Зарегистрирован: 12 дек 2015, 00:02 Наличности на руках: 71.61 Сообщения: 394 Откуда: Serbia Заблокирован
i cant open file with boardview Posted after 14 minutes 41 second: thanks everything is ok..Thanks so much!! Posted after 20 minutes 36 seconds: Please can you help me with VRM EN signal ?
it's bad... you have broken cirkuit vcore, no signal vrm_en, no signal slp_s3 and I don't understand how MB power on without slp_s3... vpp is present? (choke8)
bokin021
Заголовок сообщения: Re: msi z170a Boardview
Добавлено: 17 окт 2019, 15:12
slp_s3 it is 3.3 v pch 1.01v maybe i did mystake when i write you Posted after 3 minutes 37 seconds: (choke8) is ) 0v
