Текущее время: 05 май 2024, 09:35
latitude
Заголовок сообщения: Lenovo Thinkpad Yoga 14 /s3/ (Wistron LCB-1 13323) Can't turn on on battery only. Добавлено: 20 мар 2018, 14:59 |
Сообщения: 67 Откуда: Bulgaria
Hello everybody. I have a problem with this notebook - can't turn on on battery only. When charger is plug in, notebook starts normally, Windows loading and everything looks fine. Battery status is '100% charged'. But when disconnect power adapter, notebooks turns off. There is a small I/O board for dc jack, battery jack, usb, etc. I/O board connects to motherboard with cable. What I did: - think charger issue. replace charger - no result. - connect power adapter - 20v present. - connect battery - 15v present on pin 6,7 /last 2 pins/, but these 15V not present on connector from the I/O board to motherboard. I can't find schematic for this board, if someone can help, I will buy a beer :) I/O board attached to post. Thanks.
