Текущее время: 01 май 2024, 14:10
 Заголовок сообщения: MSI GE73VR (ms-16p11) no lcd/hdmi image
СообщениеДобавлено: 01 июл 2019, 14:01
Hi, this laptop have problems with lcd/hdmi image.
It have the kbc in short circuit, but replaced with a new one. (damaged by a problem with the flex cable)
I have reprogrammed the kbc with data extracted from main bios. (from 2 different dumps)
Bios chip has the last bios update from MSI website. (E17C1IMS.10B.BIN)
Operating system loads fully from ssd, and also boots from usb pendrive, but with no image at all.
Can someone share the schematic or point me in the right direction in order to solve the problem?
Thanks in advance.
 Заголовок сообщения: Re: MSI GE73VR (ms-16p11) no lcd/hdmi image
СообщениеДобавлено: 09 июл 2019, 23:46
Where are the stress measurements?
СообщениеДобавлено: 09 авг 2019, 13:37
One month later and have some news:
The lcd screen was also damaged and now with a new one, there is image. (hwinfo32 and other utils does not detect it, only intel gpu)
The problem now is that discrete gpu does not work.
The gpu is powering by a six phase circuit that feeds it with .9 volts.
The xtal near gpu Y8 (27 Mhz) has a god oscillation signal.
All other voltage on mothrboard seems correct, except for those 2 coils near to cpu. (pl12 and pl15) (both are .22uH)
Those coils seems to feed the internal graphical part in cpu, but if it is a little estrange.
If someone has some comments it will be welcome.
Thanks.
СообщениеДобавлено: 09 авг 2019, 18:49
Some more research:
The signal DDIB_LANE0_DP going for Display Port connector comes from cpu pin K36 as some other signals for Display Port. (see MSI MS-16J51 schematic)
Display Port is not function on this mobo, so is it possible that both problems have something in common?
Вложение:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI GE73VR 7RF-061RU (MS-16P11 VER:1.0) Идентификация ШИМ
в форуме MSI
СерегаЗиновьев
03 июн 2019, 18:43
СерегаЗиновьев Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. TOSHIBA Satellite L50D (DA0BLMMB6E0 Rev. E) No lcd image, hdmi ok.
в форуме Toshiba
andromedax
20 янв 2018, 16:15
Котеус Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv plasma sony KDL-46ex725 image with black stripe at the top of the image
eletmoraes
06 сен 2017, 17:25
eletmoraes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. tv LG 42PQ30R has image defect as attached image
в форуме PDP
eletmoraes
21 ноя 2019, 02:43
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI MS-16p1 (MS-16p11 v1.0) Короткое в первичке
в форуме MSI
НатальяZz
1822
09 сен 2020, 12:41
НатальяZz Перейти к последнему сообщению
Сейчас этот форум просматривают: Doc и гости: 6
