Текущее время: 01 май 2024, 15:58
 Заголовок сообщения: B&W Zeppelin Air Random shutdown.
СообщениеДобавлено: 03 дек 2019, 12:39
привет! Greetings from Hungary. Sorry i need to write in english cos my Russian skills are way to low atm. : D
Is there a B and W Zeppelin air veteran here?
Its did not turn on. I replaced the psu caps and then its started, but its only working for 5 to 10 minutes, than its shut down or restart. (Sometimes shut down and never turn on again)
Can you give me any advice, where i start? Its a common problem i think. Some soldering gave up maybe on the motherboard?
Спасибо!
 Заголовок сообщения: Re: B&W Zeppelin Air Random shutdown.
СообщениеДобавлено: 03 дек 2019, 21:04
prijezhaiti k nam v zauralskoe ja vse vam pochinu.pirikataim proz
СообщениеДобавлено: 04 дек 2019, 14:29
Спасибо. Мы были там тысячи лет назад с некоторыми скифами. Климат в Карпатском бассейне для меня лучше. : D
СообщениеДобавлено: 04 дек 2019, 14:36
Good photo's of cover with marking label and both sides of all PCB's ?
СообщениеДобавлено: 04 дек 2019, 16:16
Thanks for the help!
They all looks good. Sadly there are no burned components. I hope these pics will fine.
https://ibb.co/j8Y8WX5
https://ibb.co/jfwY0xZ
https://ibb.co/T2q5Z7B
https://ibb.co/vxSRpZW
https://ibb.co/tqk3zPd
СообщениеДобавлено: 04 дек 2019, 16:44
U7 on photo https://ibb.co/vxSRpZW was replacement by you ?
The boards could vibrate to the beat with loud sounds. Therefore, check with a magnifying glass if some solders are broken.
СообщениеДобавлено: 04 дек 2019, 18:38
Nope U7 was there like that when i "arrived". I only replaced capacitors.
Yes, i suspected that too. After the change of the caps i tested with high bass music with almost full volume and its worked. After 5-10 minutes its turn off if the volume high or low too.Спасибо за помощь!
I think its heat related problem. I inspected that two board with m.scope and sadly everything looked good. : /
In the end i'll resolder everything (too)..
(For the twist i got another zeppelin today with burned transistors on PSU and MOBO too, so i can't do a swap for test.. : D)
большое спасибо вам!
СообщениеДобавлено: 04 дек 2019, 20:48
May be needed https://www.abcelectronique.com/forum/s ... 915&page=1
 Заголовок сообщения: Re: B&W Zeppelin Air Random shutdown.  [РЕШЕНО]
СообщениеДобавлено: 05 дек 2019, 12:24
Это отличная помощь! Спасибо!
Posted after 4 hours 30 minutes 24 seconds:
Oh my god.. Someone brought in a third Zeppelin today. At the moment we do a cross swap test. Its look a like i managed to repair the first PSU ant there are some problem with the main motherboard. (10-15min reset)
I'll report back shortly.
Try my best with this : )
Боже мой! Кто-то сегодня привел третьего оратора. На данный момент мы проводим перекрестный своп-тест. Похоже, мне удалось отремонтировать первый блок питания и возникли проблемы с основной материнской платой. (Сброс 10-15 минут)
Я сообщу в ближайшее время.
Posted after 3 hours 39 minutes 30 seconds:
YES!
I inspected the motherboard very closely. There was a bad soldering point! Its working now. Two more left.
ДА!
Я очень внимательно осмотрел материнскую плату. Была плохая точка пайки! Теперь работает. Еще два осталось.
В этой теме нет новых непрочитанных сообщений. Acer aspire 5535 (cp2a MB) random boot
alifakhrniya
16 сен 2014, 10:30
alifakhrniya Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. E1-571 (LA-7912) Restart loop, random desplay
R EZ A
17 дек 2015, 21:38
R EZ A Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP DV6-1317ss (Quanta_UT3-UT5) random shut-down
andromedax
30 ноя 2016, 21:59
slava-yun Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Z510 random shut downs (hard) when plugged in
ahkh_72
18 июл 2017, 21:53
ahkh_72 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A135-S2386 (LA-3391P) random Display
abs
19 авг 2019, 16:45
abs Перейти к последнему сообщению
Сейчас этот форум просматривают: navkilerich и гости: 3
