Текущее время: 21 май 2024, 02:51
 Заголовок сообщения: a1398 (820-00426-a) vga 216-0846081 with horizontal lines, changed with new one and the macbook doesn't power
СообщениеДобавлено: 27 фев 2019, 11:55
hi to all, sorry if i write in english, but i'm italian
i've a macbook pro 15 retina middle 2015. the first problem was white screen after some times using it.
]in this case, i did reboot and no problem. after some week, when i had white screen, i did reboot but blue screen o grey screen with apple logo and stuck here
after some weeks it gave me only big vertical white lines with the apple logo. and it froze here
so i have ordered a new bga (216-0846081) and new vga ram
with the new bga, the macbook doesn't turn on at all. if i solder the old bga, the macbook power on with vertical lines. i've tried to solder the new vram with the old bga but same result: vertical lines
i would like to know: is it possible that i should program the macbook for installing the new bga?
if yes? how?
thanks
 Заголовок сообщения: Re: a1398 (820-00426-a) vga 216-0846081 with horizontal lines, changed with new one and the macbook doesn't po
СообщениеДобавлено: 27 фев 2019, 13:45
Good day.
In order to put a new video chip, there is nothing to program.
Also on this board you can put the chip 216-0846000 without any alterations, gpu id it has exactly the same k and 216-0846081.
It is possible that you have a problem in tying the memory modules. Ring all the resistors in the memory strapping.
Честный ремонт техники Apple и обычных ноутбуков в городе Краснодар.
СообщениеДобавлено: 27 фев 2019, 13:48
Need no program new bga. May be remark chip with 64bit adress lines. Reball old chip, maybe no problems with it.
СообщениеДобавлено: 27 фев 2019, 13:53
hi guys thank you for the help. i try to explain better all the step
1 step: reballed the gpu: no look, always lines
2 step: installed new gpu: macbook doesnt start
3 step: installed old gpu: macbook start with lines
4 step: installed new vram: still with lines
СообщениеДобавлено: 27 фев 2019, 14:00
Most likely the new chip is not working. And instead of 216-0846081 you can install 216-0846000. It is easier to get it.
Yes, and perhaps the problem is not in the chip and not in memory, but in the memory strapping. Faced with this problem on this board.
Check all the resistors near the memory.
Do you have a circuit and a BoardViewer? If yes, then check the resistors R8903, R8953, R8803 and R8853, their break can have a similar effect.
СообщениеДобавлено: 27 фев 2019, 17:38
d-pad thank you for your help! i have search in the whole internet, but i dont find any schematic of 820-00426 so for me it's impossible to fix it
СообщениеДобавлено: 27 фев 2019, 18:42
Check your email.
СообщениеДобавлено: 27 фев 2019, 23:08
thank you d-pad!
В этой теме нет новых непрочитанных сообщений. A1398 2015 (820-00426 820-00163) Отличия плат 820-00426 и 820-00163
в форуме Apple
d-pal
2910
06 фев 2022, 14:51
gsmprofi Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. macbook (A1286) horizontal lines
в форуме Apple
basic
1701
17 ноя 2017, 20:32
flusher Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Биос видеочипа (M370X/M270X) 216-0846081
в форуме Apple
Make1ive
17 янв 2019, 19:24
Make1ive Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook A1398 (820-00426-A) Странное поведение, постоянная перезагрузка
в форуме Apple
sudhir
3036
10 окт 2018, 22:32
sudhir Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Продам материнскую плату 820-00426-A MacBook Pro 15 A1398 2015
d-pal
09 авг 2019, 22:30
d-pal Перейти к последнему сообщению
Сейчас этот форум просматривают: minotaur и гости: 13
