Текущее время: 26 апр 2024, 21:04
 Заголовок сообщения: Asus HD 5870 1GB v2 No power on memory controller and 0 ohms
СообщениеДобавлено: 11 окт 2018, 20:29
Good afternoon for everyone :)
I haven't got idea what is broken so I decided to ask you about help.
I have problem with no power on memory controller. I have took controller coil off and I made tests.
The photo illustrates my reflections.
I think that the RT8105 is broken but I would like to be sure and that is why I need your help. I want to know which direction power is going.
But first of all.
Resistance under coil is 0ohm or 288k ohm.
About voltages
RT8105: 1. Boot = 12V, 2. UGate 0V, 3. GND 0V, 4. LGate 0V, 5. VCC 12V, 6. FB 0B, 7. OPS 1,55V 8. 0V
My considerations lead to UGate is connected with GATE 7030AL (MOS), and LGate is connected with GATE OF 5030AL. Moreover source from 7030 is conected with Drains of 5030.
However I am not sure which value schould be and where.
So the voltage on the UGATE and LGATE should be more than 0V?
Which is the direction from RT8105 to mosfets or maybe from mosfet to RT8105?
In my second test I connect power supply with 1,5V and 4A to coil where was 0 ohm but I didn't find anything. However I think that it is not surprise for you.
Is it short or not?
Should I search in another place on the pcb?
At the end I would like to add that I checked all fuses.
What's more on the picture I mark it that only 7030 have 12V on the drain, where source and gate are 0V. On the 5030 everywhere is 0.
 Заголовок сообщения: Re: Asus HD 5870 1GB v2 No power on memory controller and 0 ohms
СообщениеДобавлено: 12 окт 2018, 01:02
1) check fuses
2) if on the memory side ~ 0 ohm, then gpu is dead
СообщениеДобавлено: 12 окт 2018, 08:41
может память сдохла?
maybe memory dead?
---------- Добавлено спустя 8 минут 23 секунды: ----------
how much current was be?
how much current?
---------- Добавлено спустя 3 минуты 33 секунды: ----------
source 5030 at the ground, 0 it is normal
---------- Добавлено спустя 1 минуту 13 секунд: ----------
for good understanding how RT8105 works, see datasheet
СообщениеДобавлено: 12 окт 2018, 23:05
Im not sure is it memory site or not. However I have tested it one more time I give 1,5V and 5A. Te maximum voltage was about 1V and 5A. I have used pirometer to check GPU temperature and there was about 1 celcius degree more. That is why I decided to take off gpu and the short has gone. I have yet 15 pcs 5870, so I will try to replace the gpu.
I was very surprised when I took gpu off because almost all of balls was almost that same like after putting new balls. I think that gpu was wrong soldered or something like that.
I will tell more If I place another gpu.
СообщениеДобавлено: 13 окт 2018, 00:47
СообщениеДобавлено: 13 окт 2018, 10:51
Quaint
а память в таком случае не может быть дохлой?
СообщениеДобавлено: 13 окт 2018, 11:10
Hi, After I had taken GPU off I checked voltages and I was very suprised because now I have about 6-7V on memory controller. It is too much. Could you tell me what can I do now or where I schould looking for?
СообщениеДобавлено: 13 окт 2018, 11:42
i think upper mosfet is dead(short circuit)
check all memory mosfet
В этой теме нет новых непрочитанных сообщений. Shappire 5870 1GB power cutoff after few second.
Micchaleq
11 окт 2018, 19:05
Micchaleq Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS RTX 2080ti Question for ohms? and other...
PT-AH
17 ноя 2023, 19:41
PT-AH Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL INSPIRON 3521 (la-9104p) Memory Power Supply Controller
в форуме Dell
Tenhi
04 май 2016, 16:56
В этой теме нет новых непрочитанных сообщений. 250 G3 (ZS050 LA-A994P) 3.3V Power Rail 40 OHms
battery13v
23 янв 2020, 12:34
battery13v Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 23:26
Assassin Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 61
