now try flash bios one more time. for test mb use ok cpu and memory
bokin021
Заголовок сообщения: Re: msi z170a Boardview
Добавлено: 17 окт 2019, 16:48
Зарегистрирован: 12 дек 2015, 00:02 Наличности на руках: 71.61 Сообщения: 394 Откуда: Serbia Заблокирован
i alredy did bios and also memory ,cpu is ok..
bokin021
Добавлено: 18 окт 2019, 10:52
Can you please tell me some direction about repair motherboard ,for example yesterday you understand what d happen with motherboard,maybe there's some Manual for motherboard or repair guide ?
cpu and memory ok - are you testing it on another mb or he was ok early?
bokin021
Добавлено: 18 окт 2019, 14:28
i did on other board everthing is ok..I notice that part what i change ,get hot when i touch with finger ..Maybe is dammage to ,but still giving correct voltage ..I will try find another one and see after word..
vik70
Добавлено: 14 апр 2020, 09:55
Зарегистрирован: 13 апр 2020, 07:31 Наличности на руках: 1.00 Сообщения: 1 Откуда: Томск
jocker
Здравствуйте, уважаемый. Не поделитесь boardview на MSI MS-7977. Заранее благодарю.
