This laptop turns on, but it does not have an image, the backlight turns on, but the image is black, the keyboard works, the work done: BIOS program Nec Tokin Capacitor Replacement Change the CPU Replacing Ram what is your opinion?
and555
Заголовок сообщения: Re: HP (Compaq 620(VV10 - INTEL UMA 6050A2364601 -REV A01) No image
Добавлено: 15 сен 2018, 11:30
Зарегистрирован: 10 апр 2012, 22:42 Наличности на руках: 86.09 Сообщения: 285 Откуда: Indonesia
this is the most common problem.
farzad120 писал(а):
the keyboard works
how do You know it work? if You can shutdown via keyboard, then LCD might problem. please test on external LCD monitor.
Сейчас этот форум просматривают: spacestav и гости: 35
