios issue? i am going to flash some other BIOSes to see if it will work. Thank you for your help
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. SVE151J11M (DA0HK5MB6F0 MBX-269 rev f) Нет включения и индикации
в форуме Sony
Homemaster
29
4330
10 июл 2020, 22:04
Homemaster Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. SVE151J11M (Quanta HK5 MBX-269) Последовательность запуска
в форуме Sony
clock
06 ноя 2019, 20:24
clock Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sony Vaio SVE151j11v (DA0HK5MB6F0 MBX-269 Rev:F) Не включается
progaks
07 авг 2014, 14:09
Blauvolt Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony Vaio (da0hk5mb6f0 mbx-269 ) белый экран
в форуме Sony
Vusal
12
5569
28 фев 2016, 14:33
Dmitriy07 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. SONY vaio sve151e11v (DA0HK5MB6F0 MBX-269 REV: F) красное изображение
в форуме Sony
mochalov28
18 май 2015, 09:53
KSergei Перейти к последнему сообщению
