Текущее время: 28 апр 2024, 05:58
 Заголовок сообщения: tv lcd lg32pc5rv no power , led board principal flashing
СообщениеДобавлено: 14 дек 2017, 00:01
P814 pin stby5V pin with 5v but oscillating. the miniature led on the main board flashes and sometimes turns red and then flashes again. I checked and tested all of the electrolytic capacitors on the source power board, but all are normal.
I put a video in mp4 of the meter measuring the voltage of 5v of the standby, sorry for the bad image
 Заголовок сообщения: Re: tv lcd lg32pc5rv no power , led board principal flashing
СообщениеДобавлено: 19 дек 2017, 15:50
I was able to locate the faulty component that caused the 5v voltage on the stby5V pin of the P814 connector to oscillate, it was the PC201 (photo aclopator 817) component. Now the voltage is right.
When I turned on the TV I noticed that the high voltages that feed the YSUS card are missing.
I re-examined the source plate for the in the that provides voltages to the Ysus board. When replacing the PC802 photoaclobler the TV has returned to normal operation.
Posted after 7 minutes 8 seconds:
When I turned on the TV, I noticed that a pixel line is erased at the top of the image. I found two trails from the flat cable that goes to the P6 connector on the YSUS card, how can I recover these trails?
according to the attached image, with a red circle
В этой теме нет новых непрочитанных сообщений. monitor / lcd tv LG M227WD led flashing on the power button
в форуме LG
eletmoraes
28 авг 2014, 15:48
eletmoraes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Hp (4520s) Not power on ... dc jack led flashing
nasser_pczone1
18 июл 2018, 12:38
nasser_pczone1 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. hp elitebook 2540P (MB KATIO LA-5251P ) no power led flashing panel 2 times
eletmoraes
27 апр 2019, 04:46
В этой теме нет новых непрочитанных сообщений. Hp14s-dq1508sa (Quanta PAD DA0PADMB8F1 rev:F ) not turn on power led flashing
kamil1986
1564
12 ноя 2021, 20:33
kamil1986 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus N752VX (PCB) power LED flashing twice
BugDroid
11 фев 2024, 02:49
BugDroid Перейти к последнему сообщению
cron
