Текущее время: 28 апр 2024, 02:26
 Заголовок сообщения: Microsoft Surface Pro 4 - Bios Problem
СообщениеДобавлено: 04 фев 2020, 13:46
hi guys
i have a surface pro 4 that came with battery problem
it doesn't charge more than 46%
i replace battery with new one and in also doesn't charge more than 46%
i flash bios ,charging problem solved
but now i have touch problem
it doesn't work even in bios menu
surface Touch Firmware in device Manager has error
windows update not help
i tried two more bios but same problem
this is my dump file with battery problem
i7 dump.rar
 Заголовок сообщения: Re: Microsoft Surface Pro 4 - Bios Problem
СообщениеДобавлено: 08 фев 2020, 18:53
any idea?
can someone make Clear ME Region of my file please?
i try to do that but when i drop bios file to ME Analyzer it cant detect version of file
СообщениеДобавлено: 24 фев 2020, 20:28
any idea about that?
i really need to solve it
СообщениеДобавлено: 25 фев 2020, 00:13
Where did you get the firmware? At the official website? Return the original BIOS firmware, and update: EC, ME, SAM, Touch, UEFI from under the OS.
On the official site, the firmware is encrypted in parts. It needs to be decrypted for the programmer. Then to assemble parts together.
This utility can do phoenix tool.
If the tablet is working, it’s easier to update from under the OS.
---------- Добавлено спустя 3 минуты 13 секунд: ----------
and then install the official drivers.
СообщениеДобавлено: 29 фев 2020, 20:33
i flash bin file that i find in forum
battery charging problem solved by that but then there is error on Surface Touch firmware in Device manager
i reinstall windows and update everything by windows update but there is still error on Surface Touch (code 10)
is there any way to backup Surface Touch from old firmware with battery problem?
СообщениеДобавлено: 29 фев 2020, 21:56
Update the touchpad firmware from the official website. You understand me, not?
OR get back the original your firmware to your device (i am about this your original firmware viewtopic.php?p=740072#p740072 )
and then update the firmware from the official wesite. after update the firmware - install the drivers from the official wesite.
the official website https://www.microsoft.com/en-us/downloa ... x?id=49498
there firmwares and drivers.
Сообщение не в тему
I changed the touchpad in the Lenovo tablet 2 - he did not work at once, and through 30 min began to work.
i rebooted the tablet several times and installed the drivers. I don't know why it took so long time to initialize.
There was no firmware for the touchpad on Lenovo official website.
СообщениеДобавлено: 10 май 2020, 22:40
i still can't solve this problem
its not about driver , because touchscreen with original firmware works in bios page
but even when i make ClearME from original file, touchscreen not work
i update everything with windows update and driver from microsoft website but ME firmware and TouchScreen Firmware have error sign in device manager
anyone has any idea?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Microsoft Surface Pro 4 clean bios backup
в форуме temp
salim.thebadboy
17 дек 2016, 22:19
salim.thebadboy Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. microsoft surface pro 4
в форуме Ремонт планшетных компьютеров | Tablet-PC repairs
azatar0890
21 фев 2019, 20:32
Maxxim74 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Microsoft Surface Pro 4 биос
dvoric
3489
01 фев 2019, 11:42
mixachev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Microsoft Surface Pro 3 мать
Maxxim74
04 дек 2018, 16:27
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. microsoft surface pro 1514 Включается, загружается но нет изображения и питания видео
Contect
08 дек 2018, 04:17
Contect Перейти к последнему сообщению
cron
